Old 6th Dec 2017, 8:43 pm   #1
kirstyd
Default Fidelity HF?
Hi all
this machine has developed a fault. It will play well for about five minutes and then the sound distorts. Switching off and on cures the fault for a few minutes and then it happens again. When i got this machine it was a complete wreck but it did have a working amplifier so apart from replacing the cut off flex i have done nothing to the amp. Tested the cartridge in another machine and its fine. Any ideas guys? Not sure what model it is because the label was missing along with some of the Rexine. In one of the photos i am pointing at a capacitor that's looking a little rough.
ID:	153518   Click image for larger version
ID:	153519   Click image for larger version
ID:	153520   Click image for larger version
ID:	153521   Click image for larger version
kirstyd is offline
Old 6th Dec 2017, 8:49 pm   #2
RojDW48
RojDW48's Avatar
Default Re: Fidelity HF?
Smoothing capacitor on the way out? Did you hear any 'ripple' as part of the distortion? Not suggesting you switch it on again if that is the problem.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 6th Dec 2017, 8:58 pm   #3
kirstyd
No .the sound just starts to degrade about half way through the record 2 or 3 minutes
kirstyd is offline
Old 6th Dec 2017, 8:59 pm   #4
Techman
Techman's Avatar
Spray some freezer spray on that chip when it does it
Techman is offline
Old 6th Dec 2017, 9:42 pm   #5
Ed_Dinning
Resistors used in these amps were also not of the best quality and end caps could have bad connections.
Ed
Ed_Dinning is offline
Old 6th Dec 2017, 9:59 pm   #6
kirstyd
Well it seems like it was the smoothing cap after all .I replaced it [temporarily] with another and its been happily playing 45s for the last half hour .however this is the first time i have seen a capacitor rated this way [25 volts /1mO ] as apposed to MFDS .Can you explain please
kirstyd is offline
Old 6th Dec 2017, 10:48 pm   #7
Tom_I
Tom_I's Avatar
I think it's just that the unit (in this case millifarads) is used in place of the decimal point, as is often done with resistance values, so that the rating of the component can be expressed in only three characters.
So 1m0 is 1.0 mF, or 1000 uF. 4700 uF, or 4.7 mF would be 4m7, etc.
Tom_I is offline
Old 6th Dec 2017, 10:55 pm   #8
kirstyd
Thanks Tom. The one I put in is 1500 mfds. Will it be OK or shall I change it?
kirstyd is offline
Old 6th Dec 2017, 11:38 pm   #9
It'll be fine. The original 1000uF will simply have been the smallest value (cheapest part) that the designer could get away with.
Herald1360 is offline
Old 7th Dec 2017, 12:49 am   #10
RojDW48
RojDW48's Avatar
Good news! Possibly just in time! You have done a lovely job of restoration - it looks very good.
RojDW48 is offline
Old 7th Dec 2017, 11:58 am   #11
Edward Huggins
Fidelity HF?? - I'm 99% sure this is a Fidelity HF45. The single chip amplifier version came in about 1967-68.
Edward.
Edward Huggins is offline
Old 7th Dec 2017, 10:58 pm   #12
kirstyd
Thanks Edward. I was thinking early 70's the deck being only a three speed. It was a total wreck when I got it. Part of the rexine was torn off. The knobs were missing along with its flex and the arm had been snapped off. It was originally a grey colour. I have to say it sounds rather good especially for a Fidelity. My grandson wanted one of those Crosley crapophones for Xmas. Well let me tell you he isn't getting one he is getting this instead.
kirstyd is offline
Old 7th Dec 2017, 10:59 pm   #13
Nuvistor
Nuvistor's Avatar
It does look good, like new.
Frank
Nuvistor is offline
