24th Jun 2009, 8:58 am | #1 |
Front Panel/Chassis Design Software (FOC!)
I'm not sure whether this really ought to be posted in the Homebrew section - if so, maybe a moderator might kindly move it there.
I came across a neat bit of simple to use software which is ideal for designing front panels and chassis layouts. It even has a starter template for a front panel, to add other cut-outs to. You just choose where you want to place holes, and what size you want them. In contrast to a lot of CAD packages, its simple to use, and basically, is provided free of charge to enable potential customers to design machined components for the company to quote to make them as a one-off, or batch production - a useful service in itself. If all you want to do is to use the software for DIY purposes, that's fine. I've only had a quick look at it, but already grasped the basics. It has tutorials to walk you through the attributes. You can find it here - it's about 12MB and only takes a minute or so to dpwnload and install: http://www.emachineshop.com/machine-...re/page17.html Good eh? Hope that helps. David, G4EBT |
24th Jun 2009, 11:37 am | #3 |
Re: Front Panel/Chassis Design Software (FOC!)
We've already had 2 threads referring to emachineshop. This is one of them:
https://www.vintage-radio.net/forum/...&highlight=pcb |
24th Jun 2009, 6:32 pm | #4 |
For simple stuff you can use this freeware, again from a manufacturer, but of front panels:
http://www.frontpanelexpress.com/ No nice scales, but a good range of holes and text options. Print your front panel on whatever material you want, then spray with fine laquer to fix it. Not the most comprehensive, but it helped me get layouts right. Jeremy |
24th Jun 2009, 7:27 pm | #5 | |
24th Jun 2009, 7:53 pm | #6 |
I missed that. Now it starts to look pretty smart! If only there was a freeware meter scale program. http://www.tonnesoftware.com/meter.html is superb but is >£20. Can't justify that for only one or two meter scales.
Resolution: I must make my homebrew stuff look more professional. |
