30th Jun 2020, 1:28 pm | #1 |
Oscilloscope No. 11 A.A. Predictor
Hi folks,
A kind friend just gave me this beast, I wonder can anyone tell me what it can do and what it was used for? I believe its something to do with an Anti Aircraft Gun? It seems in very good condition but someone has put tape over the original dial paintwork, I assume as it had worn away. There are some hefty valves in there! I haven't turned it on yet.... Thanks, Nick |
30th Jun 2020, 5:24 pm | #2 |
Re: Oscilliscope No. 11 A.A. Predictor
Some previous threads here: https://www.vintage-radio.net/forum/...d.php?t=155926
30th Jun 2020, 6:28 pm | #3 |
Nick, I had a long running thread on this 'scope. I took it over from "Electronwilly" who started it back ion 12th Dec 2012. I had another thread on just the pine cabinet back on 13th Feb 2017. I've all the documentation & the thread posts hold heaps of photos.
Regards, David |
1st Jul 2020, 10:44 am | #4 |
Re: Oscilloscope No. 11 A.A. Predictor
Hi Nick,
It's looks to be in very good condition, even to the extent of the component numbering still being there and it has survived some 60+ years. It would be nice to think of it continuing to survive, unchanged as a mark of the state of the art then. . Some future historian would be very excited about it as a mark of 1950s military technology. We won't live to see this though. These days it has no real use and even powered up all you get is a trace on the screen. The value of it's components is low especially when compared to it's future value as a historical object. I'm not sure I have made a good case, or even a coherent case, but I hope you get my idea. Regards. |
1st Jul 2020, 10:59 am | #5 |
Hello again Nick, My old wooden cased 'scope was the predecessor of yours. After the Battle of Britain in 1940, it was decided by the War Office that the mechanical/optical AA predictors weren't that good. So the push was on to change to a Radar system. These 'scopes were used for setting up & calibration. Your version carried on into the early '50's, but became obsolete due to the change from AA guns to ground to air missiles.
Seemingly, loads of the two versions of 'scopes were floating around the ex government surplus shops in the 50's & 60's, but now are pretty rare. Regards, David |
1st Jul 2020, 3:13 pm | #6 |
It looks like some attempt had been made to use it for something, judging by the labels. Does your friend have any recollection?
17th Jul 2020, 12:56 pm | #7 | |
17th Jul 2020, 12:56 pm | #8 |
17th Jul 2020, 1:01 pm | #9 | |
Hi it is definitely staying in one piece, and its being donated to our local aviation and military museum at the airport for display, as they actually have an AA gun and associated Radar trailer, but don't have this unit! It has been looked after so well considering its age I agree. I did turn it on and hid behind the garage door. It did power up briefly and the valves glowed lovely, then there was a fizzt..pop and the mains cap blew, tripping our house electrics, blowing three fuses in the board.... a lesson to us all there Nick |
17th Jul 2020, 3:16 pm | #10 |
That control labelling looks to be glued over the original, with luck and care they should be removable.
17th Jul 2020, 5:20 pm | #11 |
The tube doesn't look to have a side-contact base, so that rules out VCR138.
3BP1, maybe? Likely targets for modification might have been an oscilloscope in general terms, but I wonder about some form of modulation indicator for amateur radio? Several projects have been published and both ARRL and RSGB handbooks in the sixties included designs. It's probably of more interest if put back to original... at least in appearance and as Bill says, those labels look awfully tempting. David
19th Jul 2020, 6:33 pm | #12 |
Oscilloscope No 11. CRT
Someone suggested ACR10, which is the VCR139A or Mullard ECR30 or Cossor/Etel 23D or GEC 701A or E4205. All CV279, CV964, CV1588. Tube has pins on the base. 70mm/ 2.75 diam screen. So the mentioned 3inch tubes like 3BP1 will not fit and are too long anyway. The VCR138 or ECR35 is a 3.5" tube, with the solid side contact base, not pins. The VCR139 is a much derided tube.But it is short and small and surprisingly useful as an indicator. The first scope I built used it, and gave a wonderfully small scope, compared with what we had subsequently. wme_bill |
21st Jul 2020, 2:52 pm | #13 |
I have a VCR139A available if anyone is looking for one
- Julian It's good here |
24th Jul 2020, 11:04 am | #14 |
The device has now been donated to the local military and airfield museum here on the Isle of Man. Which is going to be on display connected to an AA Gun predictor and Morris Self-Propelled Bofors Gun truck. Very cool.
http://www.maps.org.im/morris-commer...p-bofors-gun-0 Thanks all for the advice! |
