Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
12th Jun 2013, 10:51 am | #1 |
Maplin UHF Modulator Dip Switch Settings info Request
These excellent units are well known, as we know any of the channels 21-68 can be selected by altering the dip switch settings. The unit comes with instructions giving all the combinations.
Unfortunately I seem to have mislaid my instruction guide. Could anyone please upload them or at least give the combination for UHF CH64? This would be much appreciated. Now analogue has ended I wish to set mine to ch64, the original BBC2 Pontop Pike channel 1966-2012. Many thanks, Brian |
12th Jun 2013, 1:04 pm | #2 |
Re: Maplin UHF Modulator Dip Switch Settings info Request
Hello Brian,
Here are the DIP switch settings for the Maplin VH89, I think that is the one. SWITCH 1 2 3 4 5 6 7 8 Ch 64 1 0 1 0 1 1 - x (815.25MHz) On=1, Off=0, X=0 Video In; 1=Test Regards, Stuart. |
12th Jun 2013, 1:04 pm | #3 |
Column formatting lost in the post -hope it makes sense!
12th Jun 2013, 2:23 pm | #4 |
In case it helps, here is a version with the formatting restored:
Code:
12th Jun 2013, 5:04 pm | #5 |
Thank you very much to the both of you!
Cheers, Brian |
12th Jun 2013, 6:08 pm | #6 |
Hi Brian,
Not very good copies but here's the complete list of modulator settings. I assume your modulator is the same as mine, the model VH89. Regards, David. |
12th Jun 2013, 7:11 pm | #7 |
Hi David,
They came through clear as a bell at this end. My very many thanks! Cheers, Brian |
12th Jun 2013, 8:17 pm | #8 |
Or, to put it another way:
Subtract 21 from desired channel number. Set switches 1-6 to that number's binary equivalent. (Reading left to right; so 6 = units, 5 = twos ... 1 = thirty-twos.)
13th Jun 2013, 12:05 pm | #9 |
Ah...I see it now...never really looked at the switch settings in such detail before!
15th Jun 2013, 9:42 am | #10 |
Expect Ch 64 to be troublesome when 800 MHz LTE starts up. Even if no terresterial aerial is looped through there may well be enough ingress to cables/or the TV to cause interference to the modulator output. Be prepared to move channel again. Post a message here if /when you notice any interference.
15th Jun 2013, 10:28 am | #11 |
We have had a card come through our letterbox this week about 800Mhz interference,it says a free filter can be sent free of charge if you experience it!
18th Jun 2013, 3:00 pm | #12 |
Many thanks to you all for your interesting replies. Colourking- thanks for letting me know. No problems at this end so far.
Cheers, Brian |
