25th Jul 2020, 12:32 pm | #1 |
Loft find radio ID? Identified as a Graves Vulcan.
This two valve set (valves missing) was found in a loft recently. I'm hoping someone out there might be able to identify it.
Apart from the labels on the transformer there are no manufacturers' labels, parts or serial numbers. The dial labeled 'strengthen' swings a shaft that moves a coil over two fixed coils in the cabinet and I guess it's varying the mutual inductance of the coils and adjusting selectivity. The circuit is 'hard wired', the valves' wiring sandwiched between two wooden boards. I've not yet attempted to work out the circuit diagram, maybe something to do in the winter months. Any ideas as to the origin or age of the receiver? |
25th Jul 2020, 12:45 pm | #2 |
Re: Loft find radio ID?
Looks Like a Version of the Graves Vulcan
I will just check. OK here's the link https://www.radiomuseum.org/r/graves_vulcan.html Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 25th Jul 2020 at 12:47 pm. Reason: Added link |
25th Jul 2020, 1:05 pm | #3 |
Yes,Graves came to me too before I moved to your post Mike. Possibly late 20's early 30's.
25th Jul 2020, 1:07 pm | #4 |
Well done Mike, 13 minutes and a spot on answer, as usual. That Radio Museum has an interesting link to the Wireless World publish date nearly 93 years to the day.
John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 25th Jul 2020 at 1:18 pm. |
25th Jul 2020, 1:15 pm | #5 |
Re: Loft find radio ID? Identified as a Graves Vulcan.
Sorry I was busy
Cheers Mike T
25th Jul 2020, 1:29 pm | #6 |
Graves Vulcan, second version of 1927, I think. There was a Wireless World review of it, not sure in which issue. The first version had "Vulcan JGG" on the front panel, later versions don't have this.
25th Jul 2020, 2:03 pm | #7 | |
July 23 1927. John.
My favourite text message "I'll be there in five minutes, if not read again" |
