21st Nov 2013, 10:30 am | #1 |
The well-behaved valve TRF
I have made several over the years, with different valve combinations.
It doesn't make any difference, but they are all inclined to squeal when I want to wind the volume right up. I assume that there's still RF content in the signal that passes through the two audio stages & somehow that is getting back to the detector. Old TRF designs of the 1920's had the detector transformer-coupled to the audio stage/s. So, would purchase of a transformer instead of coupling the detector to the first audio stage with a 0.01uf capacitor effect a cure? What ratio should I buy? I see 3:1 & 5:1 ratios. I would never buy one unless it'd been resistance tested across each winding. |
21st Nov 2013, 10:50 am | #2 |
Re: The well-behaved valve TRF
If it is RF instability then you should see a big difference by putting a small value capacitor across the audio.
But it may well just be AF instability due to layout issues. I used to have big problems with this when I was a child, mainly because I couldn't afford to make a chassis out of metal. Transformer coupling does make it easier to avoid such problems. |
21st Nov 2013, 11:04 am | #3 |
Well behaved TRF's are normally have good screening between the audio and RF stages.
21st Nov 2013, 11:16 am | #4 |
Hi Neil, quite often an RF choke was also included in the anode circuit in series with the AF transformer.
Ed |
21st Nov 2013, 12:59 pm | #5 |
Another useful trick is to put a resistor of about 10K in series with the feed to the grid of any audio-stages. Wire it *right next to* the grid terminal on the valve-base with minimal lead-length.
The resistor, coupled with the few picofarads of grid-to-cathode capacitance, acts as a low-pass filter and removes the RF without unduly attenuating the audio component. |
14th Jul 2014, 2:13 pm | #6 |
I wondered whether there was RF getting along the HT line or not.
I added another HT transformer to the PSU: One for the detector, the other for the audio stages. A dramatic difference, but the PSU is 50% of the chassis space. You really do need screened cable anywhere that is carrying an audio signal: To & from the volume 'pot. Between the anode of the pre-amp and grid #1 of the 6V6. I can now wind the volume right up to '10' without a single squeak, no need for a grid-stopper resistor on the 6V6. I have got a HF choke to add in the feed to the anode of the detector. Maybe I can strip out the extra transformer even without using the choke? |
14th Jul 2014, 4:42 pm | #7 | |
Al. |
