| Vintage Television and Video Vintage television and video equipment, programmes, VCRs etc. |
#21 | |
I hope that all makes sense. As mentioned if it wasn't for the rarity and versatility of the thing it almost certainly wouldn't be worth bothering with. |
#22 |
True! But it's not rocket science and should be MUCH easier than with older tubes. I think the tube and yoke come as a pre-converged assembly, but I stand to be corrected if I'm wrong.
#23 |
You can stand proudly uncorrected, Nick!
It is an easy fix, but the 'new' tube will need the A1, focus and greysacle setting up which, although not difficult, might prove a little daunting if you've no experience of TVs Tetlee - it would be worth posting a 'wanted' post on the forum - you never know. It will need to be exactly the same type - A51-590. Although it's possible to substitute tubes, that's something you really don't want to do. Incidentally, try a post on a gaming froum as it appears some Hantarex 20" monitors used this tube.
Glyn Last edited by Welsh Anorak; 24th Jun 2025 at 12:30 pm. |
#24 |
He already has a wanted post as linked in post #14 in fact it was his first post.
He also has a local repairer. Cheers Mike T
Invisible airwaves crackle with life or at least they used to ![]() Mike T BVWS member. www.cossor.co.uk |
#25 |
Sorry - should read all the posts!
However I remember there's a member who has an AVS2000 whose TV section has died. ISTR he was thinking of removing the TV section and replacing it with a modern TV. As far as I know this will use an A51-590. Might be worth a message? Here's the thread:- https://www.vintage-radio.net/forum/showthread.php?t=217348&highlight=avs2000
Glyn Last edited by Cobaltblue; 24th Jun 2025 at 1:40 pm. Reason: fix link |
#26 |
Thank you again guys, I have been searching for the aforementioned AVS2000 but haven't seen any for sale currently.
I just clicked on the link above but the link is dead for me, I will try a forum search in a minute. I guess it would depend what was the issue with his tv whether that tube would be any use to me. If anyone happens to know any other specific sets that carried this tube that would be super helpful, it's a bit of a pain as obviously without opening a set the seller will be highly unlikely to know what tube is inside it. |
#27 |
Yes that link is broken I will se if I can fix it.
Try link now. Cheers Mike T
#28 | |
#29 |
I agree with what others have said, it is a simple job to replace the tube like for like. Anyone who calls themselves a "repairer" should find it a doddle. As far as setting the greyscale, focus and first anode voltage again a competent repairer should be able to do it in minutes. If not I'm sure the advice available here will soon help set it up. The monitor is well worth saving and no doubt a tube will turn up eventually just put it to one side until one does...
I sometimes see sets dumped by the skip at our local auction house. A Ferguson TX9 20" will have the correct tube as will some Panasonic models. I'll keep an eye out. There was a TX9 dumped not so long ago - they are still out there.
I am starting a choir for Christmas. So far we have Dean Dom Mary Lee and I...
#30 |
Try looking for a Pye or Phillips 20" KT3 they used that tube. The few that I have seen in the last year have all had good tubes. Bob
Bob, BVWS member |
#31 |
Might be wrong, but ISTR the 20" TX9 was fitted with the A51-580 which is different. However some TX100 20" sets used the 590.
Bob - I thought, the KT3 used the A51-570 which (in my experience) lost emission quite early on. The KT4 fared better but again it's an A51-570. I thnk the Bush/Toshiba T24 used an a51-590 (or a close equivalent) but these are thin on the ground. Unfortunately manufacturers swapped suppliers during production runs and modified their chassis to suit. AFAIK the Fidelity 20" only used the -590. There is a (vastly overpriced) AVS1600 on eBay and Facebook at the moment - no use to you as it's the 16" version, but they are out there.
Glyn |
#32 |
Thank you all once again. I will definitely be keeping hold of this set for some time now as you've all re-ignited my glimmer of hope once more, it's nice to be feeling a bit more positive about my chances. It would sure make the set feel extra special if it could be brought back to good.
I suppose the best thing I can try and do for now is compile a list of those sets suggested as suitable donors. There are 2 or 3 that have since been doubted so I will exclude those for now as would hate to buy a set and find it has the wrong tube. So let's see what we have so far.... Amstrad AVS2000 Fidelity 20" Philips TX100 20" With the following being possible but with doubts... Pye or Phillips 20" KT3 Ferguson TX9 20" Bush/Toshiba T24 All these searches seem dry in both any live, or even competed listings but still useful. If anybody knows of any other potential or better still confirmed Mullard A51-590X tube that would be fantastic. Thanks again. |
#33 | |
I think the Philips KT3 chassis used A51-570X tubes which are probably not compatible.
In my opinion it's mostly a scenario of finding a tube, and then take it from there. Last edited by Maarten; 24th Jun 2025 at 7:50 pm. |
#34 |
I used to fix VGA screens back in the day for sale at flea markets and used to swap several tubes per week. The line scan coils pretty well always worked. The frame coils were driven by a frame scan chip that was either 24 volts HT or 12 volts HT. It was a matter of going through the ones with fried power supplies or duff loptys with an ohm meter.
A check in the manual for the donor set would be in order before obtaining it. |
#35 | |
The search continues. |
#36 |
Guys, I think I have just spotted a possible contender. I'm sure somebody mentioned this music centre.
https://ebay.us/m/fD7m4f The seller mentions it 7.7" screen but just looking at the pic I'm sure that is a mistake. Not too far from me. Any thoughts? Cheers again. I'm still actively looking and hoping. One issue is they have an extremely ambitious buy it bow, and a reserve on auction so that could be way off the mark aswell. Last edited by tetlee uk; 19th Aug 2025 at 12:20 pm. |
#37 |
Looks like an AVS1600 to me which has a 16 inch screen
https://www.facebook.com/gntrading |
#38 |
#39 |
I tend to agree, but a quick message to the seller would reveal the model number - it will have a 20 in the number if it's correct for you.
If there is no label then mention it's the diagonal measurement of the screen that is the correct one.
Glyn Last edited by Paul Stenning; 21st Aug 2025 at 11:04 am. Reason: Forum rule C4 |
#40 |
Administrator
Please be aware of the eBay rules. We will allow discussions about whether the item in post #36 has a suitable tube or not, but nothing else about that listing, seller or eBay etc. One post edited.
