1st Oct 2018, 5:08 pm | #1 |
Replacement BSRX3M cartridge
I am looking to change the BSRX3M cartridge in my Dansette Bermuda MK II but do not want to change for a stereo equivalent.Will the BSRSX6M be a suitable replacement.Thanks Martin
1st Oct 2018, 5:16 pm | #2 |
Re: Replacement BSRX3M cartridge
1st Oct 2018, 6:09 pm | #3 |
If you take a look at Bens sticky on Cartridges you will find much useful information.
Cheers John |
1st Oct 2018, 6:28 pm | #4 |
If you do not want a stereo cartridge, but want a stereo-compatible mono cartridge as originally fitted to your Dansette, you may still find some residual stocks of the BSR X5M. But there's no reason why you cant just bridge the channels on the more readily available (NB all stocks under pressure now) stereo cartridges such as the BSR SC11M.
Edward. |
1st Oct 2018, 8:00 pm | #5 |
But whichever one you eventually get, make sure is has the mounting bracket with it.
4th Oct 2018, 10:15 am | #6 |
Thank you everyone for the information.
15th Oct 2018, 4:41 pm | #7 |
I have just found a BSR X5M for sale complete with bracket.Will this be a
straight replacement or need some modification, Thanks |
15th Oct 2018, 5:15 pm | #8 |
You were very lucky to still find a BSR X5M. Yes, it's a straight replacement.
Edward. |
15th Oct 2018, 7:22 pm | #9 |
Thanks
24th Oct 2018, 9:22 am | #10 |
The X5M will not fit with the screws from the X3M as it's bracket is plastic and thicker to the X5M which is metal and a lot thinner.The screws appear to be a self tapping type.Can anyone suggest where I could get some small screws that would be suitable. Thanks
