15th Jan 2020, 2:09 pm | #1 |
Dial Cord Beomaster 1400
Hello All,
I am trying to restring a Beomaster 1400 which will require a degree of patience. So as I don't get it back to front as it were, can anyone tell me whether the vanes in the variable tuning cap should be fully meshed - or fully unmeshed - when the dial pointer is at the low end of the FM band (87 MHz)? Counter-intuitively, the dial scale has the low numbers at the right hand end. Many thanks, Simon |
15th Jan 2020, 9:56 pm | #2 |
Re: Dial Cord Beomaster 1400
Hi Simon,
At the lower frequency the v cap will be fully meshed Cheers Pete |
16th Jan 2020, 1:40 am | #3 |
Thanks, Pete
20th Jan 2020, 12:43 am | #4 |
Hello,
I'm going slightly off topic here, but while going googly eyed figuring out how to restring my ancient Beomaster, I notice the set has been "got at" - quite neatly - which maybe suggests some sort of professional bodge. There is a small square of very thin plywood separating two of the AM and FM tuning coils, and what look like thin veroboard inserts into the AM/FM detector coil. Does anyone care to hazard a guess as to what might be going on here? Haven't powered this up yet, as I'm not happy with the mains switch so I can't comment on functionality. |
20th Jan 2020, 8:14 am | #5 |
The plywood between the cans could be forcing a bad joint to make contact, don’t know about the veroboard in the cans.
Frank |
20th Jan 2020, 11:28 am | #6 |
Thanks, Frank.
I will reflow them. Simon |
20th Jan 2020, 1:27 pm | #7 |
I don't know that set, but I recognise that the "IFT can" is a small daughter-board in a screening can, maybe the AM detector or something
- Julian It's good here |
20th Jan 2020, 2:29 pm | #8 |
Hi Julian,
So what I thought was a veroboard insert could be part of the daughter-board? It is indeed an FM/AM detector. Interesting. Thanks, Simon |
