Reply
Old 23rd Nov 2023, 10:20 pm   #1
EdGizzard
Default Revox A700 Capstan not spinning
Hi All,
Capstan Motor not spinning on my A700. Have checked the fuses. All seems fine.
Was going to check the power transistor tomorrow. Will also test motor.
Any thoughts much appreciated. Thanks all.
Service manual link:
https://drive.google.com/file/d/1LqW...ew?usp=sharing
EdGizzard is offline   Reply With Quote
Old 24th Nov 2023, 12:02 am   #2
TIMTAPE
Default Re: Revox A700 Capstan not spinning
Hi Ed, has the machine been in recent use? If not I'd test the electrolytic caps on the motor PCB. Silly question: is one of the three speed buttons selected?
TIMTAPE is offline   Reply With Quote
Old 24th Nov 2023, 10:13 am   #3
EdGizzard
Thanks Tim,
Yes 7 1/2 pressed in
Yes been using it recently. Switched it on yesterday but capstan not moving.
Just checked the motor and it seems OK also power transistors seem fine. Will move onto to the PCB. Thank for you help.
Old 24th Nov 2023, 1:35 pm   #4
EdGizzard
Find attached Capstan Control CD.
I've tested everything on here and all seems good. The AC cap and power transistor that are connected to it are also fine.
I guess I should check the power supply? All other functions on the machine appear in working order.
Any advise on where to start here?
Thanks everyone.
Full Service manual here:
Old 24th Nov 2023, 2:27 pm   #5
EdGizzard
I've tested everything on the Capstan Control board and everything connected to it. 135v AC is coming in.
I guess I should move on to the Capstan speed control board?
Thanks all
Old 24th Nov 2023, 3:12 pm   #6
DMcMahon
DMcMahon's Avatar
I note that you above have tested the Control Board but just to mention the capacitor C1 on that board is listed as 0.47uF 150V MP (Metalized Paper).
This is the same description as the capacitors on the Revox A77 Tape Drive board, which generally are Rifa capacitors, on the A77 they sometimes fail/go up in smoke.
DMcMahon is offline   Reply With Quote
Old 24th Nov 2023, 5:13 pm   #7
EdGizzard
Thanks David. I checked that cap. Seems ok.
After putting it all back together it started working!!
Well at least i know a little more about it now. Lets see how we go.
Thanks for your help
Old 24th Nov 2023, 6:46 pm   #8
Radio Wrangler
Radio Wrangler's Avatar
Sounds like a dry joint. Might be worth checking for others.
Old 24th Nov 2023, 11:53 pm   #9
Analogue man
They recently went on my A77 relay board, interestingly the machine kept on working until you unthreaded the tape and then I found that the reel motors were still powered with the machine in STOP. I replaced them all.
Graham
Analogue man is offline   Reply With Quote
Old 25th Nov 2023, 8:31 pm   #10
Michael Maurice
Michael Maurice's Avatar
You MUST replace all the RIFA's on the A700, failure of them can cause serious problems especially in the system control module.
Please do not use the machine until you have done so.
Forum Moderator
Michael Maurice is offline   Reply With Quote
Reply
