7th Mar 2018, 4:07 pm | #61 | |
Re: Is it worth repairing?
7th Mar 2018, 5:06 pm | #62 |
One of the things I've noticed is that some similar hobby areas to radios which use valves have become highly collectible and thus have started to have specialist dealers. For example old valve amplifiers for guitars made by Fender, Marshall etc etc are desirable and still used for their particular sound. This means the valves for them KT88's 12AX7's EL34, 5Y3's are in demand and modern ones (still made in China and Russia I understand) cost about $34 - about the same as you'ld expect from normal cost increases from the old days - say 60's when a valve cost 37/6d. Unfortunately a lot of musicians are not particularly rational and regard the original unused stock from Phillips, Brimar and so on as better quality and supplying better 'tone' than the modern valves. Hence they are willing to pay large amounts for this original stock, just as they are willing to pay 5-10 times the price of a modern electric guitar to get something from the 60's.
This in turn has led to people setting themselves up as dealers in valves primarily to supply the musos with boxed original stock - and of course make a large profit for themselves in the process. Most will be in this area with mercenary intent and unlike the collectors will 'charge like wounded bulls' as the saying goes. Such is the nature of the beast. I find this particularly irrational in view of the fact that any original amplifier from the 50's will have had capacitors, resistors, possibly transformers and speakers and even other parts replaced over time with more modern equivalents and hence any magical 'tone' inherent in the construction will be long altered but there are those fixated on the idea. There is a slight bit of rationality in that the modern Chinese KT88 (or 66; I cannot remember which) cannot handle the high voltages in some old Marshall amps (the 200watt model was particularly bad for this) and can actually explode, hence their modern nickname 'firecrackers'. But otherwise most modern replacements do a good job. So the hobby's economics are altered not just by us radio enthusiasts but also by others using the same technology/competing for the same valves - sadly that seems to be life. But to my mind the emotional worth of doing the repairs far outweighs the financial aspect. |
7th Mar 2018, 6:56 pm | #63 | |
10th Mar 2018, 1:01 pm | #64 |
I find the "treasure hunt" aspect of the hobby one of the enjoyable parts myself. So pleased when I have that "aha" moment!
10th Mar 2018, 9:53 pm | #65 |
That's what I enjoy going to the ham radio fairs. If you are willing to kneel on the grass rummaging in boxes of old valves and components you can sometimes get a surprise like finding 2 nearly new 5 pin + side contact AC/pen's for a pound each.
Often you meet other people rummaging in the boxes and you find they are restoring the same sort of equipment as your interests and then you have a good chat about restoration ECT over a cup of tea. I find restoring valve equipment is not as expensive as some people think if you are willing to take the time to go to radio events get your hands and knees dirty and meet people. Other than the usual capacitors most sets wont really require much more expense unless you are unlucky to have a failed transformer. Cabinet work can be relatively cheap if its a Bakelite case. wooden radios depending on condition are not that expensive to work on, they just need plenty of patience and time to get right. I have only come across a few valve failures and I cannot see any reason to replace all the valves with NOS ones in a radio all in one go as part of a restoration. Most will still have many hours of life left even if their emission is falling. The reliability of most valves is staggering with many doing 1000's hours service on the original valves and still the set works well. With the exception of a handful of valves most mid 30's and onwards valves are still available at a reasonable price. PX4 and other triode output valves are ludicrously expensive though conversely there are not too many radio sets with these valves in. As long as the valve stripper hasn't got to it first, its valve should be there and most likely in a working condition. Christopher Capener
10th Mar 2018, 11:09 pm | #66 |
10th Mar 2018, 11:15 pm | #67 |
I read it as "etc."
[a slip of the 'caps lock' key, maybe?]
"What a depressingly stupid machine." [Marvin: HHGTTG] |
10th Mar 2018, 11:23 pm | #68 |
What you get if you poke your finger in the wrong place in a valve set
13th Mar 2018, 12:41 am | #69 |
I myself love this hobby. I often spend more than a radio is worth in value because of the enjoyment and other benefits I get. Absolutely understand that it may not be worth it to others, in which case it might be a good idea to reevaluate what one really wants to achieve.
