Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
2nd Apr 2006, 6:39 pm | #1 |
Standards conversion - the Third Way!
It's possible to use a video scaler, of the type used to scale up standard TV to HD format, as a standards converter. I have a DVDO iScan HD+, and this will allow all output timing parameters to be altered and saved to a user setup. Unfortunately it will not quite go as far down as 405/50/2:1 (or 378i to use the modern designation), but it will certainly do 819/50/2:1 (786i). Absolutely no hardware modifications are required to get a mono output. I managed to display the result on a Bush TV135R, set to 625 with the line hold suitably tweaked. The only snag I found is that the Bush (and I suspect most 625 or 405 sets) would not accept the 819 standard's solitary field sync pulse, so I had to add more field syncs, similar to 405.
The quality of the scaling and interpolation is as you would expect, extremely high, partly because the scaler converts the input to progressive scan before scaling it. The other standard I tried, which works very well indeed, is 405 progressive (405/50/1:1 or 378p). This will also display on the TV135R. I guess it would be possible to use this as the input to a very stripped down standards converter that would just convert it to interlaced, while retaining the high quality scaling. Of course these scalers are expensive - I would not suggest buying one just for this. But for those of us that already have one, an interesting experiment! |
2nd Apr 2006, 7:13 pm | #2 |
Re: Standards conversion - the Third Way!
This is, in effect, what I'm doing - the Linux software my system is based on was developed as a free open-source software-based alternative to expensive video scalers. Modern PCs are powerful enough to do real-time video scaling rather well, these days; with the right software and a decent operating system. So you can watch DVD or off-air TV etc at any resolution you can get out of a graphics card; and with Linux you've always been able to "get your hands dirty" and play around with the video timings, resolution, etc. to a very fine degree. So, while it was developed by and for those using large high-resolution displays for home theatre systems; I worked out that with an nVidia GeForce4 card (possibly other cards, too) it's possible to get near spot-on 405-line timings, interlaced as well, out of it. (As the lowest dot-clock for the card is a touch high it comes out as 968 x 377 interlaced - the software doesn't mind this odd resolution and scales perfectly anyway.) And when I get around to running through the maths again 441, 819 and quite a few other standards ought to be possible; I just haven't worked it out yet Results should be good; just as with the video scaler this system de-interlaces any incoming interlaced signal you're feeding it (composite video or analogue terrestrial from a 'framegrabber' card) - and with streamed video, DVD and digital TV it's not acting as a standard converter as such. The source being inside the PC, it takes the digital video data directly, scales it, then outputs this directly at 405-lines; there's no intermediate stage where analogue 625-line video needs to be processed. Regards, Kat Last edited by Kat Manton; 2nd Apr 2006 at 7:25 pm. |
2nd Apr 2006, 7:41 pm | #3 | |
Or am I getting confused and you're producing what would be "810-line" if it was interlaced? Regards, Kat |
2nd Apr 2006, 8:41 pm | #4 | |
I'm sure the performance of PC-based scaling is now very good, but I suspect dedicated hardware can still beat it. Obviously the difference won't matter much when the output is 405 - the more you are scaling down, the easier it gets, which is why my existing converter using 4 lines from 1 field looks subjectively very good. When converting up to HD it's not so easy - the DVDO for example uses a 4-field aperture (they don't say how many lines per field) for de-interlacing. That's an awful lot of Mips... |
2nd Apr 2006, 9:20 pm | #5 | |
http://www.rezzer.tv/ The engine is a Gennum part: - http://www.gennum.com/ip/gf9320.html As you say though, it's pricey at around £60 - then you need RAM around it and a processor to load the registers (a small PIC type would do the job for a simple application - the 9320 is serially controlled. A fixed conversion from 625 to 405 should present no problems. Seems a bit of a sledgehammer to crack a nut with though.
Chris Last edited by evingar; 2nd Apr 2006 at 9:31 pm. |
3rd Apr 2006, 1:07 am | #6 |
I think you need to be careful with deinterlacing of the image. Interlacing was originally done as a way to achieve a 2:1 bandwidth reduction while still retaining an 'effective' 50 frame/second image. By deinterlacing you present a 25 frame per second image to the television, not a 50 field per second image, so motion will look very choppy and unnatural. Usually when deinterlacing is performed, it is done to a progressive monitor that can handle the full frame rate, 50 frames/second in this case. For interlaced televisions, the signal should remain interlaced for the best motion reproduction. |
3rd Apr 2006, 10:28 am | #7 | |
It is true that most de-interlacers have a mode where the output motion is at 25Hz, but this is only used where the source is known to be film rather than video. |
3rd Apr 2006, 10:32 am | #8 | |
3rd Apr 2006, 10:41 am | #9 |
Hi, I agree with Darryl.
I watched a HDTV picture from a satellite HDTV set top box on a Sony and a Panasonic high quality flat screen TV. And the picture is still choppy. I think in the future all sources are choppy. This is a problem. Kind regards Darius |
3rd Apr 2006, 10:46 am | #10 | |
The de-interlacing chip in the DVDO is made by Silicon Image. The combination of the DVDO with the Sony gives the best SD pictures I have ever seen - and I include Grade 1 studio monitors in that comparison. No line structure, no flicker, no motion artifacts, and subjectively higher resolution due to a reduction in the Kell factor! |
3rd Apr 2006, 10:54 am | #11 | |
3rd Apr 2006, 11:32 am | #12 |
Conclusion for me: If there is an analogue way I'll take it.
