20th Nov 2008, 12:32 pm | #1 |
Sensitivity of broadcast/domestic and communications receivers compared.
This is a general question. What is the approximate difference in sensitivity between a decent vintage communications receiver and a decent broadcast receiver? Is it twice as good, five times as good, or greater?
Please can you give an illustration in uV or mV that can be resolved at the first RF stage. Also, what other features (electronically) does a comms receiver have that are not found in a domestic receiver with a shortwave capability? Obviously I'm taking selectivity for granted. Period can be WWII onwards.
Al Last edited by Station X; 20th Nov 2008 at 12:54 pm. Reason: Title Changed. |
20th Nov 2008, 12:55 pm | #2 |
Re: Sensitivity of broadcast/domestic and communications receivers compared.
Googling "Communications Receiver" will probably reveal a lot about their features.
20th Nov 2008, 2:00 pm | #3 |
Hi Astral -
That is a broad Q. which could take a lot of space to answer fully. Graham's comment above should provide some answers. Might I also respectfully suggest that you acquire a few classic text books on the subject of Receiver Design *. These will really help - and probably also provide answers to Qs. you haven't thought of yet! * A quick glance at the bookshelf above me suggests: Terman, Radio Engineering (& others); Scroggie, Foundations of Wireless; Langford-Smith, Radio Designer's Handbook; various by the RSGB or ARRL; Radio & TV Engineers' Reference Book, Hawker & Pannet; Electronic Communications Systems, Kennedy; Communication Engineering, Everitt & Anner - to name a few. Al. / Skywave. |
20th Nov 2008, 2:28 pm | #4 |
Thanks Al. That is a helpful reading list, although with my other priorities, I'm frankly unlikely to have the chance to get through any of that any time soon.
I have owned my own LOWE in the past, so I'm practically familiar with what a comms rx can do, its selectivity and its noise rejection capabilities, and of course I know that it can resolve SSB, whereas a broadcast receiver can't. I do have an overwhelming curiosity over the comparative sensitivity issue and can't now (having got rid of the LOWE) compare performance against performance. Even a rough estimate of the relative sensitivity would be a great help.
Al |
20th Nov 2008, 3:39 pm | #5 |
Well, taking one good and reputable but decidedly "domestic" receiver, the Hacker Super Sovereign, its spec. includes:
AM sensitivity - MW/LW 3-7 microvolts for 10 dB S/N SW1 (10.9-33m.) 5-8 microvolts for 10 dB S/N SW2 (27.5-89m.) 4-7 microvolts for 10 dB S/N. I don't know how readily other available figures will lend themselves to comparison. Regards, Paul |
20th Nov 2008, 5:29 pm | #6 |
Paul - To me, those figures look pretty impressive for a "domestic" receiver; they seem comparable to a mid-range comms. RX.
Astral - Yes, agreed - it depends on what one's priorites are; we all have our responsibilities & hobbies. One of my hobbies is collecting old radio books and studying theory. My real point to you is that by acquiring a couple of publications such as these, you don't have to read them from cover-to-cover in one sitting! Just keep them handy as a readily available sources of info. for when the need arises. None of us can remember everything on the Theory Front. Al. |
20th Nov 2008, 5:37 pm | #7 |
I haven't seen sensitivity figures quoted for domestic valve sets in their service notes, but here's a thread from a time back, where I did a rough and ready check on a Pye P76.
