Old 13th Aug 2018, 3:24 pm   #1
stitch1
stitch1's Avatar
Default DAC90A (yes another one)
Well I’m not sure this really warrants a success story based on the criteria it’s definitely not unusual or challenging but may be mildly interesting, and I wanted to ask a couple of questions so posted here.
I’ve not deliberately avoided DAC90As but just not that interested because they are so plentiful but when trawling eBay as you do I spotted this cream one which looked complete, unmolested and grubby.
It was advertised as collection only and nowhere near me and had received no bids so I messaged the seller and asked if it could be posted. They obliged I paid £47 and thankfully it arrived safely.
On inspection it was all complete and original so the restoration (more an overdue service than a restoration and nothing like the quality others on here do) was straightforward. Even the bulbs were serviceable, so I changed componants where required which didn’t take too long, it took longer to clean the chassis and case.
The set did have excessive mains hum so I suspected the smoothing caps, but searching this site I found out about the UL41 spare tag issue, I rewired this avoiding using the spare pin and was surprised at the improvement so much so I’ve not replaced the smoothing caps.
So a couple of questions...
kaylee20s post on DAC90A mods mentions changing C17 (trader sheet 1161) from 0.003uf to 390pf to improve the treble. Personally I don’t find the sound muffled but that may be just my ears but, if I wanted to change this what should the working voltage be?
https://www.vintage-radio.net/forum/...ad.php?t=35784
The seller said that the grill was dented but in fact it is perfect but has a discolored section as can be seen on the photos (looks worse on the photo). It seems to have been over polished but I tried polishing the rest to make it the same but it’s no better. Has anyone had success painting these and if so what’s the best match paint for the gold/copper colour?
John
ID:	167484   Click image for larger version
ID:	167485   Click image for larger version
ID:	167486   Click image for larger version
ID:	167487   Click image for larger version
stitch1 is offline
Old 13th Aug 2018, 6:17 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: DAC90A (yes another one)
I have a soft spot for these sets because one of them used to entertain us at boarding school in 1961.
I guess I will never know if it was a 90 or 90A, it could have been either, but I have solved that dilemma by buying one of each at the same auction.
Just go for 1000v capacitors and stop worrying
I found that Duraglit silvo wadding brought the cabinets up like new with practically no effort. Mine are both mottled brown bakelite though.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 14th Aug 2018, 6:14 am   #3
stitch1
stitch1's Avatar
This set has 2 tone correctors, the usual one on the output tx and C17. I only have the ceramic disc capacitors for small values which I think are 10V, I’ll experiment with these and get a higher voltage one if the change is going to be permanent.
John
stitch1 is offline
Old 14th Aug 2018, 12:51 pm   #4
Ian - G4JQT
Ian - G4JQT's Avatar
Yes, you'll need a say 250V rated cap for C17, but at least a 600V cap for C20 (why so high is all explained elsewhere on the forum).
But you could try a 10k pot in series with C20 to adjust its effect on frequency response. Measure the value that gives you the tone you want and replace with a 1 watt fixed resistor.
Such a set up is sometimes used as a tone control; a bit crude for the purists, but it works. Just be aware of HT around that part of the cct while fiddling with it!
Ian
Ian - G4JQT is offline
Old 14th Aug 2018, 12:53 pm   #5
kalee20
C17 sees less than 100V in normal use.
My own rule is, what happens in abnormal use? If the UBC41 failed then C17 could see full HT, so 250V is a sensible rating. (I actually used a 630V polystyrene from Farnell).
Failure of C17 will cause no damage, though. So if you have a 63V, or 25V, capacitor - try it! It will hopefully last long enough to assess any improvement!
kalee20 is offline
Old 14th Aug 2018, 11:51 pm   #6
stitch1
stitch1's Avatar
Thanks for the comments everyone ... I’m happy with sound as it is but may change it just to see if I can tell the difference.
John
stitch1 is offline
Old 15th Aug 2018, 12:08 am   #7
Graham G3ZVT
I think it sometimes helps to cut the bass if your speaker cone suspension is passed its best.
Graham.
G3ZVT
