19th May 2020, 3:43 pm | #1 |
Philips GR1AX space helmet tv.
Can anyone assist, i have a Philips GR1AX space helmet tv but am having a bit of trouble tuning in. I have a few stb's but no luck.
The stb@s are Sony VTX-D800U/ Goodmans GDR11/ Goodmans GD11 FVZS1 I hope one of these are ok if not could you please tell me which STB to get. Many thanks Steve. |
19th May 2020, 4:44 pm | #2 |
Re: Philips GR1AX space helmet tv.
You need one with an RF modulator. I believe the Goodmans GDR11 has one
looking at the user manual (download it here) https://goodmans.zendesk.com/hc/en-u...R11-User-Guide Check that the modulator output is set to UHF and try various channels. You need a female to male flylead between RF on the STB out and the aerial socket of the TV
-- Graham. G3ZVT |
19th May 2020, 5:06 pm | #3 |
Hi Graham, i have had the Goodmans GDR11 working on other old tv sets.
The space tv has o to 039 channels none are picking up anything. (No remote) Thanks Steve. |
19th May 2020, 6:18 pm | #4 |
If the set was once used with a VCR it is likely that preset 39 or 0 are tuned somewhere in the vicinity of what your modulator would produce. In that case, set the TV to preset 39 and try and tune in the modulator. Try the same for preset 0.
If that doesn't work, you'd need a suitable remote for the TV set. EDIT: It seems the presets can be tuned and stored without a remote. See https://www.p4c.philips.com/files/1/...20_dfu_eng.pdf |
19th May 2020, 6:25 pm | #5 |
thanks for that, is it possible for a guide how to tune the modulator?
19th May 2020, 6:30 pm | #6 |
19th May 2020, 6:45 pm | #7 |
Thanks i will have another try in the morning and let you all know.
19th May 2020, 9:50 pm | #8 |
I might be wrong here but wasn't the GR1AX prone to going into hotel mode on it's own? This would prevent the user from entering the tuning mode and limiting the volume level.
To recover from this you needed to select the last prog number or the last but one and perform a series of button presses, or am I thinking of a different chassis. John. |
20th May 2020, 12:30 am | #9 |
Preset 38, the keys are surprisingly mentioned in the user manual I linked.
20th May 2020, 12:34 am | #10 |
Although the set has 39 channels, they are just programme presets. You'll need to open the tuning menu and scan for the modualtor's output.
It could indeed be in Hotel mode. For the GR1AX, I think you go to programme preset 38, press store and vol - (to unlock), or, press pr - and vol + (to lock and unlock). There were some sets with 3 keys on the set, others had more. YMMV. When unlocked you will be able to access the tuning. Open rhombus key on the remote control.
Regards, Ben. |
20th May 2020, 12:42 am | #11 |
He doesn't have a remote.
20th May 2020, 1:56 am | #12 |
Which is not needed since there should be a rhombus key on the local controls.
20th May 2020, 1:57 am | #13 |
The GDR11 modulator appears to cover the whole of bands IV & V, so he should be able to find a match to one of the TVs presets by trying 21-68 in turn.
-- Graham. G3ZVT |
20th May 2020, 12:47 pm | #14 |
Afternoon all thanks for all your input it has been most helpful. I have now somehow got the tv to work, i held down the store and control's . I wonder if you know of better quality STB (used) that will work with the tv ie Humax etc. Many thanks Steve.
20th May 2020, 2:57 pm | #15 |
Glad to hear you got the tuning sorted.
I don't really know what you mean by better quality STBs, the Goodmans you have is pretty decent in my experience. There aren't many with an inbuilt UHF modulator. If you want a more modern box you will have to route the signal through a VCR.
Regards, Ben. |
20th May 2020, 3:42 pm | #16 |
Hi Ben, just one that can pick up more tv stations my goodmans has a limited amount.
Many thanks Steve |
20th May 2020, 4:55 pm | #17 | |
Also there are a small number of Standard Definition channels that only can be received with a DVB-T2, a so-called HD tuner.
-- Graham. G3ZVT |
20th May 2020, 5:37 pm | #18 |
Graham,yes we can pick many more freeview on main tv via same aerial.
Thanks Steve |
21st May 2020, 11:56 pm | #19 |
Your Goodmans GDR11 Freeview box may be suffering from dying electrolytic capacitors in the power supply. This was a very common fault - it sometimes started happening after only a couple of years' use.
Open up the box (don't forget to unplug it from the mains first!) There are some screws in the bottom. Undo these, then unclip the two halves of the plastic case. Look closely at the circuit board. The usual fault is a 470uf or 1000uF capacitor which appears to have gone dome-shaped on top. Sometimes the top looks flat like normal, but the rubber bung has pushed itself out of the bottom of the capacitor. If you spot a failed capacitor like that, replace it and it's pretty much guaranteed that your box will work perfectly again. To prolong the life of the Freeview box, I suggest only plugging it into the mains while you are actually using it, and unplug it when you're not. Don't worry about missing an over-the-air software update - these have finished now. |
22nd May 2020, 12:51 pm | #20 |
Afternoon, so would this fault result in lack of tv stations when rescanning?
Thanks Steve. |
