Old 12th Oct 2019, 4:04 am   #1
Synchrodyne
Default Why Both EAA91 and EB91?
This thread is a spinoff from the thread Valve Items - Philips/Mullard Rimlock-to-Noval Transition https://www.vintage-radio.net/forum/...d.php?t=159120, wherein the question arose – why were both the EAA91 and EB91 issued, when they appear to be functionally quite similar?
A first pass look at the easily accessible data does not produce a definitive answer.
As a starting point, what were probably the final Philips datasheet issues for these valves were dated respectively 1999 June 12 for the EAA91 and 1999 June 14 for the EB91.
That for the EB91 is quite brief. No quantitative performance data was provided, simply the note “For further data refer to type EAA91.”
From those datasheets, the only discernible difference between the two was a dimensional one. The overall height (top pip to pin ends) of the EAA91 was shown as 44.5 mm maximum whereas that for the EB91 was 54 mm maximum. In that the EB91 referred back to the EAA91, Philips may have viewed the latter as the primary type.
An earlier reference is the Philips Australia 1962 Technical Data Book. This provides a tabular listing of a very wide range of valves (including the Innoval types not mentioned in Philips Netherlands sources.) Both the EAA91 and EB91 were listed, and in both cases with the comment “For data and notes refer type 6AL5”. (No dimensional data was provided in this case.)
At this stage one could say that in later years at least he EAA91 and EB91 were functionally the same valve, differing only in overall length. Whether that difference was deliberate or happenstance is unknown.
Earlier still was a Philips (international) data pocket book, apparently from 1954. This appeared to cover most of the Philips range, including miniatures, Rimlocks and novals, although not all of the Australian Innovals were listed. The apparent date of 1954 seems about right. For example the EF89 (thought to date from c.1954) was included but the EBF89 (thought to date from c.1955) was not. The double diodes listed were the listed the EAA91, EB91 and 6AL5, as well as the EB41 and UB41. Each had its own brief dataset (no physical dimensions) except for the 6AL5, for which it was said “see EAA91”. Furthermore, the EAA91 was the only double diode in the “preferred types” summary at the front of the book. That could have been a change of position by Philips, as the double diode in the TV series, as delineated in Book IIIC, was the EB91.
The 6AL5 was the standard double diode in the American miniature series. It had been introduced as a WWII valve by RCA in 1944. It was found that the 6J6 miniature double triode (dating from 1942) was being used in the triode-strapped mode where a high-perveance diode was required for wideband demodulation. Thus RCA developed a high-perveance double diode with performance characteristics very similar to that of the triode-strapped 6J6.
The 6AL5 became a part of the initial American B7G-based AC miniature receiving valve range in 1945, one of its recommended applications being as an FM receiver demodulator. The 12AL5 derivative, with 150 mA heater making it suitable for use in AC-DC radio receivers with 150 mA series-string heaters was added in 1947. Then the 3AL5, with 600 mA controlled warm-up time heater was added in 1954 for use in TV receivers with series-string heaters. The overall height of the 6AL5 & co. was 1.75 inches maximum, that is 44.5 mm. That was the same as for the EAA91.
From that one might deduce that the EAA91 was simply the European version of the 6AL5, with the EB91 being an electrically similar but physically different (for some reason) variant. But it does appear that the EB91 preceded the EAA91.
The EB91 was included in the 1949 Mullard publication “Valves for Industry and Communications”. So it was in place at least by 1949. The same publication also included the EB41 and UB41 Rimlock double diodes. The EB91 had a maximum height of 55 mm, and the EB41 and UB41 57 mm.
Whilst the exact release dates for the EB41 and UB41 are unknown, the double diode suitable for FM and TV purposes was certainly within the scope of the original Rimlock receiving valve range as discussed in Philips Technical Review 1946 October. Evidently Philips saw these as its principal post-WWII receiving double diode types. However, in 1949-50, when it decided to adopt the noval base for most of its standard TV receiving valves, it did not develop a noval double diode, but rather took the existing EB91 into its TV range. Whether Philips itself had previously offered the EB91 is unknown; perhaps it was drawn from the Mullard range.
