Old 24th Oct 2018, 11:19 pm   #1
NorfolkDaveUK
Default Philips N4408 replacement rubber.
I have one of these with goop in it . I have the belts , but does anyone know where I can get the other rubber needed for it ?
NorfolkDaveUK is offline
Old 27th Oct 2018, 2:20 am   #2
suebutcher
suebutcher's Avatar
Default Re: Philips N4408 replacement rubber.
Remember that the 4408 has the same basic mechanism as the 4404 and 4407, this may help when searching for spares. I don't know about the pinch roller, but there are people selling take up turntable idler tyres for these machines (the thing that looks like a pinch roller next to the right take up turntable).
The Waves That Rule Britannia
suebutcher is offline
Old 27th Oct 2018, 1:40 pm   #3
NorfolkDaveUK
Thanks Sue yes thats the one im looking for the pinch roller is fine . i was quite lucky the only thing that had gone to goo was the idler roller , I got a new tyre from Germany , so all good now . Just got to wait for it to arrive .
Many thanks as always x
Old 28th Oct 2018, 11:21 am   #4
ben
ben's Avatar
I once used an actual pinch roller from a scrap sanyo portable r2r to fix the FF on one of these Philips. Unfortunately that was 20 odd years ago and I can't recall the model.
Regards,
Ben.
ben is offline
Old 28th Oct 2018, 12:33 pm   #5
NorfolkDaveUK
Yeah I thought about using a Revox one , but it would have been hassle to make it fit so I paid the £16 for new rubber . I probably could have made it work but I would have to have increased the size of the pin it goes on and I really just wanted to get onto the next one so meh ...it`ll get sorted .
Old 30th Oct 2018, 10:50 am   #6
suebutcher
suebutcher's Avatar
Any suggestions about the rubber reel brakes? Mine had perished, so I've replaced them with two brake shoes made of cork matting, but the braking still isn't quite good enough.
Old 30th Oct 2018, 11:56 am   #7
NorfolkDaveUK
I have a load of old motor cycle tyres here Sue and I cut little strips of rubber and just glue them to the rail . Works just great . If you go to a scrap yard they will sell you a tyre for next to nothing and you`ll have rubber for decades ..lol
Old 1st Nov 2018, 11:57 am   #8
suebutcher
suebutcher's Avatar
I've swapped the cork for some soft rubber, and it stops the reels very well, except the supply reel is still spilling a bit on fast forward. The internal reel clutch on this side is slightly too loose. How do you tighten this, is it adjusted with the nuts inside the spindle?
Old 1st Nov 2018, 1:25 pm   #9
NorfolkDaveUK
I`m not entirely sure as yet Sue , I havent got that far I`m still waiting on the blasted rubber from Germany ..haha .
Old 1st Nov 2018, 4:34 pm   #10
Refugee
Refugee's Avatar
I would dismantle the reel table and have a look inside the clutch.
Do be prepared for the can of slug slime that may well be in there
Refugee is offline
Old 2nd Nov 2018, 12:57 am   #11
suebutcher
suebutcher's Avatar
Nasty! I'll have a go, keeping in mind all the tiny parts inside the spindle that may go flying. It's a pity that the repair manuals for this series of machines all seem to be in German.
Old 2nd Nov 2018, 1:03 am   #12
Refugee
Refugee's Avatar
There are supposed to be 4 rubber parts inside the clutch.
The problem is that they are made of normal Phillips rubber
Refugee is offline
Old 2nd Nov 2018, 1:49 am   #13
NorfolkDaveUK
There are no rubber parts in the clutch in mine at all , I`ll take a pic when i get a moment to myself , its gone crazy here .
Old 2nd Nov 2018, 2:04 am   #14
Refugee
Refugee's Avatar
If it is the same as mine it should have some slime in it now.
Refugee is offline
Old 2nd Nov 2018, 2:32 am   #15
NorfolkDaveUK
No , no rubber , no slime , it has like a tri shaped plastic spring thing in it .
Old 2nd Nov 2018, 11:02 am   #16
suebutcher
suebutcher's Avatar
Mine's a 4407, it could be different. But the clutch makes a creak, not a squish, so I may be in luck. I'll check it tomorrow.
Old 2nd Nov 2018, 11:45 am   #17
NorfolkDaveUK
are they technical terms Sue ?
Old 2nd Nov 2018, 12:57 pm   #18
suebutcher
suebutcher's Avatar
Nope. Anyway, there's no rubber involved, fortunately. Instead of the tri-lobed top clutch in your diagram, my 4407 has a felt ring held in place with a plastic grip. The bottom clutch is also felt, glued in place. The problem seems to be the spring that puts pressure on the top clutch. It's weak, and needs stretching out.
Old 4th Nov 2018, 4:15 pm   #19
Welsh Anorak
Welsh Anorak's Avatar
Re the brake rubbers - I found one in a derelict Philips deck pre-goo era. The other I made from the a wedge used for CRT scan coils. They are a pain to set up correctly, though as adjusting one affects the other....
I believe a seller in Germany does supply them with his belt kits, though the price is somewhat frightening.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 5th Nov 2018, 1:02 pm   #20
suebutcher
suebutcher's Avatar
Oh yes. It takes half an hour of microscopic adjustments to get both sides grabbing with equal force! By the way, does anyone sell the original triangular cross-section drive belt for these machines? I'm running mine on a round-section belt, which is OK, but it's on the way out.
