15th Dec 2011, 6:18 pm | #1 |
GP P8000 eprom programmer instructions ?
I know this is a long shot but I just wondered if anyone knows where I could buy or borrow a user manual for a GP P8000 eprom programmer ? this does cope with some of the older 2708 eproms that use multi supply rail voltages. the label on the back says GP industrial electronics plymouth. |
23rd Apr 2012, 10:11 pm | #2 |
Re: GP P8000 eprom programmer instructions ?
hi dragonser,
I'm looking also for manual or anythig about the GP P8000 Programmer. Hardly find any informations about it. Have you had any reply since? |
28th Apr 2012, 12:44 pm | #3 |
Hi, I'm still looking for any info I'm afraid...
regards Peter |
29th Apr 2012, 1:41 pm | #4 |
Hi - following googling around, found here:-
http://www.telford-electronics.co.uk/manual.php?alpha=S under STAG, a P8000 eprom programmer instruction manual. Wondered if it was what you are looking for. Good Luck - Mike |
2nd May 2012, 10:00 am | #5 |
Hi, I think the Stag P8000 is different from the GP instruments one.
regards Peter |
9th May 2012, 1:11 pm | #6 |
Hello Dragonser
I have an Instruction Manual for a EP8000 EPROM Programmer and Emulator. This uses the same case as your unit, but has a keypad in place of the eight ZIF sockets and is designed to write code and program EPROM’s, from 2704 to 2764 of various types and 27128 using an adaptor. It also has a printer interface, RS232 and cassette recorder input and output and a VDU output. If any of this information would be of any help I can scan it for you, but it may take some time as the original manual is in poor condition. Regards Stan.
Junk accumulates to fill the space available. |
11th May 2012, 2:18 pm | #7 |
Hello Dragonser
I have found a four-page colour brochure on the P8000 Production EPROM Programmer, which lists the devices, supported, features, menu selection, operating modes and specifications with block, flow diagram. Have a look at this information, compare it to the brochure on the EP8000, and see if the information on the EP8000 will be of any use. Please see attached PDF copies of the brochures and let me know what you think and I will scan the manual for the EP8000 later. Regards Stan.
12th May 2012, 7:52 am | #8 |
Hi Stan,
that is wonderful, many thanks. regards Peter |
12th May 2012, 1:34 pm | #9 |
Hello Peter
Please find attached a PDF copy of the instruction manual for the GP EP8000 EPROM Programmer Emulator, in two parts. The input and outputs on the EP8000 seem to be the same as the bulk programmer P8000. At the end of part two there is an appendix containing details of the options available and the last page is a “Crib Sheet” to use the EP8000 to copy an EPROM from a master copy and check the results. I hope this information will be of some use to you. Regards Stan.
31st Jan 2016, 3:12 pm | #10 |
A bit of a *bump* I know, but since this is a main search result for GP P8000 programmer, here is a link to the manual you all have being looking for, courtesy of Mr. Benoit
http://matthieu.benoit.free.fr/GP_In..._resources.htm The P8000 manual is towards the bottom of the page: http://matthieu.benoit.free.fr/pdf/p8000man.pdf |
