Old 29th Jun 2020, 3:19 pm   #1
Mike Phelan
Mike Phelan's Avatar
Default Wanted - PVR.
Hi folks,
We've had a Humax PVR 9150T for several years now, and it works fine but a bit limited on the number of programmes it can record.
We need a PVR with a bit more functionality: it needs to have SCART in / out and keep its memory when switched off.
Anyone got anything like that?
BTW, our TV is a 1980's B&O.
Mike.
Mike Phelan is offline
Old 29th Jun 2020, 5:44 pm   #2
duncanlowe
Default Re: Wanted - PVR.
When you say limited, do you mean how many recordings it can store on the disc? It might be possible to upgrade the HDD inside it.
duncanlowe is offline
Old 29th Jun 2020, 6:16 pm   #3
KeithsTV
KeithsTV's Avatar
Mike, is it a SATA drive? If it is I've got a surplus 250Gb drive you can have which should fit and increase the storage capability.
Keith
KeithsTV is offline
Old 29th Jun 2020, 7:38 pm   #4
paulsherwin
paulsherwin's Avatar
The Humax 1800T/2000T has a SCART interface as well as the now-ubiquitous HDMI (it also has phonos for audio). It supports the Freeview HD muxes. I think it's still available though it's getting on a bit now, having been introduced in 2014. I have one and there have been no disasters so far. You can upgrade it with any 2.5" SATA HD, and also use an additional HD via the USB interface.
paulsherwin is offline
Old 30th Jun 2020, 8:45 am   #5
Mike Phelan
Hi Duncan,
My wording was probably a bit too vague
The actual disc capacity isn't a problem, it was the number of simultaneous recordings; ie if we want to record four channels at, say, 9 pm, we can only record two.
The location of the unit is in such a place where access is very limited so I don't reallt want to do very much to it other than just replace it. having anything attached to it isn't really possible.
Mike.
Old 30th Jun 2020, 8:46 am   #6
Mike Phelan
Keith
Thanks, Keith, but AFAIK it isn't a SATA drive.
Mike.
Old 30th Jun 2020, 8:56 am   #7
Mike Phelan
Hi Paul,
The 1800T seemed OK regarding the size, however looking at it further, watching or recording two channels simultaneously cannot be done, so it's giving me less than my current 9150T.
Mike.
Old 30th Jun 2020, 10:40 am   #8
paulsherwin
No, it contains 2 tuners, which is standard for a Freeview PVR. This means you can record or watch channels from 2 muxes at the same time. For example, say BBC1 and BBC2 are on mux A, ITV is on mux B, and Dave is on mux C. You can record BBC1 and ITV at the same time because you have access to two muxes. You can additionally watch or record BBC2 at the same time because it is also on mux A. However, you can't watch or record Dave at the same time because it is on a third mux.
Old 30th Jun 2020, 3:01 pm   #9
Mike Phelan
Gotcha, Paul, I understand.
So, it would need another tuner to do what I need, if there were such a thing.
Looks like I'll have to stick with the 9150T.
Mike.
Old 30th Jun 2020, 3:06 pm   #10
paulsherwin
I don't know of any Freeview PVRs with more than 2 tuners, but they may exist.
Another solution is just to use more than one PVR!
Old 30th Jun 2020, 3:16 pm   #11
Nickthedentist
Nickthedentist's Avatar
Yes, I know people who have two identical PVRs on top of one another for that very reason.
Now that there's more and more available to stream, I'm doing less and less recording as time goes on.
Nickthedentist is offline
Old 30th Jun 2020, 3:37 pm   #12
Mike Phelan
Paul, I think I'll just stick with what I have as it's not a desperate need as we don't intend to be couch potatoes.
Nick, I'm not au fait with this streaming thing but I suspect I would need a newish TV and / or some sort of monthly cost? Or a wok on the wall?
Mike.
Old 30th Jun 2020, 3:49 pm   #13
paulsherwin
You just need a streaming device and an internet connection, though most only provide an HDMI interface so would need an HDMI to composite converter to drive a 40 year old telly. The T1800 PVR has some limited built in streaming facilities.
Old 30th Jun 2020, 11:13 pm   #14
Aub
Aub's Avatar
I try to record stuff, rather than stream, if it's got adverts, so I can fast forward.
Aub
Ignorance of The Law is No Excuse - but I didnt know that!
Aub is offline
Old 1st Jul 2020, 9:13 am   #15
red16v
Aub
Please donít do that, they pay my pension!
red16v is offline
Old 2nd Jul 2020, 8:46 am   #16
Mike Phelan
Mods, I think you can close this thread as my question has been adequately covered - we'll just stick with the present Humax while it still works.
Mike.
