4th Mar 2021, 11:53 am | #1 |
Replacement idler wheel for Collaro Studio
I'm trying to resolve an issue with the speed change on a Collaro Studio autochanger. There's a few issues here but the rubber ln the idler wheel is not great so Im looking to see if theres any compatible replacement, for example if there are ones marked as BSR that the collaro would take, same diameter etc?
An online search doesn't prove fruitful for a Collaro Studio idler. |
4th Mar 2021, 12:20 pm | #2 |
Re: Replacement idler wheel for Collaro Studio
The are two rubber drive wheels in your Studio. Both can be refurbished and there are various methods to achieve this. I would recommend, and as a low cost fix, by having these skimmed. Having suggested this, I do know that some Members here do not favour this approach. You cannot use the BSR idlers.
Edward. |
4th Mar 2021, 1:10 pm | #3 |
A first suggestion would be to lightly use a very fine flower/sand paper and carefully wipe the edge so roughing up the area that meets the idler. Make sure you wipe clean after using a clean cloth, dampened slightly with clean water or pure alcohol.
"I really am seriously downsizing " |
4th Mar 2021, 1:32 pm | #4 |
I wondered if sanding might help, one reason I did want to replace is that someone at some point has put the metal platter back on and pushed down, while the edge of the idler wheel was out near the edge. A crack can be seen at thw edge (maybe the outer 3mm) and the rubber is bending away. My worry is that sanding might weaken the area further and cause this fragile edge to shear off while the turntable is in operation.
Definitely worth a try before I give up on it but would be nice to know a replacement could be found if worst happens. |
4th Mar 2021, 2:24 pm | #5 |
Yes, I can well understand how it got badly crimped on this turntable. You could have it expertly skimmed so as to take the whole 3mm off and get back to the good solid rubber. You really can't do this with sandpaper. Reducing the diameter will not affect performance as these are "intermediate" wheels.
Edward. |
4th Mar 2021, 2:57 pm | #6 |
Collaro idlers have become difficult to get in useable condition.
You can of course send yours off to get it rebuilt but at a cost. If your idler is held on with a small screw and is 2.1/2" diameter then you might look for spares for Collaro reel to reel decks as these parts seem to come to market more often than turntable spares. Don't expect them to be cheap though, some Collaro decks now have a following and these idlers are in demand. It might be more reasonable to get another deck, if you can determine the condition of the idler. FWIW, I have in the past made a similar request to yours with no response. Luckily managing to get spares from a r2r deck. From your description, your idler would not appear to be suitable for the edge to be skimmed or trued up, 6mm off the diameter might be too much. Alan |
7th Mar 2021, 12:47 am | #8 |
I tried sanding the edge very lightly to bring up the rubber surface again but in the end the contact between idler and motor pulley was inefficient due to a very loose spring on one of the metal arms underneath.
This wasn't springing it into the place up against the motor pulley. Have adjusted and all seems to be in better mechanical order. Thanks to all for advice. |
