13th Dec 2018, 1:42 pm | #1 |
Philips radiogram.
Hi
Does any one know whis part is missing on the arm on the record player ( type nr. ) see pictures. |
13th Dec 2018, 3:12 pm | #2 |
Re: Philips radiogram.
I can't see clearly enough to see if the (Mono only) LP/78 stylus is missing. Is that what you meant in your question?
Edward. |
13th Dec 2018, 5:29 pm | #3 |
14th Dec 2018, 11:04 am | #4 |
14th Dec 2018, 12:16 pm | #5 |
Before spending money on a stylus I'd test the cartridge first by gently rubbing the little rubber fingers while the amplifier is on. You should hear a bigger version of the same noise through the speaker, but the chances are you won't. I've not seen one of these cartridges that still works for many years.
14th Dec 2018, 12:44 pm | #6 |
I'd also test the amplifier. The whole cartridge assembly can be pulled off the end of the arm. Remove it and then touch the contacts at the end of the arm. You should hear a buzzing noise from the speaker.
15th Dec 2018, 12:01 am | #7 |
Waaay back when I was about ten years old a neighbour gave me this exact gram (non-working). I recall it came with two mono pickup heads, one for shellac one for vinyl. I didn't manage to get it working as at that tender age I didn't know about the rochelle salt goo!
I recall there was a little' shelf' inside the compartment for the head not in use. The rocker head you have I think was a slightly later replacement. I still have one of those two heads, just waiting for the day I come across a AG1006 deck to repair and use it on!
Regards, Ben. |
15th Dec 2018, 12:57 am | #8 |
Actually the heads were is the AG3212-3213
Reading around, it seems that the gel they used to 'preserve' the crystal instead accelerated its decline - the heads only lasted a few years! That would explain why the 3016 was used.
Regards, Ben. Last edited by ben; 15th Dec 2018 at 1:03 am. |