One may then ask, why did Mullard (by 1949) offer both the EF41 and EF91, which were very similar in performance characteristics. A possible answer may be found in the Wireless World 1947 November report on the valves shown at that year’s Radiolympia. In respect of Mullard it was said: “Miniature all-glass valves shown by Mullard are mainly for use in industrial equipment. There were a few samples of the valves that will eventually be produced for domestic receivers, with the small B8A pin arrangement.” (The associated picture included both the EF42 (B8A) and EF91 (B7G) high-slope pentodes, another duality that has been covered in the recent thread EF91 to EF80, https://www.vintage-radio.net/forum/...d.php?t=157399.) In 1947 the term “miniature” was mostly used for the B7G types, the Rimlocks being identified as such or as B8A.
Thus Mullard probably saw it as necessary that its B7G industrial range should include a double diode, hence the EB91. The competitive situation may also have indicated this. Osram had opted for the B7G base for both industrial and domestic applications, and its double diode was the D77, part of its “77” range. Mazda, whilst a strong proponent of the Rimlock base, had nevertheless offered a small number of B7G valves for industrial applications, including the 6F12 high-slope pentode and the 6D2 double diode. That latter also doubled as its domestic double diode; unlike Philips/Mullard, it did not release a Rimlock version.
The D77 and 6D2 both had properties that were more-or-less the same as those of the 6AL5. According to a 1948 May datasheet, the 6D2 had a maximum height of 54 mm, the same as was later specified for the EB91. The D77 had a maximum height of 49 to 55 mm, according to a 1951 October datasheet. Brimar’s offering in this class was, unsurprisingly, the 6AL5 itself. Brimar Manual #7 gave the height of its 6AL5 as 1.875 inches maximum, 47.6 mm, different to that of the original American 6AL5.
The EAA91 appears to date from 1951. Perhaps it was intended to be an exact match, both electrically and physically, for the (American) 6AL5.
A Mazda datasheet dated 1961 December showed its miniature double diode as being the 6D2/EB91, with 54 mm maximum overall height.
A Mazda Belvu datasheet dated 1968 January had what it called the 6AL5/EB91 with a 45.24 mm maximum height
A 1956 GEC summary leaflet listed its double diode as the D77/6AL5, no physical dimensions given.
Condensing the foregoing, we can say:
The 6AL5, EB91 and EAA91, released in that order, were functionally the same valve. So were the Mazda 6D2 and Osram D77 functionally the same as these three.
The original American 6AL5 had a maximum height of 44.5 mm, but some European issues were taller.
The original EB91 was taller, up to 55 mm, but some later issues were shorter.
The EAA91 appears to have conformed to the original 6AL5 physical specification.
But that still does not produce a “hard” answer as to why both the EAA91 and EB91 were necessary. One could say that the “short” version might have been needed for some compact equipment that had been designed around its dimensions, and in which the “tall” version would not fit. But that just moves the unanswered question to :why was the (functionally identical) taller version developed in the first place?
Cheers,
Synchrodyne is offline
Old 12th Oct 2019, 10:06 am   #2
paulsherwin
paulsherwin's Avatar
Default Re: Why Both EAA91 and EB91?
The EB91 was by far the commonest version around here. I don't think I've ever seen an EAA91. As you say, it's puzzling that both were produced, especially as the market for the EAA91 appears to have been tiny, whatever it was.
paulsherwin is online now
Old 12th Oct 2019, 10:11 am   #3
G6Tanuki
G6Tanuki's Avatar
I wonder if there might have been some more-prosaic production-line-related drivers for these sorts of things, something like "we need to increase our diode-production! We don't want to build another production-line for B8A as the world's not really embraced the idea, and we've got spare capacity on the B7G lines".
G6Tanuki is offline
Old 12th Oct 2019, 10:39 am   #4
G8HQP Dave
Maybe the taller version allowed use of the same envelope as other B7G valves, which might ease both stock control and production line settings. However, set against this idea were other small envelope valves such as EF95/6AK5 and other 'UHF' valves.
Does the EAA91 have the electrodes set nearer the base, so shorter connections and better high frequency performance?
G8HQP Dave is offline
Old 12th Oct 2019, 11:16 am   #5
jjl
jjl's Avatar
The Grundig 5080 that I used to own featured an EAA91 and this was specified as such on the valve lineup printed on the back panel. Being a typical tall, imposing '50s German set there would have been plenty of room for the taller EB91.
John
jjl is online now
Old 12th Oct 2019, 11:46 am   #6
paulsherwin
I wonder if there was some dispute within Philips regarding the naming of double diodes with separate cathodes. The diodes in the EB/EAA91 are completely separate structures.
