8th Apr 2019, 2:09 pm | #1 |
Maths help....Again...exp?
Vr=(Vp-0.7v)(1-exp(- T/RC))
I don't get the above, however…. ...Vr= ripple voltage ...Vp=AC peak into a rectifier 0.7v= rectifiers forward voltage drop I get that bit....I also get the T/RC bit...Time over Resistance Capacitance.... ….but what's 1-exp? I tried using some exp calculators online but couldn't make much sense of them due to my ignorance but eventually I did manage to find one that I could use and used the result to compute Vr but not by using the above formula (as I see it) I tried other values against known results and my method agreed with them. Here's the calculator I used: https://www.medcalc.org/manual/exp_function.php I entered the result of T/RC into the brackets and hit the button, with that result I divided it into Vp-0.7v I then subtracted that result from Vp-0.7v and got the correct value for Vr as would have been given by the formula in question Excuse my maths dyslexia, I'd prefer a simple answer if it's possible. Lawrence. Last edited by ms660; 8th Apr 2019 at 2:18 pm. |
8th Apr 2019, 3:13 pm | #2 |
Re: Maths help....Again...exp?
I think that particular "exp" is a version of "e" or ~ 2.7183.
..-t/cr e..... is a common expression where time constants are involved. Rather confusing sinc "exp" is commonly used as a workround when superscript isn't an option, like on here. (Bit of cunning formatting going on here 'cos you can't even paste in superscripts as far as I can tell- if you look hard, you can see the white ...s). eg: ..-t/cr e....... ≡ e exp(-t/CR)
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 8th Apr 2019 at 3:24 pm. |
8th Apr 2019, 3:23 pm | #3 |
If this is load ripple, it's easier to work in current and the capacitor and assume the transformer is ideal.
C=dV/dT is easier to work with. dV=ripple ... dt=10ms (for 50Hz). Once you have C you can work the voltages back from the load to the transformer adding dropout for regulator, ripple, two diode drops, load regulation of the transformer, mains voltage variation and a few % of headroom. If I've got the wrong end of the stick, ignore me |
8th Apr 2019, 3:32 pm | #4 |
Isn't dV/dt = i/C the expression needed? Or for constant current, V = it/C
8th Apr 2019, 3:39 pm | #5 | |
I'm still no further forward with 1-exp. Lawrence. |
8th Apr 2019, 4:17 pm | #6 |
The function you describe relates to ripple voltage on a capacitor loaded with a resistance, rather than a constant-current.
exp(x) here means e (the base of natural logs) raised to the power of x. exp(-t) is a very general function that describes the exponential decay of a value as t increases. This occurs widely in the physical world, where the rate of decay is proportional to the instantaneous value. At t=0, exp(-t)=1, indicating that the decaying property is at its full initial value. As t increases, exp(-t) falls towards zero following the exponential decay curve. exp(-t/RC) describes the decay of the voltage on a charged capacitor as it discharges through a resistance, as a fraction of the initial voltage. Vp(exp(-t/RC)) gives the voltage at time t, as it falls from the initial peak charging voltage Vp. If one assumes the ripple voltage to be sawtooth-like, where the capacitor charges in negligible time and then discharges into a constant resistance, the ripple voltage will be the difference between the peak voltage, and the voltage to which it has fallen by the beginning of the next charging impulse, which we are considering to be time t. Hence, Vr = Vp(1-exp(-t/RC)) For small values of ripple, it is not necessary to compute the exponential, since the discharge current is approximately constant, as mentioned above. Last edited by Lucien Nunes; 8th Apr 2019 at 4:25 pm. |
8th Apr 2019, 4:19 pm | #7 |
That formula looks like the output voltage assuming a DC input. The ripple would be 0 without load current yet the load is not in your equation.
Try cheating http://www.duncanamps.com/psud2/ |
8th Apr 2019, 4:23 pm | #8 |
Chris (Herald1360) is right that exp is the exponential function. It's like other functions in that you put a number in (in this case -T/RC) and get another number out. The output number in the case of exp varies from 1, when the input is 0, smoothly down to 0, when -T/RC is very large.
