Old 6th Jan 2011, 11:49 pm   #1
Coastwatch
Default Your favourite Transistor, Mine the 2N2926G
How I wish I hadn't found this forum, now I'm neglecting everything to try and catch up with the threads.
Anyway this has also started me reminiscing on my past electronic history and the change over I made from valves to transistors and then from Germanium to Silicon and I have to say that of all the transistors I have used (and abused) my favourite was the 2N2926G as it was the first Silicon NPN transistor I use.
As a teenager this transistor seemed to do everything I wanted it to do, Guitar sound effects, TRF radio, and with a BFY52 my first fm transmitter, got my Dad to drive around with his B&O Beolit 700 to check the range (a patchy 1 mile) Ah! happy memories.
So I wonder what is your favourite Transistor and why.
Cheers n Beers,
David.......
Coastwatch is offline
Old 7th Jan 2011, 12:09 am   #2
Martin G7MRV
Default Re: Your favourite Transistor, Mine the 2N2926G
The BC108, the J310, and the 2N3055H, in that order
BC108 'cos its a GP beast that will do most things, although these days i use the less 'transistory' looking BC548. The J310 - pressed into RF service everywhere i go, and the 3055, because, well, 'cos its a beast that can take the heat!
Never really thought about favorite devices. Im a child of the years when 555's and 741's were everywhere, although if we talk ICs them favorite is definately the NE602
I got food in ma belly and a license for ma telly
My Blog - http://g7mrv.blogspot.com
Martin G7MRV is offline
Old 7th Jan 2011, 10:57 am   #3
Andrew2
Andrew2's Avatar
Indeed, the 2n2926 was the device of choice when we were teenagers messing about making amplifiers, oscs etc. BC109 also. These days I've got a huge reel of BC548's which will probably last me 'til I croak!
Back in the late 60's, we'd get the bus into Manchester and pick up ex-computer boards containg rows of ASZ21's, PNP Germaniums good to 300 MHz and make portable 'telly-jammers' with them. Great fun standing outside the TV shops watching the tellies swirling and rolling.
And the NE602 mixer - it makes me wonder what I did before they came along!
Andy G1HBE.
Andrew2 is offline
Old 7th Jan 2011, 3:27 pm   #4
electroanorak
electroanorak's Avatar
Mine.....
The good old BC182 and BC212. And of course the great and reverend 2N3055. I now use the 2N4401 and 2N4403's now and the BS107, 2N7000 and BUZ11 MOSFETS more.
Fav IC's.
PIC,s and still the 4000 CMOS logic and 74C logic series.
electroanorak is offline
Old 7th Jan 2011, 5:47 pm   #5
Skywave
If I'm designing or repairing something and I want low-power, general-purpose devices, I instinctively reach for BC109 (possibly BC107) and BCY71. If I need medium power, BFY52 and BFX29. After that, 2N3055 (easy when you have a box of them!).
For low-power RF applications, BFY90; occasionally, 2N2369A.
2N3819, 2N3823/4 when FETs are required.
Otherwise, it's look up the spec. (Towers and / or the 'Net) and choose accordingly, which is certainly helped when you have a large range to choose from. The biggest problem is finding medium-power PNP silicon with high Vce.
Al. / Skywave.
Skywave is offline
Old 7th Jan 2011, 7:56 pm   #6
McMurdo
McMurdo's Avatar
BC107 is my favourite all-purpose project transistor, base in the middle, emitter by the tab and collector the other one.
Kevin
McMurdo is offline
Old 7th Jan 2011, 8:01 pm   #7
murphyv310
murphyv310's Avatar
BC107-9 great little transistor, BD131/132 are very useful too with a reasonable ft. 2N3055 of course and 2N3819's
Mind you I have enough BC547 & BC548 to last for years.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 7th Jan 2011, 9:12 pm   #8
davegsm82
davegsm82's Avatar
BC108 Is possibly the thing which first got me into electronics.
For higher power, it was then the BFY50-51, 2N3055/TIP3055 progressively.
Just recently i've made up a plastic divider box with different types and their basic credentials written on the lid. Current favourites (all TO-92 types)
BC182 (NPN) - 50v - 0.1A
BC556 (PNP) - 65v - 0.1A
2N6517 (NPN) - 350V - 0.5A (for high voltage switching)
2SD965 (NPN) - 22V - 5.0A (for high current switching)
BC337 (NPN) - 50V - 0.8A
BC237 (PNP) - 50V - 0.8A (Both good all rounders).
The 2SD965 is an excellent choice for battery driven transformer/inductive converter circuits, it switches well and can carry huge currents for its size.
Almost out of 548's
Favourite valve was the first I ever bought, an ECC83, bought from maplin about 16 years ago, that thing did some work!
