28th Jul 2006, 4:28 pm | #1 |
Octal valve bases.
Octal chassis mount relay sockets make cheap alternatives to octal valve bases. The ones I have used are from RS (part number 419 4222). The solder tag ones are available in minimum packs of 3. The tags on the bases are straight and not splayed like a true valve base but can still be used successfully. Has anyone else used these in the past? I can't be certain of the voltage ratings though, as they are plastic, but I believe they should be rated ok at mains voltages.
Biggles |
28th Jul 2006, 4:30 pm | #2 |
Re: Octal valve bases.
I thought RS still stocked valve bases. They still stock valves. Josh.
28th Jul 2006, 4:35 pm | #3 |
You're probably right Josh, the proper valve bases may well be cheaper knowing my reverse logic approach!
Biggles. |
28th Jul 2006, 5:35 pm | #4 |
I've use'd the maplin's ones beforwe when i was playing about with some amp desighns also built a trf set useing the same, i have four screwed to a peace of wood for such experiments. the ones i have all pins come out to screw terminals which mackes them ideal for experimenting. not particulerly cheep though.
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
28th Jul 2006, 5:50 pm | #5 | |
Regards,
Brian |
29th Jul 2006, 8:15 am | #6 |
Jaycar do octal valve bases, NZ$6.70 incl GST each which doesn't seem to bad price-wise (works out to about GBP2.20).
