29th Jun 2020, 3:29 pm | #1 |
Ducretet Thomson C635 1935
Hello,
Just got this set – it looks like it has been in a barn since the war but it is complete To establish if there are enough functioning bits on it I have: Set the voltage to 225-250v Replaced grid capacitor C1 Replaced two big 8uf electrolytics C5 & C6 with 10uf as C6 started to get warm Replaced C29 as it started to grow in front of me! Voltages on rectifier: 4.7v on heaters 338vac on both plates 322vdc – cathodes Voltage output: Pin 1 & 6 heater 6vac 2 Anode 199v 3 Grid 2 219v 4 Grid 1 -16v 5 Cathode 0v However not a squeak from the speaker. I think I have diagnosed that as an open voice coil I have connected a modern 8 ohm speaker across the contacts on the output transformer that connected to the voice coil and I have some low output and one very weak station! QUESTIONS: Are the valve voltages reasonable? Is it possible/realistic to rewind a voice coil? Dial cord is broken but it is stranded steel wire approx. 0.3mm in diameter – any suggestions for replacement? https://www.doctsf.com/ducretet-thom...5/f3749/ori=ps As always thoughts and suggestions welcome many thanks Philip |
3rd Jul 2020, 10:59 am | #2 |
Re: Ducretet Thomson C635 1935
Having spent some time looking at voice coil rewinds the inter-web is may well be above my pay grade!
The field coil is working as is creates a magnet, which I understand is also a choke/ inductor in the power supply. So could I replace the 10inch speaker with a more modern unit, if so what impedance and what do I do about the choke function? Thanks Philip |
3rd Jul 2020, 11:29 am | #3 |
Hi Philip have you checked to see if the pig tails are ok sometimes the can look ok but be o/c these are the flexible wires connecting the coil to the L/S terminals . If the voice coil is o/c ,fit a new speaker , remove the field coil mount it separate to the spk. That could be a very nice looking radio. Good luck Mick.
3rd Jul 2020, 11:52 am | #4 |
Thanks Mick
I will check out the pig tails I think it has the potential to be a good looker although it may be a long project, at the moment I'm just at the evaluation and conservation point, as I found a few woodworm holes I treated the case and glued down some loose veneer, bit of switch cleaner and radio 4 long wave appeared ...so there is hope! Philip |