Dave.
davegsm82 is offline
Old 7th Jan 2011, 9:33 pm   #9
Lucien Nunes
ZTX653 (NPN) & 753 (PNP) are two of my favourite toolbox transistors.
Ic max 2A, Vceo 100V, typical hFE >150 @ 10 - 800 mA and >200 @ 500mA, fT 175 MHz, Ptot 1W without heatsink or 2W with Tc=60 deg.
All in the dinky E-line package less than 0.1" thick that will pack tightly on stripboard and slot into places a TO92 package won't. Not the cheapest small transistor by a long shot, perhaps a bit old hat now, but a good allrounder that has often come to the rescue.
Lucien
Lucien Nunes is offline
Old 7th Jan 2011, 9:35 pm   #10
Steve_P
Steve_P's Avatar
Mine are the AF11x series, because if you see them then 9 times out of 10 you've found the fault....
Cheers,
Steve P.
Steve_P is offline
Old 7th Jan 2011, 11:36 pm   #11
robjkmannering
Could not agree more Steve.
Think my first transistors were BFY51 because they were used in a book of projects and I liked the larger metal TO18? shape.
Must addmit to have a strange obsession for OA81 diodes at the age of 7 which Dad had to order through RS for me till I discovered Maplin.
Regards,
Rob
Last edited by Brian R Pateman; 8th Jan 2011 at 10:29 am. Reason: Quote "Adjusted."
robjkmannering is offline
Old 7th Jan 2011, 11:43 pm   #12
ppppenguin
ppppenguin's Avatar
Many years ago I used to think that metal cased transistors were always better than the cheap and nasty plastic ones. BC548 and BC558 are now my first choice unless I need something bigger or faster.
ppppenguin is offline
Old 8th Jan 2011, 12:17 am   #13
peter_scott
peter_scott's Avatar
I used to like 2N5179, Ft ~1G for VHF stuff and 2N3904, Hfe ~200 for general LF stuff.
Peter
peter_scott is offline
Old 8th Jan 2011, 1:29 am   #14
Skywave
Question Re: Your favourite Transistor, Mine the 2N2926G
Originally Posted by ppppenguin View Post
Many years ago I used to think that metal-cased transistors were always better than the cheap and nasty plastic ones.
Ditto. But, maybe, when the 'cheap and nasty plastic ones' first came along, the then metal-cased ones were superior: I'm not sure.
Al.
Skywave is offline
Old 8th Jan 2011, 1:31 pm   #15
jim_jobe
OC71 RULES!! OK!
Jim
jim_jobe is offline
Old 8th Jan 2011, 2:29 pm   #16
Coastwatch
Originally Posted by jim_jobe View Post
OC71 RULES!! OK!
Jim
BlueTac em' to the spin drier, top to the drum, & spin for 10 mins then scrape off the paint........
Presto a OCP 71
Don't ya just love em'
In the interest of impartiality I should point out that this works with other similar transistors
Old 8th Jan 2011, 2:56 pm   #17
rmslt56
The MOD only bought metal encapsulated ones,Plastic ones were thought not to be water tight.
I have some OC71 clear glass and unmarked but full spec.
Pm if you would like one for the cost a large stamp.
Doug
rmslt56 is offline
Old 9th Jan 2011, 10:13 pm   #18
kalee20
BC107 / BC109 - metal can NPN's (and PNP complements). But these days it's more likely to be BC547 / 9 as the metal can types are getting expensive,
ZTX450 (and now ZTX650 / ZTX850) - astonishing current capability NPN's in E-line package (and their complements).
TIP31 series - TO220 medium power GP transistors (and their complements).
BD131 - really low saturation / pretty fast switching in TO126 package (and their complements).
ZTX600 - low current Darlington.
TIP112 - medium current Darlington.
2N3819 N-channel FET (and complement 2N3820). These are pretty symmetrical.
Unlike most folks above, I don't reach for a 2N3055 when needing a fair bit of power. TO3 isn't a nice package to mount!
But now I'm off to start a 'Favourite Valve' thread.
kalee20 is offline
Old 10th Jan 2011, 1:47 am   #19
Skywave
Arrow Re: Your favourite Transistor, Mine the 2N2926G
Ah! I was just going to do that - before 'domestic issues' got in the way!
Pipped at the Post again!
Never mind - see you there . . . .
Al.
Skywave is offline
Old 10th Jan 2011, 12:01 pm   #20
jim_jobe
Originally Posted by Coastwatch View Post
OC71 RULES!! OK!
Jim
Presto a OCP 71
I bought 100 unmarked OC71s for £1 about 30 years ago and they all had the clear filling so made great OCP71s with the paint scraped off. I still have a few if anyone wants a couple,
Jim
jim_jobe is offline
