8th Feb 2018, 12:25 pm | #1 |
Philips 603 record player output transistors?
Hi i've been given a Philips 603 record player with no output on one channel i have looked about and it seems it needs new output Transistors can anyone tell me what type and specs of transistors to get hold of for it?
Barry. Last edited by Station X; 8th Feb 2018 at 1:04 pm. |
8th Feb 2018, 12:31 pm | #2 |
Re: Philips 603 record player output transistors
Are there not any numbers on the transistors?
Peter |
8th Feb 2018, 12:39 pm | #3 |
Hi I've not opened it yet.
Barry Last edited by Station X; 8th Feb 2018 at 1:04 pm. Reason: Thread title edited. |
8th Feb 2018, 4:11 pm | #4 |
Re: Philips 603 record player output transistors?
Hi the transistor types are given on the radiomuseum
https://www.radiomuseum.org/r/philip...?language_id=2 To my surprise they are in the main Germanium It also has an integarated circuit in the audio side. https://www.radiomuseum.org/tubes/tube_sbf3a.html Cheers Mike T
8th Feb 2018, 4:11 pm | #5 |
That seems a good place to start!
The transistors are AC187 and AC188: http://85.144.192.2/nvhr/Philips_22GF603.pdf |
8th Feb 2018, 6:44 pm | #6 |
Ouch! Looks like that circuit depends on lots of NFB to squash any crossover distortion. Maybe acceptable with Ge devices but still a bit naff.
8th Feb 2018, 8:30 pm | #7 |
Would be better to diagnose the fault rather than guess what it is.
Geoff |
9th Feb 2018, 12:08 pm | #8 |
In my experience the SBF3A is the likely problem.
9th Feb 2018, 1:40 pm | #9 |
If so, that's bad news: http://www.philipsradios.nl/forum/in...hread&id=18786
9th Feb 2018, 6:55 pm | #10 |
On ebay for a heart stopping £28.99!
Plus you don't yet know what else it might want. http://www.ebay.co.uk/itm/SBF3A-Inte...YAAOSwdSNZ4gLx Edit:- There is a suggestion at the bottom of that thread that you might get away with using a bog standard op-amp. |
9th Feb 2018, 9:08 pm | #11 |
I would think that you could. There's nothing exciting about the circuit. It would be easier and better sounding just to substitute purpose made audio power amp chips, though, if a working repair is the aim, not restoration.
9th Feb 2018, 11:56 pm | #12 |
Notwithstanding the previous posts, with a bit of luck Barry may be right and all he needs is the transistors. Please let us know the outcome.
