Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets and Parts Wanted (private buyers only, no swaps)
Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 20th Nov 2023, 8:19 pm   #1
EF80TVVALVE
EF80TVVALVE's Avatar
Default UX5 type male plug
Hi Everyone,
I'm trying to source a UX5 male plug so I can build an original type speaker for my Pathe Vox projectors without needing to modify the sockets. I have attached a photo of the pin configuration as I have a couple of 47 type valves in an amplifier. I used one to check that it is indeed a UX5 socket.
If anybody can help then that would be great, at worse a base from a U/S UX5 valve would work okay but it would be nice to find a proper plug too.
Bren
ID:	288470   Click image for larger version
EF80TVVALVE is online now   Reply With Quote
Old 20th Nov 2023, 8:59 pm   #2
Cruisin Marine
Default Re: UX5 type male plug
As a last resort you could use an 807 valve base turned in to the plug you desire with some sealant after it is made.
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline   Reply With Quote
Old 21st Nov 2023, 11:20 am   #3
EF80TVVALVE
Yes that's the plan if one can't be sourced. Would be a shame to remove one from a perfectly good valve though so if anybody has a bad UX5 socketed valve then that would be great.
Old 22nd Nov 2023, 7:12 am   #4
FrankB
I save the old dead tubes to make plugs from when I need them.
A 5 pin base from a 24, 24A , 51, or a 41 would work. Also Cinch Jones and Amphenol also make the 5 pin bases. possibly you could find a juke box repairman. IIRC they used them in the juke boxes for inter connecting cable wiring.
Probably I can dig one out, but postage from the States would likely exceed cost of one there.
FrankB is offline   Reply With Quote
Old 22nd Nov 2023, 10:34 am   #5
cmjones01
This is a great idea, and I save some old valves for the same reason. But UX-based valves, with the possible exception of the 807, are nowhere near as common on this side of the Atlantic. British pre-Octal era valves were mostly B4/B5/B7 bases, and continental European ones also use the "Footless" and side contact bases which are very rare in the USA.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline   Reply With Quote
Old 22nd Nov 2023, 12:57 pm   #6
EF80TVVALVE
Thanks for the replies. Frank, if you manage to find one of the 'proper' UX5 type interconnecting plugs then I would be happy to pay for shipping from the states otherwise it'll probably be cheaper for me to source an 807 here and remove the base. As Chris said the UX type bases were not common here in the UK so things like interconnecting cables often used a pattern similar to our B4 bases. I think Pathe only used them as there looks to be some American influence on their projector amplifiers, they use all American valve line ups and American plugs and sockets. I don't know if that was similar across all of France at the time but it strikes me as a bit unusual.
Old 22nd Nov 2023, 1:39 pm   #7
David G4EBT
David G4EBT's Avatar
There are quite a few 807s on eBay untested (apart from heaters) from £5.00 - £7.00.
It takes a lot to wear out an 807, so it may seem a shame to sacrifice one, but needs must...
EG: Untested 807, 'buy it now' £5.00 + £3.30 post:
https://www.ebay.co.uk/itm/195311897...YAAOSwD1xjCbbY
Good luck in your quest Bren.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline   Reply With Quote
Old 22nd Nov 2023, 7:17 pm   #8
Diabolical Artificer
Diabolical Artificer's Avatar
I have an 807 base if you want it Bren, FOC + £3 post. Drop me a PM if interested, Andy.
Diabolical Artificer is offline   Reply With Quote
Reply
