Old 2nd Dec 2016, 5:15 pm   #41
julie_m
Default Re: 'THAT' Capacitor. What is it?
Originally Posted by DKW F102 View Post
I bought an E.S.R meter when I started geting my kit together but could not realy understand what it was supposed to be for, so have not used it since.
Equivalent Series Resistance (hereinafter abbreviated) is a property of any electronic component, and represents the fact that the connections are never perfect conductors. An electrolytic capacitor makes contact via the electrolyte, which can be a very imperfect conductor if the capacitor is old and worn out. In this state, its decoupling ability is reduced, since an AC voltage can exist across the equivalent series resistance; and there is now a positive feedback loop causing the capacitor to run warmer than it should, only accelerating its own demise.
An E.S.R. meter is designed to work at a very low voltage, too small to turn on a semiconductor junction, and a high frequency so the capacitive reactance is close to zero; so it can be applied to a capacitor still in-circuit without fear of false readings. It would normally be usedf or testing the capacitors in a switched-mode PSU, which are required to have a low E.S.R. for correct operation. But a high E.S.R. is a problem in any decoupling or smoothing capacitor; and also in a loudspeaker DC blocking capacitor, since it ends up stealing some energy that should have gone into the speaker.
Since a capacitor which has started to go high-E.S.R. probably also has begun failing in other ways, it can be useful for identifying faulty electrolytic capacitors in any circuit. I haven't got one yet, but I would definitely purchase one if I needed to do some repair work on a PSU or amplifier with many electrolytics. (But I probably would not buy one this close to Christmas, in case there was already one in Santa's sack ..... )
Capacitors used for DC blocking can develop an unwanted parallel resistance. This sometimes only begins to conduct at high voltage, so may not show up on a test meter using only a low voltage at the probes -- or even in real life, in a transistor circuit using only low voltages.
I measure my resistors with my AVO 8 and my capacitors with a Greyshaw CR 50 C/R Bridge. Both the AVO and the bridge have been overhalled /aligned by a kind member of this forum. Am I missing something I should realy be paying attention to ?
No, that's right. The AVO 8 was for many years considered the "gold standard" test instrument, until it was finally displaced in the 1980s - 90s by digital instruments such as the Fluke 77; and an AC bridge measures capacitance in a way that is less likely to be affected by DC leakage resistance than a modern, digital capacitance meter. The latter type work by measuring the time taken for the capacitor to charge enough to produce a certain voltage change, at a known current. A parallel resistance will take some of the energy that was meant to get stored in the capacitor; meaning it will charge more slowly than expected, and discharge more quickly. Most digital capacitance meters only time the charging phase, and ignore the time taken to discharge; so they will tend to read artificially high when testing leaky capacitors. An AC bridge is measuring the capacitive reactance (which is inversely proportional to capacitance) directly.
julie_m is offline   Reply With Quote
Old 14th Dec 2016, 9:59 pm   #42
DKW F102
Hi Again. I'm going to have to sit quietly and read this carefully. It seems like I have more to learn about capacitors. I always wondered why I was geting odd readings when I tried to check electrolytics. I understood when a wax paper type was leaky, but fought shy of Electrolytics because of the confusion.
DKW F102 is offline   Reply With Quote
Old 22nd Dec 2016, 1:59 am   #43
Graham G3ZVT
Graham G3ZVT's Avatar
I started by building TRF valve receivers when I was at school, did radio and TV at collage, worked in the TV repair industry on valve sets throughout the '70s and into the '80s, but I've never come across the term "That capacitor" until I read this thread. Now it has been explained to me I fully "get it".
I get worried, paranoid almost, about this capacitor, and the damage it can do if it goes leaky.
Good example is my old Yeasu FT200 transceiver, "That capacitor" is a well known stock fault, and the 6JS6C, finals are practically unobtainable.
Hence the paranoia.
Graham G3ZVT is offline   Reply With Quote
Old 17th Jul 2019, 10:50 pm   #44
FStephenMasek
Slang and acronyms may help communication amongst some people, but hinder it with others. I started my working life as a computer consultant, and have been an environmental consultant for the past 29 years, so have always had to take care when communicating with people who are not "insiders."
