14th Jun 2009, 10:29 pm | #1 |
Ekco/Ford CR280 car radio questions
Flushed with success following the TV22 I dug out an old valve car radio given to me about 25 years ago. Now I knew this did work as I powered it up about 23 years ago, not knowing that the capacitors needed checking. It ran but some of the caps were starting to get warm so I turned it off and put it away thinking I’ll fix it out of some time later. Today I opened it up, applied 200v to the HT rail, with the heater supply disconnected and there was approx 62v on the output valve grid. That cap was replaced and I opened up the PSU to be greeted by a waxy and a Hunts cap, both of which were replaced.
I powered it up, remembering it was positive earth, and when the heaters had warmed up, the buzzing of the vibrator could be heard in the speaker with a faint station in the background. The PSU cover was then refitted and the resulting lack of interference showed how good the PSU screening is. I could then hear the stations on Long and Medium wave. The vibrator was also causing a lot of audible noise, which wasn’t helped by resting it on the bench acting as a resonator. So it now works and needs a bit of tidying up but I have a couple of questions. It is an Ekco CR280 but is labelled as a Ford CR280 so presumably was offered as a Ford accessory. The questions are, what is the significance of the name "EnFo" on the front panel and what year was it introduced? Keith |
14th Jun 2009, 11:01 pm | #2 |
Re: Ekco/Ford CR280 car radio questions
Hi Keith,
"Enfo" was a name used on many accessories even I think for the antifreeze and touch up paint supplied to the customer via their dealers for Fords definately in the 1950s. Cheers, Des.
www.freewebs.com/405tv |
14th Jun 2009, 11:10 pm | #3 |
Hi Keith,
En-Fo seems to be nothing more complicated than "English Ford" |
15th Jun 2009, 7:19 am | #4 |
Keith as Bill says above ENFO is simply english ford..another one you may come accross is FoMoCo simply Ford Motor company!
Dave G1AGK. My perception is my reality! |
15th Jun 2009, 12:43 pm | #5 |
Thanks all
I'm familiar with the FoMoCo, having owned 3 Fords in the past. I guess the EnFo must date from the 50s. I don't know if Ford sourced their radios from different sources or relied on Ekco exclusively. In the early 80s the Fiesta I had was fitted with a Philips radio cassette but badged as a Ford RST21P unit. The original unit was faulty from new and was replaced by another similar unit which also went faulty and was replaced by a Blaupunkt unit still under the same Ford designation. Somehow I don't think this CR280 will fit in my current car but it does have Long Wave which the current radio doesn't have. I'd still like to know a date for this radio as there is no date in the service data. My guess would be mid 50s as it uses B8A valves and a vibrator PSU. Keith |
15th Jun 2009, 1:47 pm | #6 |
15th Jun 2009, 7:49 pm | #7 |
Checked this out with my father ....he worked as a tool maker at the Dagenham Ford factory for a number of years in the 60s. He recalls his Aunt who was a workshop floor manager at the EKCO factory for over 40 yrs telling him that they made the radios exclusively for Ford @ Dagenham during the late 40's-50's. They where an aftermarket option or accessory to be supplied as an optional extra as very few motors had radios as standard.
Obviously they where badged up as FORD units to disguise the fact that they where EKCO units much as is discussed above with modern day units. |
15th Jun 2009, 8:57 pm | #8 |
The R&TVS index in Jim Beacon's site shows the CR280 as being in the 1957-58 volume. This is presumably at the start of production.
