Old 11th Feb 2007, 3:50 pm   #1
milairuk
Default Dual outputs from one transformer secondary ??
I want to have two switched HT outputs, both individually selectable high/low, but want to use only one transformer. Given that the current rating would be split between the two rails, would the attached circuit work or am I missing something? Voltages given are just notional at this time.
Ideas / comments invited
milairuk is offline
Old 11th Feb 2007, 4:39 pm   #2
oldeurope
oldeurope's Avatar
Question Re: Dual outputs from one transformer secondary ??
if one output is switched high, the other one will be high too !?!
Kind regards,
Darius
oldeurope is offline
Old 11th Feb 2007, 4:42 pm   #3
milairuk
Default Re: Dual outputs from one transformer secondary ??
Originally Posted by oldeurope View Post
Kind regards,
Darius
Sorry I may not have decsribed this well - The switches are not ganged, SW1 & SW2 are seperately selected, so HT1 can be set to 350v, whilst HT2 can be set for 250v, Or the opposite, or both at 350v or both at 250v.
milairuk is offline
Old 11th Feb 2007, 5:00 pm   #4
oldeurope
oldeurope's Avatar
Smile Re: Dual outputs from one transformer secondary ??
you described this well. If SW1 is switched to 350V and SW2 is switched to 250V both will be 350V. I am sure (at the moment, hi hi).
Darius
Old 11th Feb 2007, 5:34 pm   #5
Ed_Dinning
Hi , the common ground connection will give problems. You would be better using simple 1/2 wave rectification and larger caps. Then switch your "outputs" to the desired supply. Note that you may need substantial switches as it will be DC.
Ed
Ed_Dinning is offline
Old 11th Feb 2007, 7:32 pm   #6
milairuk
Ed
Thanks Ed, I had a feeling that the common ground would cause a problem. Your suggestion is so damned obvious. Sometimes ideas get overcomplicated
I'm not too worried about ripple as the solid state regulators will give 60dB rejection on their own.
John
milairuk is offline