3rd Apr 2006, 5:53 pm | #13 | |
Location: CH3, Blaen Plwyf Transmitter, Aberystwyth, WALES
It seems as if there is a gradual shift away from the old interlace technique, PCs and Mac don't use it now, TV is starting to move away from it. I seem to remember a mechanical 3:1 interlace system mentioned on this forum not that long ago, must have been a nightmare televising football with it!! Going back to scalers as converters, good idea but the cheapest I have found new I think is from Keene Electrical at about £160. Or risk fleabay. Cheers Tim |
3rd Apr 2006, 7:20 pm | #14 | |||
This is the direction a lot of industries are heading; processing power is relatively cheap and getting cheaper; and software is more flexible than dedicated hardware... Once you've designed a device and committed it to silicon you're stuck with it; unless you stick a CPU core on the die along with some reprogrammable memory. (In which case the 'software' becomes 'firmware' but that's just semantics, it's still a processor running software and it can be reprogrammed.) Quote:
Regards, Kat |
3rd Apr 2006, 7:52 pm | #15 |
The problem with running a progressive 25 frame/sec image to an interlaced monitor is your eye is only seeing 25 images per second, not 50 images per second as with true interlaced video so motion will never be as smooth. It really doesn't matter how good the deinterlacer is in this situation. The deinterlacer is critical when converting an interlaced image for display on a progressive monitor. Then how much information the deinterlacer takes into account from adjacent frames becomes critical.
An easy way to see this is to view filmed material that was simply sped up to 25fps (not half fields inserted as some systems do), and then compare to true interlaced video, like that from a live sports feed, and the difference is fairly extreme. Progressive video at twice the frame rate of interlaced video is far superior to interlaced, and has none of the flicker effects on stationary images, with all the same motion information, which is why computers and digital television have gone this way. Interlacing was an extremely cleaver way to reduce bandwidth while keeping the apparent frame rate up at 50 in the early analog days. David, you mentioned how producers seem to like the "film effect" when shooting video. I've had the unfortunate experience of dealing with Hollywood for the last 6 years for both episodic television and theatrical film, and there is a definite tendency to believe "film just looks better". You'll get all sorts of reasons why they believe this is true, but I think it is mostly due to familiarity. If television had come along first, I really think these guys would be trying to achieve that "electronic effect" for their films because it just looks better ;-) Darryl |
3rd Apr 2006, 8:41 pm | #16 | |
As someone from a hardware background, I still back hardware solutions over software solutions running on a standard platform for simple single use applications. Cheap desktop PC's are "messy" with their monitors, keyboards and mice, “lappys” are neater but more expensive - WRT either type, I personally can’t be fagged waiting for them to boot up, "fart about", do a disk check etc etc. I understand what you say about dedicated software, but you are always going to have to run an operating system kernel, and this gives fundamental problems irrespective of the power of the machine. We provide service for 2 kind of machine at work, a Doremi server based on bespoke hardware and a simple time delay server based on standard PC hardware running a Linux kernel and dedicated software. You would not ***believe*** the problems we have had with the latter in areas of dirty power etc – it’s just not as robust as the dedicated hardware solution! This is in no way a reflection of what you have achieved with your PC standards converter - which IMHO is nothing short of miraculous, but a neat tiny standards converter takes no time to boot up, takes minimal power, does not have a noisy fan and does not "crash”, take aeons to boot, corrupt its hard drive, do disk check etc etc every time the power dips. A dedicated hardware solution is preferable in my eyes for my particular situation - even if ultimately it does cost more (I have a Pineapple standards converter which I am very pleased with).
Chris |
3rd Apr 2006, 8:46 pm | #17 | |
3rd Apr 2006, 9:04 pm | #18 | |
Interesting you saying this, so this would mean that modern new such as 720p at 25fps are not a smooth even on native progressive plasma/LCD displays as old fashioned 2:1 interlace video? So the source video format is the crucial factor rather than the processing afterwards. In that case why go 720p at 25fps, or does just look jerky on CRT displays which will soon be out of date anyway? Cheers Tim |
3rd Apr 2006, 9:26 pm | #19 |
Hi Chris,
I fully understand; though I'll add a few points: Yes, my PC system takes a while to boot. But: (Once it's all sorted out, anyway)
My target audience I guess is really those who have an older PC lying around, necessarily still half-decent spec (possibly around 1GHz; I need to investigate system requirements properly and finalise a minimum spec.) It's the sort of system that can be had cheaply enough; I've had three machines around the right spec given to me by people who've upgraded. But, once it's polished and tidied up, you just turn it on, (yes, and wait for it to boot)[2], then sit back and play DVD, watch televison etc. all controlled from an IR remote with on-screen display on the 405-line TV. Ease-of-use is a priority for me with this project. Regards, Kat. |
3rd Apr 2006, 9:35 pm | #20 | |
Interlace was a great video compression system in its day. Unfortunately it's now a curse. It is not possible to achieve perfect de-interlace of all pictures simply because it is not possible to distinguish between some vertical detail and certain movement. Some de-interlacers are very good indeed, others are not. The Pineapple standards converter had a frame mode which interpolated between the interlaced pair of fields. Superb on still pictures and revolting when anything moved. In practice you always used the field mode. Last edited by ppppenguin; 3rd Apr 2006 at 9:40 pm. |