Why even bother testing any old paper and foil capacitors?
So many old resistors are far off of the correct value, so I often also replace all of them. Many are connected to the same locations which are de-soldered to replace the capacitors, so replacement adds very little additional effort and time.
FStephenMasek is offline   Reply With Quote
Old 18th Jul 2019, 5:47 pm   #45
Graham G3ZVT
I've noticed a different cultural ethos between the UK and USA in TV/Radio restoration, particularly when watching Youtubers like shango066. We seem to be more obsessed with maintaining originality, and sometimes have an almost reverent respect for these old chassis.
Graham.
G3ZVT
Old 19th Jul 2019, 8:30 am   #46
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
I agree with FStephenMasek. I'm in the process of repairing a Bush DAC90A, and have already replaced all the waxies, without bothering to test them-they are the best part of 70 years old and will all be electrically leaky. The resistors I have checked, and will replace out of tolerance ones. When undertaking these kind of jobs I metaphorically wear my 'service engineer's hat' i.e. I replace faulty components with the nearest equivalent modern ones. Waxed paper caps. I replace with yellow LCR or similar poly. wire-ended types, resistors usually with 2 watt metal film, since these are similar in size to the old carbon composition type. I don't re-stuff old components unless I'm working on a particularly rare radio.
'LIVEWIRE?' is offline   Reply With Quote
Old 19th Jul 2019, 9:03 am   #47
That's fine if you know what you're doing and have fault finding skills, but many newbies don't. They're convinced that if they change all the capacitors in a set they'll get it going without the need for so much as a test meter. Often they'll change capacitors in the RF and IF sections having values of a few pF, spoiling the alignment. There's also great scope for fitting the wrong value capacitor and introducing wiring faults. I've done both myself
"In changing a capacitor I dislodged a wire. Where does it go?" is a frequent plea for help.
The main fault may have been something as simple as a dodgy OFF/ON switch, which is easily repaired or it might have been an open circuit transformer winding which could render the set BER. These faults could easily have been found with a meter without the need to apply power to the set.
It surprises me that some newbies are willing to change any component because they think it may be faulty, but won't take a few resistance or voltage readings.
As for record players, the simplest two valve amplifier seems to defeat some people even though they're given sound advice on testing and repairing it.
Old 19th Jul 2019, 9:09 am   #48
Heatercathodeshort
Heatercathodeshort's Avatar
They want 'instant' results with everything or it goes for 'recycling'.. John.
Old 19th Jul 2019, 9:37 am   #49
'LIVEWIRE?'
Points taken, Graham and HCS. In my defence I'll point out that I have been a service engineer since 1971, and before that a hobbyist for 3 or 4 years, none of which means I'm immune to making mistakes-far from it-but over all those years if I've learned nothing else it's when to spend time testing & checking and when, by visual inspection,to simply replace things. I still replace parts such as capacitors, one at a time, and check after so doing that I've wired things correctly.
Old 19th Jul 2019, 9:43 am   #50
No need to defend yourself. I have no doubts concerning your technical ability and skills.
Old 19th Jul 2019, 11:19 am   #51
kalee20
It's ironic that the replaceable parts are the ones that usually stay with any radio I attend to, whereas the there-for-life, wired-in components, are the ones which get replaced.
I have several radios where I have needed to rewind the mains transformer, and replace waxies, but the plug-in, life-limited valves are still originals!
Whether faulty or not, 'that capacitor' gets replaced as a matter of course. Modern polyester capacitors are so good, they'll see me out - and the next generation too. 40-year-old Mullard C296's would be left in place, but so far I have not dealt with a valve radio new enough to have been fitted with them from new!
kalee20 is online now   Reply With Quote
Old 19th Jul 2019, 11:25 am   #52
I don't _always_ replace "that capacitor" - some Philips radios from the 50s and 60s use a ceramic capacitor there, which never seems to fail.
