21st Jan 2016, 4:12 pm | #21 |
Re: Apple 2 Europlus Power Supply
I can refubish the drives for you if needed
33, 45, 78, around and around they go...
23rd Jan 2016, 4:29 pm | #22 |
Well - feeling a little stupid now! Turned out the power lead I was using had a blown fuse! Just tried a new lead, and the computer fired up straightaway. I just need to refit it in the case, then I can try out the floppy disks and start thinking about repairing the monitor (which has a cracked case, but otherwise is untested).
Many thanks for the help and advice - next time though, I should probably check the fuse first rather than last!!! |
24th Jan 2016, 11:54 am | #23 |
Well, at least the capacitors will last for a while now
Glad to hear it's working. |
24th Jan 2016, 12:16 pm | #24 |
Don't beat yourself up about it. Nine out of ten users of this forum have made exactly the same mistake, and the tenth one is probably telling spare ribs
24th Jan 2016, 12:57 pm | #25 |
Lovely, well done!
Yes, been there, done that too. My latest time being promising to look at my parents' Beocenter which hard died over a year ago. I exchanged e-mails with our resident B&O expert, got the PDF, dragged the unit onto the bench... then found I'd fitted a ridiculous fuse (1A) in the mains plug, which had blown after a few months of switch-on surges (my parents like to switch off at the wall at bedtime). Fitting a 3A one has sorted it and took 20 seconds. |
24th Jan 2016, 2:18 pm | #26 |
Solid state audio gear mostly has a very substantial switchon surge as the PSU electrolytics charge up. It can be a revelation to power up via a lamp limiter and watch the bulb flash white.
24th Jan 2016, 2:21 pm | #27 |
Yes, and this one has a HUGE mains tx. But back to the Apple...
24th Jan 2016, 2:37 pm | #28 |
I think that's been eaten, now
29th Jan 2016, 10:45 am | #29 |
And finished!
The disk drives just plugged in and worked with no issues whatsoever. The monitor was in poor condition with a badly damaged case, but with plentifull superglue and bostik plus some re-soldering around stressed parts, it fired up without a problem. Now just need to re-learn some basic commands to actually get to use the thing! I shall also need to keep an eye on eBay for any software or expansion cards. Thanks again for the advice - I'll bear it mind for the next time (after checking fuses of course)! |
