31st Jan 2011, 1:05 am | #1 |
R1155 model E (we think it's model E, certainly an R1155)
Gentlemen and Ladies,
This is my first post and I expect a delay before it "goes live". We have a beautiful R1155 - model E as we recall - together with its original power which works perfectly. Forgive me for being mercenary, but military radio is not a particular interest of ours, but having a 1932 model "sunrise" restored and working radio in good condition is. Would you please let me know what you think in terms of value? I know nothing about vintage radios and seek your advice and comments. Regards, goodfortune Last edited by paulsherwin; 31st Jan 2011 at 2:00 am. Reason: Edited to comply with forum rules |
31st Jan 2011, 8:18 am | #2 |
Re: R1155 model E (we think it's model E, certainly an R1155)
Can you explain what you mean by 'together with its original power which works perfectly' - the original power supplies were either two rotary converter power units (also powering the T1154 transmitter) in an aircraft, or two big and heavy (very heavy!) mains ground power units.
Andy |
31st Jan 2011, 10:03 am | #3 | |
Regards, goodfortune |
31st Jan 2011, 11:07 am | #4 |
Pictures?
Alan |
31st Jan 2011, 11:08 am | #5 |
It sounds like you have the original ground station power supply. Could you post some pictures .
Mike |
31st Jan 2011, 12:06 pm | #6 |
R1155s seem to be flavour of the month as an R1155N recently went for a staggering £640on eBay and previously another made well over £200. Both unmodified and in good condition with all the DF intact but no PSU. I think that one of the war surplus sellers (in Lisle Street?) offered a PSU in the 60s.
31st Jan 2011, 1:36 pm | #7 |
If your power unit is 'two feet tall and jolly heavy' it does sound like one of the two units comprising Power supply Type 114. This supplies the receiver HT and also enough LT for the receiver and transmitter (the other unit supplies 1200v EHT for the Tx). This PSU is well worth preserving, but proably less than ideal for running a receiver alone. Apart from its size and weight, it uses selenium rectifiers (also for the LT supply, which is DC for the Tx valves) which might be dubious due to age, and conflicts in various ways with what would be considered basic good design nowadays from a safety viewpoint.
Andy |
31st Jan 2011, 1:57 pm | #8 |
If it is one of those then it'll have some changes in he wiring to make it work without the transmitter. The wiring is set up to come out of the LT power supply and go to the transmitter and thence to the receiver. The on/off switch is on the transmitter. So unless the cabling was modified to effectively permanently switch it all on once the on/off switch on the front of the LT module was made, it wouldn't work.
Robin G5HI |
31st Jan 2011, 2:49 pm | #9 |
Robin,
Agreed! We need some pictures. Andy |
31st Jan 2011, 9:55 pm | #10 |
Well, I'm delighted that you are interested. I shall take some pictures and come back to you. They won't, I afraid, be good pictures, as I'm not strong enough to lift the receiver into the light and the big, heavy box will have to be "walked" from where it is.
Back shortly. goodfortune |
31st Jan 2011, 10:11 pm | #11 |
31st Jan 2011, 10:55 pm | #12 | |
Hi all
In the ignorance of youth (Mum and dad didn't even meet till well after the war) I thought they were all like that until I saw one in, if memory servers, the nose section of a Lancaster in the Imperial war museum. So the box in question could be one similar to mine. TYJ
"If we are not going to make things, what are we going to do?" Fred Dibnah |
31st Jan 2011, 11:03 pm | #13 |
I'm pleased that you are interested in this and very much appreciate your comments.
Before going further I should apologise for trying to post photos which were too large. They have now been reduced, successfully I hope. Regards, goodfortune |
31st Jan 2011, 11:32 pm | #14 |
Good evening GF. You are creating a stir with your set and it's [I think largely unknown] original power supply unit [PSU]. Most restorers usually have to create their own dedicated PSU to get these going but certainly not of that size-perhaps less than half that of the reciever itself! See other threads on here. It's interesting that you were told not to let the cases touch. This may [or not] relate to an unusual arrrangement in the 1155 in which the negative side of the Power Supply is "floating" rather than attached to the chassis and therefore incorrect connection can be bad news. I wonder if this has anything to do with your comment? It will be interesting to see what the many expert technicians have to say. My own, as yet unrestored set, has a 1950's ad hoc power unit that is definetely unsafe.
Dave Walsh Last edited by dave walsh; 31st Jan 2011 at 11:38 pm. |
1st Feb 2011, 3:06 am | #15 |
I doubt this is an original power unit - as the case on that should be ok for touching....
The problem with the R1155 is that the receiver cabinet and chassis are at Bias potential (in some cases about 40v above ground - not dangerous, but painful if not expecting it, and makes the rx very deaf if the bias rail gets shorted!
1st Feb 2011, 3:29 am | #16 |
I can never get my mnd around a perfectly safe psu for the R1155. Any psu made in a metal chassis has to be earthed to ensure a ht fault making the chassis or metal case live.
Hence an earthed case can never be in contact with a R1155 chassis. Am I missing something ?or are weforgetting that in 60's or earlier the "nanny state" did not exist Mike Last edited by MichaelR; 1st Feb 2011 at 3:30 am. Reason: spelling |
1st Feb 2011, 8:34 am | #17 |
In the absence of any pictures yet, I would put money on the PSU being the HT/LT unit of the PSU Type 114 - the description that it has to be 'walked' from where it is sums it up! I have both units, and have to move them the same way.
I'm puzzled by the comments about not letting the cases touch, and Sean's comment that the Rx chassis is at bias potential about 40v above ground. The chassis of both Rx and PSU should be earthed (therefore can touch). The HT- then sits at the bias potential below ground and is not earthed. There should be no connection in the PSU between HT- and the chassis - the supply circuit being isolated from the PSU chassis, which should be earthed. Andy |
1st Feb 2011, 10:09 am | #18 |
Quite right Andy, the chassis is at earth potential, it also serves as the return for the heater supply. Both HT+ and HT- are floating WRT chassis.
Neil
1st Feb 2011, 10:10 am | #19 |
"In essence an isolated output".....exactly.
Mike |
2nd Feb 2011, 9:54 pm | #20 |
I do apologise gents, I posted a few pictures (then realised they were too large, so reduced to "small size" and posted again but they still haven;t arrived on the thread.
Have you any suggestions? Would it be better if I posted one photo per post or have I angered the Gods and been chucked out for too many demerits? I really do appreciate your comments and hope you will bear with me. Regards, goodfortune |
