13th Apr 2009, 1:12 pm | #1 |
LEAK TL12 PLUS Problem
Help!
I have a pair of TL12+ amplifiers. These have had all the resistors/caps replaced by someone. One of these amplifiers works perfectly, but the other one "motorboats" at about 20Hz, apart from this it works OK. The motorboating starts after a fairly high level signal is input and remains when the signal is removed. All voltages are correct and the valves have been swopped between the amplifiers and all resistors & caps. check OK. The only way to stop the problem is to change the load and jumper to 4 ohms or to reduce the feedback by doubling the value of the feedback resistor, which in turn gives a natural increase in gain and distortion. This is driving me nuts! am I missing something? Any ideas are welcome Trevor |
13th Apr 2009, 1:29 pm | #2 |
Re: LEAK TL12 PLUS Problem
Is the output transformer original and the right version? Did you replace the reservoir caps?
13th Apr 2009, 2:24 pm | #3 |
What are the values of the bypass capacitors on the cathode resistors of the EL84s? If they are too high this can cause motor-boating.
13th Apr 2009, 3:14 pm | #4 |
When in the "boating mode" try the effect of a parallel C of 10 microfarads or more across the 8 and/or 16 microfarad HT filter caps.
If this does not cure it, check the earthing at the filter capacitors. Remove and clean the solder tag and chassis connection. R |
13th Apr 2009, 3:42 pm | #5 |
Ok, thanks for the replies, it's fixed, a leaky coupling cap on the EF86.
This was a brand new one fitted by me, this must have been the one in a million that failed in the MTBF tests, from now on I will check the new ones too if I have this kind of problem! Trevor |
