10th Mar 2009, 6:59 pm | #1 |
Where does this go then? (Philips 555A component)
I've decided to re-start work on a very tired-looking and previously "got-at" Philips 555A.
There is a lot of work to do; much of the wiring needs replacing, the output transformer is scrap and someone has changed the original valve line-up. That said, it's a good challenge and using a replacement O/P transformer I managed to get some sound from it the other day, so I'm pursuing things! I've removed the main tuning capacitor assembly for cleaning (it was covered in some very unpleasant grease) and came across what I think is "C33" per the trader sheet (724). Take a look at the photo attached. C33 is the oscillator circuit LW trimmer and has a very low mfd rating (0.00003). According to the trader sheet, the capacitance of this component is altered by changing the number of windings around the plastic former. My question is whether the loose end (highlighted in red) actually goes anywhere? Any help would be welcome! Thanks Andy |
10th Mar 2009, 7:25 pm | #2 |
Re: Where does this go then? (Philips 555A component)
The short answer is no, it doesn't go anywhere. You just unwind it to reduce the capacitance.
10th Mar 2009, 7:39 pm | #3 |
Excellent - thanks for your help!
