Old 22nd Jul 2018, 3:20 am   #1
19Seventy7
19Seventy7's Avatar
Default Dansette Conquest
Hi, I'm interested in buying a Dansette Conquest, but I would like to know what the average tracking force on one of these is and whether you can adjust them or not. Thanks.
19Seventy7 is offline
Old 22nd Jul 2018, 7:06 am   #2
Edward Huggins
Default Re: Dansette Conquest
The Dansette "Conquest" was fitted with 3 types of BSR autochanger - BSR UA8, UA14 and UA15 - so without knowing which one you are buying we cannot be specific. You can certainly adjust the tracking force using the spring under the tone arm. A rather rough answer to your question is that if the version you are buying is fitted with an older type BSR TC8M Mono cartridge and you only intend to play older Mono LPs (not Stereo) and 45s the tracking force should be c.5-7 grams. If it has been later fitted with a Stereo-Compatible cartridge and you intend to play both Mono and Stereo LPs, the tracking weight should be c.5 grams. We really do need more precise info from you.
Edward.
Edward Huggins is offline
Old 22nd Jul 2018, 9:50 am   #3
Herald1360
Herald1360's Avatar
5g+(+++?).
Probably coarsely adjustable via a spring position but will vary somewhat depending on the height of the stack in autochange mode.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Jul 2018, 9:52 am   #4
Audio1950
If still fitted with the original cartridge, about 8 grams, but in all probability the cartridge would have been replaced with a stereo compatible version by now, tracking at between 4-6 grams, depending on the make and model. The tracking weight is adjustable by the stretching of a spring under the arm. Not exactly hi-tech, but effective.
Audio1950 is offline
Old 22nd Jul 2018, 3:17 pm   #5
19Seventy7
19Seventy7's Avatar
Oh, sorry, I don't know which deck, ill get pictures of the type I would like to get. Im not sure of the first decks' model, but I know the second image is BSR UA14. Thanks
ID:	166396   Click image for larger version
Old 22nd Jul 2018, 4:58 pm   #6
Edward Huggins
The photo on the left is of the earlier and rather more rare, BSR UA12. If these were ever fitted to an early Dansette "Conquest" Mk1, it will be very rare.
Edward.
Old 22nd Jul 2018, 5:21 pm   #7
Michael Maurice
Michael Maurice's Avatar
I sell Dansette Conquests from time to time, but before you buy you must make sure it is fully serviced.
Before I sell them, the deck is stripped right down, all old grease is removed and fresh lubricant applied. The motor is stripped and oiled. If a stereo compatible cartridge is fitted then it gets a new stylus, otherwise ??I fit a new stereo cartridge.
The amplifier will be checked and certain capacitors replaced on sight, any other out of tolerance components are also replaced.
A new mains cable is also fitted.
I have seen loads of these that are sold serviced but have in fact only had their mains cable replaced and had a few drops of oil here and there.
Finally I give a 1 year guarantee except for the stylus.
Forum Moderator
Michael Maurice is offline
Old 22nd Jul 2018, 6:00 pm   #8
19Seventy7
19Seventy7's Avatar
looking on ebay, I have actually seen a few for sale, but none that have been serviced and some not working.
Do you also repair if someone has bought the player and then sends them to you? If so, how much?
Old 22nd Jul 2018, 8:12 pm   #9
Michael Maurice
Yes I do, I'll send you a PM.
Forum Moderator