The Germans did seem keener on EAA91s than anybody else.
Old 12th Oct 2019, 5:01 pm   #7
G8HQP Dave
I seem to recall that in my own stock of EB91/EAA91 and lookalikes the Russian ones are mostly small envelope versions.
Old 12th Oct 2019, 8:16 pm   #8
turretslug
turretslug's Avatar
Looking the other way, did Mullard/Philips act as early adopters of the "US format" EB91 with its taller, 6AL5-style envelope, whilst Telefunken et al continued with production/usage of the 0.2A heater EB41 in an environment where Rimlock had been popular and established for some years including in VHF/FM receivers? When Rimlock was finally pushed aside as B9a (particularly) became dominant, it might have seemed sensible to standardise on a B7g double diode, the short and recently introduced EAA91 looking favourable over the established EB91.
The postulation that the EB91 was introduced in its taller envelope simply on the grounds that it enabled common envelope processing and handling over a range of B7g types seems reasonable from the production engineering viewpoint, which of course raises the question- what was the point of the EAA91's appearance?
turretslug is offline
Old 13th Oct 2019, 12:21 am   #9
Synchrodyne
A reverse lookup on RMorg shows generally a higher application count for the EAA91 then the EB91 once the former became available. A cursory inspection suggests that the EAA91 was used by European setmakers, whereas the EB91 was used by UK setmakers.
Here is a postulate, or perhaps a “straw man” as to why things turned out the way they did, at least in terms of what Philips/Mullard did.
  1. Philips developed the EB41 (and UB41) as part of its new Rimlock receiving range. The EB41 essentially replicated the properties of the American 6AL5, but otherwise was built according to Rimlock precepts. As a result of this, or perhaps the result of limiting the number of height variants in the Rimlock range, it was somewhat taller than the 6AL5.
  2. Mullard at least, and perhaps other Philips branches required a double diode on the B7G base for industrial applications. Speculation, with as yet no supporting evidence; thus was developed the EB91, essentially the EB41 on a B7G base, and perhaps with Rimlock structural features inside. It came out somewhat longer than the 6AL5.
  3. In 1948-49 Philips decided to adopt the noval base in place of the Rimlock. This change had several facets, as follows:
    • a. New radio valves would be issued as novals, e.g. the EBF80.
    • b. As well as the EBF80, a few existing Rimlocks would immediately be reissued in noval form, and with American registrations and designations, for the Australian market, under the “Innoval” name.
    • c. A new range of noval TV valves would be issued, the EF80 and ECL80 being early examples.
  4. In connection with 3c, Philips decided that it was not appropriate to reissue the EB41 in noval form. Rather it took the existing EB91 into the new TV range as its standard double diode. Insofar as the B7G and B9A bases ran in parallel, with mixes thereof being acceptable to the setmakers, this was a logical move. The EB91 was also to displace the EB41 in radio applications.
  5. Purely speculative: from 3b, Philips would have needed an American designation for whatever double diode it chose to sell in Australia. AWV, I think the dominant Australian valve producer, and with a mainly RCA-derived range, had already made available the 6AL5. Philips might have obtained an American designation for the EB91, but saw offering the 6AL5 as such as being the better pathway in this case. The 6AL5 was physically at least not quite the same as the EB91, and for Philips manufacture, it needed a Pro-Electron designation, so EAA91 was chosen to differentiate it from the EB91.
  6. Still speculative, Philips Netherlands (and in Europe generally) may not have been heavily invested in the EB91, and so decided to make the EAA91 its standard double diode. That could explain why it was shown as the preferred type in the 1954 pocket book. De facto then, the EAA91 directly superseded the EB41 in European radio receivers.
  7. This is empirically supported: Mullard, already heavily invested in the EB91 as part of its industrial range, retained that variant as its standard double diode in the radio and TV receiving ranges as the Rimlocks faded out.
If there were any performance differences between the EAA91 and EB91 – and it does seem at least possible that there were - these have not been mentioned in any of the datasheets and literature that I have seen.
Cheers,
Old 13th Oct 2019, 12:49 pm   #10
Maarten
Are you sure those aren't the dates that Frank Philipse (a private person unrelated to the company), compiled those sheets?
Maarten is offline
Old 13th Oct 2019, 1:12 pm   #11
Radio Wrangler
Radio Wrangler's Avatar
I'd never even been aware of the EAA91 until this thread. EB91s have been breeding in my junk box for almost 60 years, however.
