16th Oct 2007, 12:05 pm | #1 |
Leader 8022 20MHz 2-Channel Oscilloscope service data wanted
I'm having trouble with the timebase lock on my Leader 8022 scope and really could do with a circuit diagram/service manual.
Does anyone have a copy they can let me have or know of a source of this information on the web? Thanks Colin
Colin Armstrong |
16th Oct 2007, 7:58 pm | #2 |
Re: Leader 8022 20MHz 2-Channel Oscilloscope service data wanted
Hi Colin, failing getting a circuit you could try looking at the PCB as the functions were often silk screened onto it. Look for the usual leaky caps and also high value resistors.
Clean sync selector switches and also clean ther board. If all else fails I have a coulpe of nice scopes to tempt you next time you are in the area. Best regards, Ed |
16th Oct 2007, 9:49 pm | #3 |
Hi Ed, thanks for the tips. I'll have a poke around. You're right, there's a lot of info silk screened on the board and it is possible to roughly locate the triggering circuit components. I'll cover off the basics - caps and high value resistors and also give the switch a shot of servisol. The trace can be stabilised by using the Holdoff control but it drifts. Also the sweep seems to be very unstable and has a slight 'waving' motion when there's no input.
It's annoying as this one is my 'Sunday Best' scope ... perhaps I will take you up on your invitation when next I'm in the North! rgds Colin
Colin Armstrong |
17th Oct 2007, 11:10 am | #4 |
Result
I emailed those nice people at Leader Instruments in the US and they've sent me the LS 8022 Service Manual in PDF format - FOC. What great customer service. Now all I have to do is fix the scope ... rgds Colin
Colin Armstrong |
17th Oct 2007, 9:30 pm | #5 |
Hi Colin, if otherthings are drifting as well try checking the main HT rails as if they are drifting other things are often referenced to them and drift as well.
Ed |
17th Oct 2007, 9:47 pm | #6 |
Hi Ed,
The main HT rail is spot on at 185v and as the CRT EHT is 2KV I haven't tried to measure it yet! Colin
Colin Armstrong |
