Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps. |
#1 |
1) 3 x Hour counters - DIN rail mounting, not re-settable, presume DC operation from '+' label
2) Video camera mounted in case. No idea, no data, but presume superseded and still working. All FOC but for postage. Last edited by Cobaltblue; 24th Jun 2022 at 5:45 pm. Reason: added to title |
#2 |
Here's some more:
1) just for the collecters amongst you, 5A plugs, 2 by Eveready, one WG (the embossed lines on the cover don't show in the pic), one MK along with matching socket 2) a rather odd device, a B15 (SBC) lampholder at one end, a pair of sprung pins at the other, overall length 71mm. All FOC but for postage. |
#3 |
And for the die-hard collecter:
1) a ceiling pull switch by Crabtree, 250V 15A DP 2) a 3 pole Twist-Lock connector, made in USA by Hubbell, rated 250V 10A, 125V 15A. 3) a wood cased push button switch, would grace any museum Again FOC but for postage. |
#4 |
And finally:
1) Semiconductor Strain Gauge Sensor, type TS1 by Ether Engineering Ltd of Hemel Hempstead. Comes in its own instrument case, with 2 yards of flexible cable and original Test Certificate dated 18-9-70. Range 0 - 200 grammes, Appears unused. 2) Terminal block 4w - the camera show every speck of dust on this one. FOC bar postage. 3) Collection of Bulgin connectors. The largest one (on the left), with 2½m of 1.5 flex, is 22mm diam and is the type with screw terminals. I'll match Norman's £15 incl postage for this one. The remainder to go as one lot, perhaps £15 incl postage is reasonable? |
#5 |
Good evening,
Could I show an interest in the hour meters and the strain gauge please. They would need posting though. Many thanks, Christopher Capener
A proper radio is one that needs to be moved with a wheelbarrow !! |
#6 |
#7 |
Hi, I have a use for the crabtree pull switch as I have similar ones in my house and one's faulty! I hope you don't mind posting but I'll stand aside if anyone else wants it as part of a job lot
#8 |
Good morning Graham,
PM sent. Regards Nigel |
#9 |
#10 | |
Consider it yours, Graham. Please PM me with your address.
Regards, Graham Quote:
#11 |
Delighted that it will be put to good use. Please PM me with you address.
Regards, Graham |
#12 |
Price reduced - Post #4, item 3, 22mm Bulgin connector now £8.50 posted,
Remaining Bulgins £12 posted. (Misread detail in Norman's post - oops) Repeating photos for clarity. |
#13 |
Hi Graham
I'll take the 22mm bulging plug for £8:50 posted Cheers Simon |
#14 |
I would like no3 please, the wooden switch for my museum, should go well with the wooden plugs. will be in contact later today.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
#15 |
Still available:
1) 5A plugs & socket 2) Odd B15 lampholder 3) 3 pole Twist-lock connector 4) Bulgin connectors (new photo - largest one claimed) 5) 4-w terminal block |
#16 |
Here's another item I'm never likely to use: a Gemini Data Logger, presumably of temperature by Tinytalk, part no.TK-0014. Presumed working but don't have the knowledge to test. Range -40 > +85 C.
#17 | |
![]() Quote:
EDIT: sorry I realise now the required software is licensed, so not something I'd use. |
#18 |
Oops - re the data logger, omitted the "FOC" plus postage.
I did enquire of the supplier a while ago, the response being that proprietary software and USB cable would be required, the quoted price from them being £55 + VAT & carriage. I have neither software nor cable. They did also send me the datasheet which I'll be glad to forward to anyone here. |
