Old 20th Jun 2020, 1:33 pm   #1
AndyWright
Default Labgear Topbander
I've acquired a Labgear topbander transmitter which needs restoration. I know there were 2 variants of this, I suspect I have the latter.
The original MK1, whose circuit is readily available on the net shows a modulator valve line up of EF80, 12AU7 and 12BH7.
The version I have, has a modulator valve line up of EF80 (mic amp) followed by an ECL82 (triode pentode) and another valve (definitely not a double triode or an ECL82) which has lost its markings. Some of the wiring around the mod section has been disrupted.
Does anyone have the schematic for what I presume is the MK2 version of this transmitter?
Andy G4OJY
AndyWright is offline
Old 20th Jun 2020, 5:27 pm   #2
AndyWright
Default Re: Labgear Topbander
I've made a little progress. The topbander manual djvu file on boat anchor manual archive mentions the modulator valve line up as EF80, ECL82 and EL84, so I guess this is what I have. There is no schematic with this manual, but the manual for the labgear LG160 does have a crude schematic with an EL84 modulator.
At least I can now try and retrace the schematic knowing what the valve line up in the mod is.
Old 20th Jun 2020, 11:44 pm   #3
m0cemdave
I have the circuit diagram for that version (stated as for use with transmitter serial numbers prefixed "S" only).
I need to scan it in sections and stitch them together.
Also the relevant manual, a bit yellow with age but will probably clean up OK.
Watch this space...
m0cemdave is offline
Old 21st Jun 2020, 8:30 am   #4
AndyWright
Thanks Dave that will be really useful.
Andy
Old 21st Jun 2020, 2:02 pm   #5
m0cemdave
Here is the circuit. It will be compressed by the forum software, so if it's not readable I will try again.
edit:
Not readable on the forum, but I can send the file to you if you PM me an email address (don't post it here).
Old 21st Jun 2020, 2:28 pm   #6
If you can convert it to a .pdf file the forum accepts these up to 4M.
Station X is online now
Old 22nd Jun 2020, 11:58 am   #7
ribbonmicsrus
ribbonmicsrus's Avatar
Dave
Can I ask a favour as well, can you send me a copy as well, mine is working well but it would be nice to have for reference.
73
Andy G3UEQ
QTHR QRZ.com
ribbonmicsrus is offline
Old 22nd Jun 2020, 10:14 pm   #8
m0cemdave
The Topbander Mk2 manual:
These pages are all readable on here, but if anyone wants a higher resolution copy for printing etc please send me a PM with an email address.
(see next message for the last two pages)
ID:	209273   Click image for larger version
ID:	209274   Click image for larger version
ID:	209275   Click image for larger version
ID:	209276   Click image for larger version
Old 22nd Jun 2020, 10:15 pm   #9
m0cemdave
last pages:
ID:	209278   Click image for larger version
Old 22nd Jun 2020, 10:16 pm   #10
m0cemdave
Andy (ribbon mics), you have a PM.
Old 23rd Jun 2020, 5:39 am   #11
G3VKM_Roger
G3VKM_Roger's Avatar
Hi All,
I put the MK1 manual on BAMA many moons ago, see here:-
http://bama.edebris.com/manuals/labgear/topbander
Unfortunately, I didn't own a MK2 and so have never chased up the manual for that mark. If a copy is located could the finder please add it to the BAMA directory and let the group know?
73
Roger/G3VKM
G3VKM_Roger is offline
Old 28th Jun 2020, 4:41 pm   #12
AndyWright
I've finally got the tx up and running. Can anyone with the MK2 version comment on how much output power they are getting. Into a 50 ohm load I get just under 5 watts. PA anode current is about 35mA dipped in the CW position.
I cannot get more than 1mA of grid current even with the drive pot on max, though the manual says I should be able to get at least 2.5mA
I have peaked L3 for max grid current.
Andy
