31st Aug 2006, 11:20 pm | #1 |
Source of psu for 18Volt Hackers, cheap and with free tool!
Hi All,
I obtained a "Blackspur" branded multi-tool the other day, you know the sort of thing, like a Dremel only cheaper and perhaps better value as these things cost £14.99 only! The device came with lots of blades and collets for the fitting of other types of things but, and here's the good bit and the point of this posting; the device comes with a good quality 18 Volt psu, it's designed to provide up to a whole Ampere so is plenty hefty enough for the radio use and the only thing that you will need to do is fit an inline connector to enable the polarity to be swapped over for the Hackers with a DC input as they're centre pin -ive and the Blackspur psu is +ive. I didn't bother as I use it inside my RP37 and simply made a loom to allow connection to that set's original terminals, but the best thing is that, even without additional smoothing measures, the thing creates no hum that I can detect, even at the low volumes that the set is used at during the night. The kit including the (surprisingly good) multi-tool, loads of accessories and the all-important psu cost, like I said, £14.99! Model/type number is BB-MD100. Go buy one, you know it makes sense! (I have no commercial interest in the product, its manufacturer or any member of their family, nor have they given me money to plug their product and I don't suppose that Blackspur would have foreseen the thing being put to this use anyway)
John. |
31st Aug 2006, 11:31 pm | #2 |
Re: Source of psu for 18Volt Hackers, cheap and with free tool!
Hi can you tell me who is stocking these, as I am interested in buying one many thanks
1st Sep 2006, 8:13 am | #3 |
Den
In this part of the world you tend to see lots of this Far Eastern like Blackspur, Proline, Tison et al in markets, especially the Sunday variety. Wonder who imports them?
Mike. |
1st Sep 2006, 8:41 am | #4 | |
This came from a small, local shop that sells everything on a "stack it high, flog it cheap" basis, but Blackspur stuff also comes from branches of Parkers Tools, the nearest one to here being 30 Miles to the South, at the Metrocentre.
John. |
1st Sep 2006, 8:43 am | #5 |
That sounds like a good deal, John.
But if you want just a PSU, 200mA is more than ample, and CPC does a suitable regulated one for £8.50 + VAT: http://cpc.farnell.com/jsp/endecaSea...sp?SKU=PW00506 Nick. |
1st Sep 2006, 8:53 am | #6 | |
Accepted that the Farnell device is the ideal thing for the job though!
John. |
1st Sep 2006, 11:00 am | #7 |
There are lots of these Dremel copies around, and I've seen them as cheap as £7.99. I've got one and they work well enough.
Quite a few wall warts will provide the 18V for a radio. I always keep old wall warts and have a shoebox full of them in the loft A big unregulated 9V or 12V one will often supply around 18V offload and at typical listening levels. HP inkjet printers and some others use a 30V wall wart (strictly speaking, a lump-in-the-cord). You can build a matchbox adapter with an LM317 to turn these into a regulated 18V supply. Paul |
1st Sep 2006, 11:08 am | #8 |
2nd Sep 2006, 2:27 pm | #9 |
Many laptop PSUs deliver 18-19 volts, and I've seen many of these supplies for sale very cheaply at Amateur Radio rallies.
Phil
2nd Sep 2006, 2:49 pm | #10 | |
Paul |
2nd Sep 2006, 6:26 pm | #11 |
When I went to the Worthing Rally at Newhaven in 2005 you got a substantial WW just for attending [ie giveaway]. These were 17v so probaly would fit the bill on load. No idea what they were for or why 17v? Dave
3rd Sep 2006, 3:51 pm | #12 |
If you've got acces to radiophile No 75 there is a picture of a Hacker Hunter with a "home brew" 18v PS which is actually made by Esther Ltd of Stevenage. Not exactlky readily available I know but it may be to someone! sorry can't do a picture. dave
