Old 1st May 2020, 2:19 pm   #1
garry71
Default Main panel cleaning
I have a rather scruffy looking Akai 4000D on the way from ebay.
What's recommended for cleaning the main front panel without damaging any of the lettering?
I have Brasso and Autosol in the house if they're suitable. I'm assuming the front panel will be aluminium, and haven't tried them on that before.
Thanks a lot.
garry71 is offline
Old 1st May 2020, 2:28 pm   #2
Edward Huggins
Default Re: Main panel cleaning
For goodness sake don't use Brasso! Use White Spirit.
Edward.
Edward Huggins is offline
Old 1st May 2020, 2:38 pm   #3
Michael Maurice
Michael Maurice's Avatar
i use Servisol Foam cleanser
Forum Moderator
Michael Maurice is offline
Old 1st May 2020, 3:07 pm   #4
paulsherwin
paulsherwin's Avatar
Brasso and Autosol are both abrasive, as is T-Cut.
Whatever you use, always try it out on an inconspicuous area first. The various inks and paints used for front panel lettering can become unstable with time and can just wipe away in seconds.
paulsherwin is offline
Old 1st May 2020, 3:53 pm   #5
DMcMahon
DMcMahon's Avatar
I also have found Servisol Foam cleanser good.
DMcMahon is offline
Old 1st May 2020, 4:52 pm   #6
garry71
Okay, I'll get some Servisol foam then.
Cheers all.
garry71 is offline
Old 1st May 2020, 6:26 pm   #7
Lloyd 1985
Lloyd 1985's Avatar
Before trying any harsh chemicals on it, try just a damp cloth! I have microfibre cloths that I just use water with, not dripping wet, just wrung out well, and give it a good going over with that. If it’s really dirty I take apart said item and give it a wash in warm water with a bit of hand soap.
Lloyd
Lloyd 1985 is offline
Old 2nd May 2020, 3:42 pm   #8
David001
I'm with Lloyd: cloth, warm water and detergent or hand soap gets most muck off
David001 is offline
Old 2nd May 2020, 4:43 pm   #9
vidjoman
If it is aluminium then it's probably anodised. As said before a clean with soapy water should get most muck off. Remove the panel and it'll be easier.
vidjoman is offline
Old 2nd May 2020, 5:20 pm   #10
garry71
I have some Servisol foam cleaner on the way, but I'll try soap and water first anyway.
Now that the machine is here with me, the anodising looks a bit shot in places.
When I manage to get the panel off I can give it a clean and see what's what.
Cheers.
Name:	akai 4000d front.jpg
garry71 is offline
Old 2nd May 2020, 8:28 pm   #11
DMcMahon
DMcMahon's Avatar
Yes soapy water (I sometimes use diluted washing up liquid) works well, the Servisol as well as a good cleaner can also remove some stubborn stains and can give a nice shine,
As others have pointed out, always first test any cleaning product/method on a small area to make sure that it is not going to cause a problem
DMcMahon is offline
Old 2nd May 2020, 11:51 pm   #12
Uncle Bulgaria
Uncle Bulgaria's Avatar
Even then, be careful. I'm repairing a clock (thankfully not valuable) for a relative and have had a night of re-lettering the dial with the finest Rotrings in my possession, after a suite of careful cleaning tests lulled me into a false sense of security and I discovered to my horror that after the second pass the maker's name was coming off. A salutary lesson in never being too careful, and terribly embarrassing.
Uncle Bulgaria is online now
Old 3rd May 2020, 4:31 pm   #13
camtechman
camtechman's Avatar
Seeing the corrosion to the heads is so bad why spend time and effort on the main panel until the head problem is resolved ?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 7th May 2020, 1:59 am   #14
garry71
I posed my cleaning question before I'd actually got the machine in my hands. What looked like dirt in the ebay photos is actually pitting and corrosion, so I'm going to attempt refinishing the panel. I have a couple of ideas I'll experiment with.
Even if the heads turn out to be knackered, I'll do it for the experience, and to see if I can make a decent job of it.
garry71 is offline
Old 7th May 2020, 2:33 pm   #15
stuarth
Be very careful with foam cleaners. Some are safe in panel lettering, some just take all the lettering off. Guess how I know that.
Stuart
stuarth is offline
Old 7th May 2020, 2:54 pm   #16
stevehertz
stevehertz's Avatar
Another one for Servisol foam cleanser. Does an amazing job and is just about the best for not affecting lettering. Use cotton buds and/or a toothbrush to get into corners and around awkward shapes.
stevehertz is offline
