Old 22nd Jun 2009, 11:47 am   #1
yestertech
yestertech's Avatar
Default yacht boy 209 - current 'leakage'
I've just found that my recently refurbished yacht boy 209 has chewed through the new "D" batteries when left idle for a week.
The radio was not switched on.
The symptoms were low volume /distortion and complete failure if the dial light button was pressed in
I suspected the batteries but as a check connected a PP9 to the external PSU adaptor. This restored normal operation
The radio pulls around 100 + ma when on low volume, but to my surprise when switched off there is still a drain of around 65 ma !
I can't see anything on the schematic which could cause this
Anyone else come across this problem ?
I don't know this set's quirks well enough !
It is a truly superb radio though
Andy
yestertech is offline
Old 22nd Jun 2009, 1:02 pm   #2
Tom_I
Tom_I's Avatar
Default Re: yacht boy 209 - current 'leakage'
I think you must have a fault somewhere.
I've just checked my Yacht Boy 210, which is similar, and it's drawing about 22 mA on low volume, and nothing at all when switched off.
Tom
Tom_I is offline
Old 22nd Jun 2009, 1:25 pm   #3
OErjan_S
leaky capacitor?
something shorting the circuit?
OErjan_S is offline
Old 22nd Jun 2009, 1:30 pm   #4
yestertech
yestertech's Avatar
Thanks folks
I can't see anything which is in circuit with the power "off" hence the puzzle. It would also seem that when 'on' the current drain is excessive also ....HO HUM
....and yet it works brilliantly
Andy
Old 22nd Jun 2009, 2:02 pm   #5
Darren-UK
Try disconnecting the dial lamp switch and then measuring the current, with the radio on and off. It sounds like a permanent s/c exists at or near that switch, probably caused by something as simple as a stray strand of wire or even a tiny blob of solder that's been rattling around inside the radio.
Darren-UK is offline
Old 22nd Jun 2009, 2:14 pm   #6
paulsherwin
paulsherwin's Avatar
I agree with everybody else, 100mA is far too much for normal operation. I would guess that something is drawing 65mA all the time, even when the set is switched off. Have you done a simple resistance test across the battery terminals with the set switched off?
Paul
paulsherwin is offline
Old 22nd Jun 2009, 3:44 pm   #7
Steve_P
Steve_P's Avatar
Clean and examine the circuit board (PCB) and the push button switch.
There's some sort of external power adaptor too - I can't read German! - look here too.
It can't be much.
Cheers,
Steve P.
Steve_P is offline
Old 22nd Jun 2009, 4:09 pm   #8
yestertech
yestertech's Avatar
Doh !! I've just realised - when the external PSU connection is used
( aka PP9 ) it permanently powers the scale lamp. Wally !
That'll teach me to test it from the rear !!
So my actual low volume current drain is the difference between the two readings, ie about 35ma
I will have to uncase it ( ho hum ) and measure the current drain from the holder assembly for the D cells with the set switched off.
I'll also check the OP stage quiescent adjustment, which I've had no cause to touch.
Maybe I just got a bad bacth of D's
Andy
Old 22nd Jun 2009, 4:44 pm   #9
russell_w_b
russell_w_b's Avatar
Andy
If you get yourself a sliver of double-sided copper-clad PCB about 1/2-Inch wide by whatever long and solder a wire to each side connected to your metimulter, you can measure current-drain simply by pushing the PCB between the +VE terminal of one cell and the -VE terminal of the adjacent one.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 22nd Jun 2009, 4:51 pm   #10
Tom_I
Tom_I's Avatar
It's dead easy with these Grundigs. Turn the set upside down and remove the battery cover. Then just connect your meter between the two exposed battery ends.
Tom_I is offline
Old 22nd Jun 2009, 5:19 pm   #11
paulsherwin
The quiescent current is probably about right if the set is drawing about 35mA at low volume. It was out by a factor of 10 on my Yachtie - presumably some assembly technician in Portugal had had his meter set to the wrong range, and quality control didn't pick it up. It was great for battery life but not so good for crossover distortion
Paul
Old 22nd Jun 2009, 5:45 pm   #12
yestertech
yestertech's Avatar
Very clever ! I wish I'd thought of it ! A.
