Old 26th Feb 2013, 9:02 pm   #21
emeritus
Default Re: Vintage Drills
Yes, the workshop came first. My father got one when it first came out. The manual (which I still have somewhere) contains an illustration of a Selecta drill being used with the workshop, but the caption said that the drill was "available later".
emeritus is offline
Old 26th Feb 2013, 9:28 pm   #22
elanman99
elanman99's Avatar
Another electric tool manufacturer was 'Arcoy'. I posted a picture of one that I have last March (this should link to a picture of it)
https://www.vintage-radio.net/forum/...6&d=1333053878
Arcoy also made larger drills (Buccaneer series) as well as a planer. Another product they made is a dovetailing jig which even after all this time seems to much in demand considering how many change hands on auctions sites.
elanman99 is offline
Old 27th Feb 2013, 10:30 pm   #23
Oldtools4ever
Thanks for the pdf scanned docs, they have clarified a few details which I had'nt grasped. I remember that my father originally had a B&D single speed 3000rpm Drill /Sander/Polisher ( I think the model No was U-300) which just about managed to produce mortises using a 1/4inch straight router bit in incremental passes. The chuck was hand tightened and locked with a hex grub screw.
I did not know of the lathe set up parts or the comb jointing and dovetail equipment.
The Arcoy dovetailing jig produced and still does make exellent dovetails.
Oldtools4ever is offline
Old 1st Mar 2013, 12:10 am   #24
emeritus
I still haven't found the Selecta manual, but have unearthed the "General Arrangement Drawing" that was supplied in its own brown envelope. The original is on one side of an 11 1/2" x 18" sheet.
emeritus is offline
Old 2nd Mar 2013, 11:44 pm   #25
emeritus
Re post #21, I have now dug out the manual, and find my memory was incorrect: the "available later" item was the dovetail jig, not the drill. To fit a "Selecta" drill, it was necessary to replace the front casting by a special casting: see page 6. It recommends the use of a higher speed than the usual 2500 - 3000 RPM for routing and grinding, but does not say that the Selecta drill can provide this: a marketing opportunity lost, or did they make an earlier model without the high speed setting?
Name:	Selecta  Manual cover .jpg
emeritus is offline
Old 12th Mar 2013, 2:52 pm   #26
FIXITNOW
FIXITNOW's Avatar
Pictures of a Desoutter drill I picked up a few weeks ago. A quick rewire and saftey test and one good working mini drill.
ID:	77369   Click image for larger version
ID:	77370   Click image for larger version
FIXITNOW is offline