THe EAA91 number seems a bit silly when there's long history of suffix letters in valve designations to cover different bulb shapes.
Does the EAA91 do the bright heater flash on turn on in series string heater systems that I associate with the EB91?
Radio Wrangler is offline
Old 13th Oct 2019, 3:44 pm   #12
ionburn
ionburn's Avatar
I have some EB91 and EAA91. I regard them both as equivalent. My EAA91's are branded RFT whereas my EB91's are RST.
I just had a look at some curves I plotted a while ago which show similar characteristics.
ionburn is offline
Old 13th Oct 2019, 8:55 pm   #13
kalee20
They are, but that may be irrelevant. The EABC80 has 3 diodes, two are reasonably matched for FM discriminator use, the third is quite different for AM. The 'different' diode shares the same cathode as one of the matched diodes. I would argue that the 'B' diodes are the FM diodes and the 'A' diodes is the AM diode, even though it has a shared cathode with one of the 'B' diodes (and the 'C' triode).
Hopefully nobody has found evidence of an EAAAC80...
kalee20 is offline
Old 13th Oct 2019, 9:32 pm   #14
Synchrodyne
I think that thy are Philips’ own dates. I have attached the said datasheets, also that for the EB41.
In the usual Philips way, each page has its own data. I have taken the issue (or really reissue) date to be that of the final page.
The actual data in the EAA91 case dates from 1954, as does the limited data provided for the EB91. The “refer to the EAA91” statement also dates from 1954 June 06, so a reasonable inference is that by mid-1954, if not earlier, Philips viewed the EAA91 as being the parent type and the EB91 as a derivative. That aligns with the presentation in the 1954 Pocket Book. The EB41 data dates from 1952.
Cheers,
Old 13th Oct 2019, 9:54 pm   #15
Synchrodyne
Here is the section on the EB91 from Philips Technical Library Book IIIC, “Data and Circuits of Television Receiving Valves”. The English edition was published in 1953, although the book appears to have been based upon the (predominantly noval) range of TV valves introduced in 1950. Anyway, it is apparent that at that time, the EB91 was Philips’ preferred double diode type.
EB91 Philips Book IIIC 1953.pdf
The EB41 had been covered in Book IIIA, “Data and Circuits of Radio Receiver and Amplifying Valves; (Second supplement; Valves developed during the period 1949/50”. The English edition was published in 1952.
EB41 Philips Book IIIA 1952.pdf
As may be seen, the EB41 was also said to be suitable for FM and TV applications.
The Philips preferred double diode progression was thus:
EB41 (from c.1946)
EB91 (from 1950)
EAA91 (from 1954, if not earlier).
Mullard apparently stayed with the EB91, not moving on to the EAA91.
Cheers,
Old 13th Oct 2019, 10:01 pm   #16
G6Tanuki
G6Tanuki's Avatar
Thinking further on this: the B8-valves are only ever going to have been produced by a few European companies (so can best be disregarded in the greater scope of things).
Is there any evidence of world-market manufacturers [ITT/Brimar/Sylvania/RCA/Tung-Sol/GE/Hytron/Raytheon being examples] ever producing an EAA91?
Or there being military CV- or VT-numbers issued for it?
G6Tanuki is offline
Old 14th Oct 2019, 3:03 am   #17
Maarten
Clearly Frank Philipses artwork, that doesn't match what Philips would have used for a reissue in any way. Also, Philips Components wasn't involved in any other vacuum than picture tubes by that time and hadn't been for 20 years or so. The real Philips issue dates are those from the 1950's, FP (Frank Philipse) compiled the sheets at mentioned date in 1999.
However, for the research at hand, that isn't too relevant. I'm just trying to prevent urban legends from taking off.
Besides the dates on the pages, the dates and code numbers on the individual drawings might come in useful to establish the history of those valves. The drawing numbers (7R, 7Z etc.) would have been issued in order, just as the page numbers starting with 93. Only possible exception to that might be when a drawing was revised. 7R xxx xx could have been renumbered to 7R xxx xx.1 .2 .3 etc. I'm not sure whether Philips actually used that convention in this case or just issued a new drawing number.
From a quick look at the EAA91 datasheet, I'd say the EB91 was prepared for market in mid 1949 while the EAA91 was prepared in late 1954. This matches your findings.