So 1-exp(-T/RC) varies the other way i.e. when -T/RC is very small (usually because you've got a big R and/or a big C, which makes a very effective ripple filter) the ripple voltage will be close to zero. If, on the other hand, you've got very small resistance and capacitance, so -T/RC is very large then exp(-T/RC) will be close to zero, 1-exp(-T/RC) will be close to one and the ripple will be the full AC input minus just the diode voltage drop. Cheers, GJ
http://www.ampregen.com |
8th Apr 2019, 4:35 pm | #9 |
How to calculate it? Do the brackets first. So, work out T/RC and change sign to get -T/RC. Then hit e^x which will give you exp(-T/RC). It's a number less than 1. Put it in memory. Clear the calculator, enter 1 - (memory) and hit equals, you now have (1 - exp(-t/RC)) which is also less than 1. Put it in memory, overwriting previous result. Clear the calculator. Work out Vp - 0.7v (easy) and hit equals. Then multiply by (memory) giving you what you want! Last edited by kalee20; 8th Apr 2019 at 4:36 pm. Reason: Clarity |
8th Apr 2019, 4:51 pm | #10 | |
Lawrence. |
8th Apr 2019, 5:11 pm | #11 |
Here's a table of exponential functions from my old School log tables! Go down the left hand values of x to the nearest value of T/RC and read off the value in the second column [e to the minus x]. It should give adequate results, unless you are using close tolerance components.
8th Apr 2019, 5:13 pm | #12 |
Hi Lawrence,
No problem... Here's one of many online scientific calculators. You can transcribe the calculation as it unfolds, with pen and paper, if that helps keep track of it. Cheers!
Al |
8th Apr 2019, 5:19 pm | #13 |
exp(x) = 1 + x + (x^2)/2 + (X^3)/6 + .. successive terms are (x^n)/n! where n! = n(n-1)(n-2)....3*2*1
If T/RC is much less than 1, then exp(x) is approximately 1+x. This will be the case when (x^2)/2 is much less than x Your formula then becomes Vr=(Vp-0.7v)(T/RC)) HTH and 73 John |
8th Apr 2019, 5:23 pm | #14 |
Here's the example numbers for the formula I posted:
Vp = 15 volts T = 0.01667 secs. R = 5,000 ohms. C = 100uF The answer given according to that formula is Vr (ripple voltage) = 0.47 volts but I can't get that formula to work as it's written ('cos I don't fully understand it) so here's what I did: Work out T/RC, easy for me.....0.01667/0.5 which = 0.0333 Bung that into the exp calculator I used, that returns an answer of 1.0338 Divide that into Vp-0.7 (14.3) that = 13.83 Subtract that from Vp-0.7 (14.3) = 0.47 volts ripple That's the same answer as was given by the formula that I don't yet fully understand. Here's the site I got the formula and example from: http://tuttle.merc.iastate.edu/ee201...rectifiers.pdf I've used the other examples given for R and using the above method everything more or less tallies up with the given answers. Lawrence. |
8th Apr 2019, 5:35 pm | #15 |
I think you've forgotten to change the sign of the (-T/CR) term.
The original formula works for me : -T/CR = 0.01667/(5000*100*10^-6) = -0.0334 (I think that's where you got the sign wrong). exp(-T/CR) = .9672... 1-exp(-T/CR)=.03279... Vp-0.7=14.3V So (Vp-0.7)*(1-exp(-T/CR)) = 0.47V or thereabouts. There is no point in me giving the key sequence I used, I am using an HP RPL calculator... |
8th Apr 2019, 6:14 pm | #16 |
I get lazy and chuck this sort of thing at ltspice https://www.analog.com/en/design-cen...SAAEgLmbfD_BwE warning... you can spend hours experimenting and looking at waveforms.
8th Apr 2019, 6:20 pm | #17 | |
Lawrence. |
8th Apr 2019, 6:35 pm | #18 | |
Geoff |
8th Apr 2019, 6:36 pm | #19 |
Lawrence, what is the circuit you are trying to model? Is it a PSU design and you are trying to determine the ripple voltage on the HT? If so, your model is far too simple and you need to look at the PSU designer link I gave you. Choose your PSU design, enter some values, and the PSU designer will tell you all you need to know.
8th Apr 2019, 6:51 pm | #20 | |
Lawrence. |