https://www.vintage-radio.net/forum/...read.php?t=321 It was 4mV to 15mV for 100mW output. Comms receivers usually have a sensitivity spec in the manual. E.g the AR88 has a stated sensitivity of about 3µV for 20dB S/N CW and about 8 for AM. The exact values vary depending on the frequency, and they give tables. To answer your question broadly, I'd say 20µV or less for a comms receiver and 20mV or less for a domestic AM receiver. What features does a comms receiver have over a domestic receiver? It depends on the comms receiver. More than one IF stage, maybe with staggered tuning. At least one RF stage. Often a separate local oscillator valve for stability. Sometimes specially chosen components such as caps with particular temperature coefficients so the frequency remains stable Sometimes a particularly rigid cast chassis because rigidity is important. BFO, often with a neon stabilised supply. Sometimes Noise limiter and crystal filter. Switchable AGC sometimes with long and short delay. Often an elaborate geared drive for the tuning cap. Separate RF and AF gain. Sometimes an S-meter. Usually an aerial tuning control. Very often a selectivity control. Offhand I don't think I've ever come across a domestic receiver with a BFO or switchable AGC. HTH, Pete. |
20th Nov 2008, 5:47 pm | #8 | |
Hi Pete,
Thanks for taking the time to put this detailed answer together. Quote:
And thanks for listing the features, also. Very interesting stuff. I'll also check the link you provide here. All the best
Al |
20th Nov 2008, 6:05 pm | #9 |
Many of the details on the Lowe range of receivers can be found here
http://www.arar93.dsl.pipex.com/mds9...ent/lowe1.html |
20th Nov 2008, 6:06 pm | #10 | |
And even that assumes the same IF bandwidth. Al. Last edited by Skywave; 20th Nov 2008 at 6:08 pm. Reason: Grammar! |
20th Nov 2008, 6:13 pm | #11 |
Sensitivity is not the only consideration of course, things like tuning bandwidth and spurious signal rejection are also important.
20th Nov 2008, 6:14 pm | #12 |
I see your point, Al, but I was looking at the smallness of the signal voltage and in absolute terms, 20uV and less seems very small indeed (although I do recall that I needed an extra stage in front of a comms receiver to detect carrier waves from moribund satellites and I wonder what signal size we were dealing with there? )
Al |
20th Nov 2008, 6:43 pm | #13 |
If you are impressed by 20 µV then you might like the early valve Yaesu ham radio transceivers quoting rx sensitivity of 0.5µV for s/n 10-20dB.
20th Nov 2008, 6:52 pm | #14 |
One of the main problems with comms receiver design is front-end noise. it's easy to increase the sensitivity by adding stages, but that's no use if it also increases the noise. There's a big difference between a set which claims 10µV @ 6dB S/N and another which does 10µV @ 20dB
Comms receivers and domestic receivers are designed for different jobs and to different budgets. One's designed to recover intelligence from very weak signals and cost, styling, audio quality and ease of use are secondary. Very often they were bought by governments or large companies. Domestic receivers are appliances and pieces of furniture. Ease of use, eye appeal, reasonable cost (because people are spending their own money) and decent reproduction from powerful stations at most a few hundred miles away are important. Are you sure that the device for picking up satellites is an amplifier and not a frequency converter? Pete. |
20th Nov 2008, 7:45 pm | #15 | |
https://www.vintage-radio.net/forum/...4&d=1201795663 Your analysis of the design differences between the two types of sets is very interesting and lucid. Thank you. If the functional spec is so clearly defined - the difference between detecting strong, nearby signals vs weak, distant signals - then the obvious differences in cost, component count & sophistication make a lot of sense.
Al Last edited by Al (astral highway); 20th Nov 2008 at 7:51 pm. |
20th Nov 2008, 7:50 pm | #16 |
Impressive indeed. I will start looking for one!
Al |
20th Nov 2008, 8:02 pm | #17 |
http://www.arrl.org/tis/info/pdf/0003069.pdf
This is a report relating to the Elecraft K2 Transciever - A kit radio built by at least two of us here - Performance equal or better than a commercial product costing two or three times more! Still regarded as the best reciever in the amateur market!
20th Nov 2008, 8:20 pm | #18 |
Incredible. Thanks Sean. I'm guessing these aren't still available as kits..? (mind you, it would seem a bit of a waste as I don't have a ticket to TX)
Al |
20th Nov 2008, 8:51 pm | #19 |
Yep, still available, and good fun to build too!
21st Nov 2008, 2:05 pm | #20 | |
If you are interested in picking up satellite transmissions, then a receiver, however sensitive and quiet, is only part of the story and a decent aerial system to feed it would be important. I suppose that's another difference between comms receivers and domestic receivers. Domestic receivers frequently have an internal ferrite rod or frame aerial, because it's compact and tidy. Comms receivers are expected to be used with an outside aerial. Pete. |