Geoff |
13th Mar 2018, 10:12 am | #70 |
Perhaps you have seen this?
https://www.vintage-radio.net/forum/...ad.php?t=95955 I fix radios because I want to. Simples. |
13th Mar 2018, 1:20 pm | #71 | ||
Careful circuit design is important, particularly the position of coupling and decoupling capacitors which can charge up and affect DC bias conditions. What intrigues me about your experience is that different valve examples can change overload behaviour. I can understand that changes of bias conditions would affect the behaviour of different valves in a different way. However, I'd have expected that a (literal) Chinese copy of an ECC83 would behave identically to the Mullard design which it copied. I guess that the first question is just which stage of a guitar amplifier tends to clip first. Is it the power output stage, or somewhere else? Then,what's the impact of any feedback loop behaviour when the open loop gain has been driven to zero by clipping? Steve - As an experienced engineer, have you any theory as to how different valve examples might vary sufficiently to make such an audible difference? Mods - Apologies that this is moving OT. maybe it belongs somewhere else. Martin
BVWS Member Last edited by Hartley118; 13th Mar 2018 at 1:26 pm. |
21st Mar 2018, 4:40 pm | #72 |
Apologies if my claims of musician irrationality upset people, but my main point was that there were more than just radio hobbyists pursuing the old valve stock (saw some old stock ECC83's being offered for $100+ a pair today on the local internet auction site) which will affect the economics of repair.
Mind you one lovely example of musician 'behaviour' I came across a few years back was a liquid being offered at some huge sum. Apparently the idea was if you painted this onto the integrated circuits in your amplifier, it would then sound like a valve amplifier. It was aimed at guitarists and presumably someone thought they would buy it in large enough quantities to have bottles of the stuff made up. I rather regret not buying it and having it analysed. |
21st Mar 2018, 6:04 pm | #73 |
It was probably snake oil
21st Mar 2018, 9:18 pm | #74 |
Varnish sols as snake oil?
21st Mar 2018, 9:19 pm | #75 |
Back on topic please.
22nd Mar 2018, 12:30 pm | #76 | |
24th Mar 2018, 6:01 pm | #77 |
I am a new member here and know very little about electronics, so do not have the knowledge to repair some of the items I acquire.
I have an interest in vintage items for their historical value, workmanship and aesthetics so they are worth saving. These include clocks, radios, phones and record players. I clean them, try to get them working and use them as display items. |
24th Mar 2018, 8:47 pm | #78 |
Hi Mitch, with the assistance of the forum members you should, given time, be able to fix up many more of your acquisitions.
Post your problems here and we will try to help. There are now quite a few forum members in the NE Ed |
5th Jun 2018, 1:06 pm | #79 | |
I've not had any electrical background but I've spent countless hours on the internet soaking up information and asking questions and now I spent very enjoyable time fixing sets. The original post here does miss the point, a hobby such as this doesn't have to be justified as being cost effective or worth doing. Even saying that I think it represent remarkably good value, it can be enjoyed on so many levels, components don't cost much and there's lots of lovely sets still to be had cheap. Look at how much people are prepared to pay out on the average football season ticket or golf club membership!
Clive Last edited by MurphyNut; 5th Jun 2018 at 1:18 pm. |
5th Jun 2018, 2:51 pm | #80 |
I agree with your views Clive. Although I think that this thread began with some very inaccurate and unsupported assumptions, it started a very good discussion about what's possible? why we are doing it? and relative values in general. Of course it's possible to pay as much as you like for anything and high value items exist [the retro craze has contributed] but in general, enthusiasts enjoy creating/restoring something with ingenuity, cooperation and minimum cost. This is very much the ethos of Amateur Radio as well and a great attraction.
Unfortunately it's not always understood, as we have seen quite recently Here on the coast [from the bar] I see people enjoying a low cost sailing hobby in small boats that cost very little and are self maintained by completely ordinary individuals working together yet there is still a [diminishing] belief that sailing requires a particular social standing and deep pockets. Maybe at the Regatta-I do know of one seaside town that has two Clubs [one for the "elite"] but generally the hobby is accessible by anyone at all of good character and intent. Dave W |
