Old 29th Jul 2011, 9:43 pm   #1
Mark the Mender
Default Ever Ready 5318
Hello all
I have finally finished bringing this set back to life.
To be honest it was not that difficult as it is a superhet from 1946. I do think it is an earlier chassis from the late 30's modified slightly from the original circuitry as it still uses the Ever Ready side contact valves, and was issued in a new cabinet as makers returned to domestic production.
There are only about 5 or six wax caps in the set, all were checked for leakage, they all leaked so were changed, and the decoupling electrolytic of 8uf.
As it is a battery only set there are no smoothers.
Some of the wiring looms had to be remade, that for the battery plug, speakers and frame aerial.
The only other major problem was the speaker magnet was not correctly aligned so the cone had no movement. there was also some rust on the mating faces. once cleaned the magnet was put back in and gently nipped up, then with a brass faced watchmakers mallet gently tapped to centralise it.
The cabinet was given a good clean with brasso and the tuning dial plastic with warm soapy water.
Once connected up to the battery eliminator it halfway worked but was not very sensitive. A clean of the wavechange switch soon resolved that problem and the set is exceptionally sensitive on both MW and LW.
The observant of you will note there is no space within the cabinet for a battery, there is a slot cut in the back for the battery plug and loom to poke through to enable connection to the battery.
In all a neat set and pleasing on the eye
Name:	Ever ready 5318 003.jpg
ID:	54482   Click image for larger version
Name:	Ever ready 5318 speaker.jpg
ID:	54483   Click image for larger version
Name:	Ever ready 5318 halfway.jpg
Mark the Mender is offline
Old 30th Jul 2011, 11:28 am   #2
neon indicator
Default Re: Ever Ready 5318
Amazing for 1946.
When were 1st D series B7G valves used by Ever Ready? 1950?
neon indicator is offline
Old 30th Jul 2011, 9:49 pm   #3
JoshWard
JoshWard's Avatar
The chassis looks great, almost like new with the replacement wiring
Now how about a pic or two of that pretty little cabinet?....
Josh.
JoshWard is offline
Old 30th Jul 2011, 10:09 pm   #4
Mark the Mender
oops forgot that. I shall sort it!
cheers Mark
Old 30th Jul 2011, 10:17 pm   #5
Mark the Mender
As requested
Whilst the cabinet has been brassoed I shall go over it with some TCUT
cheers Mark
Name:	Ever ready 5318 cabinet done 001.jpg
ID:	54516   Click image for larger version
Name:	Ever ready 5318 cabinet done 002.jpg
Old 30th Jul 2011, 10:20 pm   #6
Steve_P
Steve_P's Avatar
Nice set that Mark. Bet it sounds as nice as it looks too.
Cheers,
Steve P.
Steve_P is offline
Old 30th Jul 2011, 10:23 pm   #7
JoshWard
JoshWard's Avatar
Thankyou!
It really is a lovely looking little thing, well done . I've found T-Cut is slightly more abrasive than Brasso and gets a slightly deeper shine faster, also found it preferable to that Polishing Paste Number 5.
JoshWard is offline
Old 1st Aug 2011, 9:52 pm   #8
Phil G4SPZ
Phil G4SPZ's Avatar
Nice job, Mark, well done! I nearly bid for one of these on eBay a while back, but managed to restrain myself. I like Ever Ready battery sets, and have restored one from 1937 and have another in the 'to do' pile. Sadly, though, the one thing missing from a battery radio is an illuminated dial
For what it's worth, I use Paste Polishing No. 5 followed by a burnishing cream or liquid antique wax polish, it gives a fantastic shine to Bakelite.
Phil
Phil G4SPZ is offline