Maarten is offline
Old 14th Oct 2019, 3:29 am   #18
Maarten
ITT probably did through its German subsidiary SEL, though it would be interesting to compare envelope size and system construction to the various other variants.
Also, Philips was a world market manufacturer. It would be interesting to find out what double diode, if any, they marketed (and possibly manufactured) in for example their South American national organisations. Even though their valves were shipped as unlabeled bulk goods from and to their own and 3rd party factories all over the world, some local markets would have seen more local production than others, especially if they had their own preferred types.
Maarten is offline
Old 14th Oct 2019, 3:52 am   #19
Synchrodyne
Thanks for the clarification. That kind of third party “mixing and matching” of and additions to datasheets does raise questions about the provenance of the data, although in this case I don’t think that it changes the basic picture.
The attached datasheets are extracted from Philips Electron Tubes Part 4 1972, and so apart from the extraction exercise, have not been tampered with as it were.
Philips Electron Tubes Part 4 197206 EAA91.pdf
Philips Electron Tubes Part 4 197206 EB91.pdf
The EAA91 was still the shorter version, and appears to have still been current in 1972. The EB91 was listed as “maintenance only”, and was referenced back to the EAA91 for detailed data.
More insight into the early 1950s chronology may be had from a couple of Philips valve pocket books.
The first of these is Philips Electronenbuizen Zakboekje of 1953. It listed miniature double diodes as EB41, EB91 and UB41, but not the EAA91. The EB91 was shown as the preferred type for 6.3-volt and 300 mA heater applications, with the UB41 the preferred type for 100 mA heaters:
Name:	Philips Electronenbuizen Zakboekje 1953 Preferred Types.jpg
The second is the 1954 Pocket Book mentioned upthread. This listed miniature double diodes EAA91, EB41, EB91 and UB41 with the EAA91 now shown as the preferred type for 6.3-volt and 300 mA heaters. (By then there was no preferred type shown for 100 mA heaters.)
Name:	Philips Electronic Tubes 1954 Preferred Types.jpg
That puts the change from the EB91 to the EAA91 as the primary miniature double diode as having occurred in the 1953-54 time period.
It still does not answer the question “why”. But the previous suggestion remains a good fit. That is, Philips decided that it needed a miniature double diode that was an exact performance and physical replica of the American/International 6AL5, and not simply a performance match. The Australian market requirement may well have been the prompt for that, and once done it was logical that the EAA91, identical to the 6AL5, was made the preferred type, displacing the EB91 from its short reign in that role in most of the Philips world, with the UK being an exception.
Cheers,
Old 14th Oct 2019, 5:17 am   #20
Radio Wrangler
The odd nomenclature suggests two possibilities:
1) EAA was chosen before 'B' was defined in the pro-electron world. This is immediately shot down by the earlier EB41.
2) They already had the EB91, and had created a second version with the same electrical characteristics but a different envelope. Now the numerical part of a pro-electron number (you know what I mean!) is supposed to be chronological in order of issue. So the new thing could have been EB92 without straining the nomenclature system.
So the part wasn't a 100% form, fit, and functional replacement and therefore needed a different name. So the question becomes why they wanted so much to stick with the '91' digits that they mucked around with the 'B'?
We tend to think in terms of the consumer market. The AM radio designs went for combined bottles with detector diodes included with a triode or pentode. The FM radio designs needed a pair of diodes without common cathode connection. So 6AL5 in the states, and its equivalent over here. The valve was at a high signal level so screening wasn't necessary and so either size envelope could be used. There would be nothing to make the larger part not fit. Same for tellies.
But those aren't the only uses for double diodes. They turned up in RF, military and industrial stuff where sometimes exact mechanical size was critical... such as inside RF test probes. Also the height was important where location devices were used to keep valves in their sockets under vibration.
Designers of military gear would want multiple sources for their parts. Nato would have gone for 6AL5 but would have disqualified EB91 on fit grounds as any sort of equivalent. This sounds the most likely reason to me for Philips doing another version of their double diode. Money is involved. Maybe Philips had had their consumer radio/TV goggles on when they did the EB91 and used a glass envelope size they already had tooled-up for something else (maybe even a something else that never made it to production) but by doing so they blew its chances as a 6AL5 true equivalent. After a sound kicking from their accountants, they set out to right this missed opportunity.
This seems plausible but still leaves the mystery of why they felt so attached to the '91' digits. Pride, perhaps?
