Old 20th May 2017, 10:36 pm   #1
tracypaper
tracypaper's Avatar
Default Fidelity HF4 missing valve ID please
Hi all.
Trying to identify a missing valve from above mentioned player.
It has an EL84 in situ but the other valve (I assume the rectifier) is missing, it has a smaller diameter base than the EL84 and has 7 pins,
Pin 1 is connected to a red wire from the transformer and linked to pin 6,
Pin 3 links to pin 5 of EL84 and is also connected to bulb and a different wire on transformer.
Pin 7 goes to one of the 32ufs in the can.
The other two different wires from transformer go to chassis.
Also while i'm here the wire wound resistor connecting the two 32ufs in the can is reading over 1000ohm but the colours are suggesting 10? or 100ohm not too sure has it may have burnt a bit.
Cheers.
Gaz.
tracypaper is offline
Old 20th May 2017, 11:55 pm   #2
Peter.N.
Default Re: Fidelity HF4 missing valve ID please
Don't remember seeing a B7G rectifier, if it exists it would be an EZ90 or something similar.
Your smoothing resistor sounds about right, I would suggest that the red has turned brown.
Peter
Peter.N. is offline
Old 21st May 2017, 12:23 am   #3
Michael Maurice
Michael Maurice's Avatar
It sounds like an EZ90 wired for half wave rectification.
http://www.r-type.org/exhib/aaa0433.htm
Forum Moderator
Michael Maurice is offline
Old 21st May 2017, 9:34 am   #4
Edward Huggins
Yes, it will be an EZ80 (6X4) that is missing. These early Fidelitys used mains isolated amplifiers and were a better quality build than the later models.
Edward.
Edward Huggins is offline
Old 21st May 2017, 10:45 am   #5
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
If the 'empty' Valve base is a B7G, then, surely, Michael Morris is right, the rectifier will be an EZ90 maybe wired as a Half-Wave Rectifier
'LIVEWIRE?' is offline
Old 21st May 2017, 11:27 am   #6
tracypaper
tracypaper's Avatar
Thanks guys.
Now on the hunt for an EZ90.
Gaz.
Old 21st May 2017, 11:36 am   #7
Edward Huggins
Originally Posted by tracypaper View Post
Thanks guys.
Gaz.
Oppps - I meant EZ90, but at least got the 6X4 option right. I like these early Fidelity's, their only weakness (as with Dansettes) is the perilously small OPTX.
Edward.
Old 21st May 2017, 11:40 am   #8
ukcol
ukcol's Avatar
I believe MALC SCOTT owns an HF4 it may be worth sending him a PM for a definitive answer.
Edit: Gaz, I have two 6X4s listed in stock, If it is definitely an EZ90 (6X4) you want I will test them and send you one for the cost of postage.
ukcol is offline
Old 21st May 2017, 8:55 pm   #9
electrogram
IIRC this model does not have a mains isolating transformer, just a heater transformer.
electrogram is offline
Old 22nd May 2017, 9:15 am   #10
Edward Huggins
Wow, that's news to me. I have always thought the secondary was isolated.
Edward.
Old 22nd May 2017, 8:39 pm   #11
tracypaper
tracypaper's Avatar
MALC SCOTT contacted awaiting confirmation reply.
Gaz.
Old 2nd Jun 2017, 8:43 pm   #12
tracypaper
tracypaper's Avatar
Valve received from UKCOL, Thanks Collin.
Amp now working.
Gaz.