(watch out though for some strange Philips 'things' that incorporate two capacitors and a resistor into one unit - these are often used as IF-decouplers in detector circuits. The resistor-component can be a source of an annoying background 'rustle' sound when it goes intermittent)
Old 19th Jul 2019, 12:12 pm   #53
"You should replace that capacitor"...."Which capacitor?"...."That capacitor"....."Do you mean that one there?"...."No, that capacitor"....."Ah, got it now, this capacitor?"...."No, no, that capacitor"...."I see...that capacitor?"....."No, no, no, this capacitor"...."But you said to replace that capacitor?".... "I did but it's not that capacitor you need to replace it's this capacitor"...."So....this capacitor there then?"...."Yes"..."But you said replace that capacitor which is this one which isn't that one?"...."I did but it's that capacitor"...."Got it now, you mean replace the grid coupling capacitor?"....."Yes"...."No problem"
ms660 is offline   Reply With Quote
Old 19th Jul 2019, 1:38 pm   #54
ekjdm14
This forum requires a post-like feature for Lawrence's post alone... (that post, not this one or those ones!)
Never forget some kit doesn't have that cap but those caps!)
ekjdm14 is offline   Reply With Quote
Old 22nd Jul 2019, 4:53 pm   #55
crackle
Nice one Lawrence, that just about sums up the stupid annoying term
Mike
crackle is offline   Reply With Quote
Old 27th Sep 2019, 3:33 pm   #56
HoraceBatchelor
Following on with this capacitor question. To a complete novice like me it is so confusing. It's just a question with too many answers. To get answers like, "change that cap if you don't do anything else" Or "you need to change all paper, wax caps", viable answers but.......I started as purely a collector not a fixer. But as my collection grows i would like to be able to do the simplest of fix where's needed. Two of my radios, cracking looking sets both, a Philips 141u and a Bush vhf 70 need a fix just to allow me to say that they work even if its only a couple of minutes per week. the 141u works good enough for what i need. but its got a big black cap that is burst open making me not keen to use it. The Bush doesn't work as well, only lots of whistling and crackling as it passes where stations are.
So to begin with i downloaded the bush manual thinking i may learn something. No. just more confused. the page showing all the numbered components would be a great help if i knew what they were and what they do, and the ones to replace them with, but i don't. No doubt someone will tell me to read the numbers on the original and replace with similar, but when no numbers are visible it becomes difficult. Take the blown cap in the Philips for example, any writing that may have been on it, is no longer visible.
Is there an answer to these questions that anyone can give me. Or should i just concentrate on collecting and leave the mending to you experts? But i don't want to do that. i want to tell people when they look at my collection that, "this is one that i fixed." So any suggestions will be appreciated.
HoraceBatchelor is offline   Reply With Quote
Old 27th Sep 2019, 4:07 pm   #57
That capacitor over there is the that capacitor
This capacitor over here isn't the that capacitor, it's just another capacitor.
But that posh push-pull set has two that capacitors and an awful lot of capacitors which aren't that capacitors.
Simples!
Old 27th Sep 2019, 4:23 pm   #58
Nuvistor
Nuvistor's Avatar
Hi Horacebatchelor,
Just need to start with the basics if you want to learn to read those manuals. Some theory learned and the simple circuits in most 1950’/60’s domestic radios will be understandable.
Start with this from Paul Stenning and then perhaps some books, GN Patchetts Radio books are full of good information. Lots of others, MG Scroggie wrote the excellent series Foundations of Wireless.
Learn some theory and it will be a lot clearer.
https://www.vintage-radio.com/repair...ion/index.html
Frank
Nuvistor is offline   Reply With Quote
Old 27th Sep 2019, 4:30 pm   #59
^^^^ Ditto.
Everything you need to know is in the basic theory and the schematics/manuals you've been looking at.
The Force helps those that help themselves.
Old 27th Sep 2019, 5:56 pm   #60
Don't forget that there's always plenty of helpful help here as well as a sprinkling of THAT help
More to the point, a decent photo of a suspect capacitor in situ like in the Philips set will almost certainly be enough for someone here to identify it for you and suggest a suitable replacement. Easy if you just want functionality back, a bit more involved if you want it all to look original as well.
A lot of Philips manufacturer's service info is around which usually has layout pictures as well as basic circuits and service data- it may be in Dutch, but a picture's a picture and there're enough members with enough Dutch or German to make a good stab at understanding the technical terms.
