Old 21st Apr 2014, 2:31 pm   #21
dodgy-dxer
dodgy-dxer's Avatar
Default Re: Chinese valve FM receiver kit
Richard
My rusty brain started working
I have asked my "Man in Macau" to take a look! He is both Chinese and RF professional/technical, although not a ham
Fred
dodgy-dxer is offline
Old 22nd Apr 2014, 1:45 pm   #22
dodgy-dxer
dodgy-dxer's Avatar
Dear Richard
This is what Stephen has sent to me:-
Hi Fred,
here is what it means:
(was jpg of that part of the message in his email text)
L1 - use diameter 1mm wire and make 2 turns
L2 - use diameter 1mm wire, use an AA battery as a core to make 4 turns, then take away the battery
so i think you are right.
Good luck
Fred
Old 22nd Apr 2014, 3:50 pm   #23
Courtney Louise
Courtney Louise's Avatar
would you use the battery to make L1 also?
33, 45, 78, around and around they go...
Courtney Louise is online now
Old 22nd Apr 2014, 5:05 pm   #24
mole42uk
mole42uk's Avatar
I think I probably will use the AA battery for L1 to see if it works and may modify it if necessary.
The thing about L1 is that it needs to match an aerial into the circuit at about 100Mc/s and, of course, there's no specification for the aerial.
Lots of speculation here in Bristol!
Richard
mole42uk is offline
Old 22nd Apr 2014, 5:07 pm   #25
mole42uk
mole42uk's Avatar
Thanks Fred!
I can see I'll now have to switch the soldering iron on....
Richard
mole42uk is offline
Old 22nd Apr 2014, 6:28 pm   #26
Courtney Louise
I have one of these kits too but havent started it yet
Old 22nd Apr 2014, 8:19 pm   #27
mole42uk
mole42uk's Avatar
You also bought one of the amplifier kits I remember - did that go together okay?
Does it sound good?
Richard
mole42uk is offline
Old 23rd Apr 2014, 7:38 am   #28
Courtney Louise
Went together fine and have just bought the matching 4 input preamp. It sounds outstanding to be honest. I use it a couple of hours a day as my bedroom sound system.
Old 23rd Apr 2014, 11:48 am   #29
Hybrid tellies
Hybrid tellies's Avatar
Looks like an interesting project. I will be amazed if it works where I live, as FM reception can be challenging to say the least. But with my birthday coming up I could be tempted to put an order in.
Simon
BVWS member
Hybrid tellies is offline
Old 23rd Apr 2014, 3:10 pm   #30
mole42uk
mole42uk's Avatar
Well, I'm soldering it together today so, as soon as the HT batteries arrive we'll see....
I'm in my workshop in the centre of Bristol just now where the little radio will get it's first test, and then I'll see what happens at home, near Westbury-on-Trym. VHF broadcast signals are not too bad in the city centre, but it's a bit more trouble at home.
Richard
mole42uk is offline
Old 23rd Apr 2014, 4:12 pm   #31
Courtney Louise
I was contemplating running mine on one of those cheap nixie clock power supply boards from a 9v adapter. They should be adjustable down to about 100v and then use something to drop another 10. The 1A2 is rated at 90v max.
Old 23rd Apr 2014, 5:58 pm   #32
mole42uk
mole42uk's Avatar
I thought about a power supply like that, but I bought ten PP3s for less than 50p each, so why not? If I solder seven of them together it's a portable receiver!!
I was interested to note the HT on the diagram calls for 67 volts which is the old 467 battery size. I wonder if someone in China is making them? 67.5 volts is also the rated maximum for g2 + g4 + a when the valve is used as an oscillator.
mole42uk is offline
Old 23rd Apr 2014, 7:55 pm   #33
Courtney Louise
If it would manage on 60v then you could try 5 of the 12v car alarm fob batteries.
Old 23rd Apr 2014, 11:43 pm   #34
That would be small, but I bet it's more expensive than 7 cheap PP3s.
Herald1360 is offline
Old 24th Apr 2014, 6:52 am   #35
Courtney Louise
not if you get them from the same place the radio kit came from. £5 or less for 10
Old 6th May 2014, 6:01 pm   #36
Courtney Louise
Hi Richard, how have you got on with this?
Old 6th May 2014, 7:38 pm   #37
mole42uk
mole42uk's Avatar
I finally received the batteries today and connected them - 'D' cell for the heater and 7 x PP3 for the HT
Audio out was disappointing, although the kit seems to give some signs of life (motor boating at certain combinations of variable pot and variable capacitor) but nothing resembling a received signal.
More information as soon as I have something to report.....
I got sidetracked this evening tracking down a couple of high-value resistors in my Murphy A188C so the little Chinese kit has to wait!
Richard
mole42uk is offline
