Old 5th Jul 2020, 7:39 pm   #1
davidh2019
Default PW 208 Bandspread Portable restoration - alignment
Hi
Further info from a previous post inc circuit diags.
See https://www.vintage-radio.net/forum/...d.php?t=168193
I have changed the electrolytic caps as suggested in the previous post but with no improvement in performance of the radio. I even temporarily replaced the RF stages decoupling caps with no improvement either.
However re alignment has been much more successful and the set is working reasonably on MW.
I have never aligned a radio before and I started by aligning the IFTs to 470KHz using a Digimess SG100 sig gen.
IFT 1 and 2 peaked with just a little tweek of the slug however IFT 3 is no where near as sensitive and I can twiddle the core quite a lot both up and down with no sensitive spot like I obtained with IFT1 and 2.
On IFT3 should I get the same sensitivity as IFT1 and 2?
davidh2019 is offline
Old 5th Jul 2020, 8:20 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: PW 208 Bandspread Portable restoration - alignment
If IFT3 feeds the detector it will not be as “peaky” But would expect some rise when on tune.
Frank
Nuvistor is online now
Old 5th Jul 2020, 8:50 pm   #3
crackle
Have you tried turning the signal generator output right down so you can hardly hear it.
Mike
crackle is offline
