17th Sep 2007, 4:48 am | #1 |
Manor Supplies Mark V Colour Bar Generator
Hi!
Can anyone help me with a data sheet/block diagram/application notes for the TEA1002 PAL Encoder IC used in the Manor Supplies Mark V Colour Bar Generator, *OR* alternatively the Construction Plans originally supplied with it? The ZNA234E Ferranti IC is working but the colour O/P is missing. I purchased this s/h a year ago but the seller had long since lost the plans!!! (I can redo my own plans if I've got the TEA1002 info by the way!) Many thanks, Chris Williams |
17th Sep 2007, 7:00 am | #2 |
Re: Manor Supplies Mark V Colour Bar Generator
I have a Mk5, which gets used VERY occasionally. I attach a scan of the circuit and the Mullard TEA1002 from the instruction book and can supply more pages if you need. Not a very good copy I am afraid, but neither is the original which is a photocopy.
Hope this helps Dave |
19th Sep 2007, 1:15 pm | #3 |
Hi!
Thanks very much for your time and trouble Dave! It looks whoever built the one I've got made more than one assembly howler! However the paper you've posted is a bit unclear so could you post what else you have on this please - there might be a parts list etc. I can use! Chris Williams |
19th Sep 2007, 8:33 pm | #4 |
Your post reminds me that, last time I used mine it to had no colour...must get around to it sometime
I have the full set of distructions here if you need them, but for now have these- |
21st Sep 2007, 7:29 am | #5 |
Chris55000
some more scans for you, the rest will follow |
21st Sep 2007, 7:37 am | #6 |
more scans of the manual
21st Sep 2007, 7:46 pm | #7 |
Hi!
To Members dsergeant and kevinmin, thank you both very much Gentlemen! Sorry I don't have your names to hand here but this info is excellent and exactly what I need to sort out where my colours might have gone! I don't know wether I'll ever get round to making a new set of CAD-drawn circuit diagrams, PCB layouts etc and write this all up properly on a PC but rest assured if I do it will be posted! Once again, thank you both very much for taking the time and trouble to assist! Chris Williams Note for Mods - Another post Succesfully Solved! PS! A full Plessey Data Sheet for the ZNA234E Pattern/Sync Generator has recently been added to many Datasheet search-engines! Last edited by Chris55000; 21st Sep 2007 at 7:49 pm. Reason: Addition! |
