7th Feb 2018, 11:24 pm | #1 |
GPO Heat Shunt?
Hi.
I came across this item (attached pic) in a box of miscellaneous junk items at the local car boot sale. It appears to be made from lacquered aluminium. As a guess, it looks like a heat shunt used when soldering vulnerable germanium diodes and transistors. On one handle there's stamped "GPO 1966." On the other handle is stamped SPEARETTE" which I take is the manufacturer. Can anyone confirm my suggestion that it's a heat shunt? Regards Symon. |
7th Feb 2018, 11:56 pm | #2 |
Re: GPO Heat Shunt?
Google shows that Spearette was a brand name of Spear Engineering Co. of Surrey, who made aluminium-based tools for the radio and allied industries.
Products include valve-pin straighteners and jigs for wire harness making
Kevin |
8th Feb 2018, 12:03 am | #3 |
Re: GPO Heat Shunt?
I have an identical one here that came from a British Railways signal and telegraph technician. When he gave it to me he described it as a 'heat shunt' though he never said what he used it on. Your assumption would seem to be correct.
Al
I won't tell you how I discovered that. |
8th Feb 2018, 10:30 am | #4 |
Re: GPO Heat Shunt?
Hi
Thanks for your replies and the info. It looks to be a handy little item especially when soldering small germanium diodes. Regards Symon |
