25th Aug 2007, 4:19 pm | #1 |
Chemically treating Chrome to look like Brass?
Does anyone know if it is possible to chemically treat a chrome metal finish to make it look like brass?
The question is posed with regards to the chrome and brass tuning buttons used on the Bush TR82 portable and variants. As most will be aware the tuning buttons are often missing on these portables and the brass types virtually unobtainable except by taking from a scrap donor set. However I always seem to have a few of the chrome type spare and so wondered if it was possible to change their finish in some way to a similar colour to brass? Opinions appreciated. |
25th Aug 2007, 4:48 pm | #2 |
Re: Chemically treating Chrome to look like Brass?
Hello Robert,
I use a mixture of M&P antique gold lacquer and Rustins metal lacquer. Many of the 'brass' trims on 1960s transistor radios were not solid brass, some were brass and nickel plated steel, and some nickel plated steel with a gold varnish sprayed on. If you mix a little M&P lacquer into some Rustins and maybe a spot of cellulose thinners and then very quickly paint it liberally over the chrome trim, within a few minutes it will be dry and will look just like varnished brass. Do take the trim off the Bush TR82B dial first as the cellulose thinners in the Rustins will damage the perspex. Howard Last edited by howard; 25th Aug 2007 at 5:02 pm. |
25th Aug 2007, 5:02 pm | #3 |
Hello Howard
Thanks for your reply. I've heard of Rustins Lacquer, which I believe just gives a protective clear acrylic coating to metals to prevent tarnish. But haven't come across M&P Lacquer before, can you suggest a suitable place to look for it? Just done a quick internet search and not found anything. I also found this American website which sells metal plating kits; http://www.caswellplating.com/kits/plugnplate.htm Very interesting but a little expensive for just doing the odd tuning bright though. |
25th Aug 2007, 5:06 pm | #4 |
Hello Robert,
Caswell's won't ship many of their chemicals out of North America so get your plating kit here .... http://caswelleurope.co.uk/ordinfo.htm You will also need a sisal polishing wheel and various polishing products to polish the trims to perfection before you can degrease and then replate them. M&P aka Meadows and Passmore are here ... http://www.m-p.co.uk/ The Rustins that I have here is cellulose rather than acrylic, I bought it last year at Robert Dyas. I guess with the new paint legislation, it may now be acrylic. Howard Last edited by howard; 25th Aug 2007 at 5:32 pm. |
25th Aug 2007, 5:07 pm | #5 |
If the base metal is brass, I suppose you could use wet and dry paper to sand the chrome off and then polish it
It might be worth seeing if another member would like to do a swap first though David |
25th Aug 2007, 5:20 pm | #6 | |
I've not encountered a chrome plated brass trim, they're always mild steel, as are the chrome TR82C trims, that's why they rust. I've polished off the brass plate on steel trims with Brasso back to the nickel and then varnished them as above and they look just as good as the originals. Howard Last edited by howard; 25th Aug 2007 at 5:27 pm. |
25th Aug 2007, 5:28 pm | #7 |
I've found the Meadows & Passmore website now Howard. They have three sorts of gold lacquer; pale, medium, and dark. Which one is it you've used before and would recommend please?
I've thought of that idea myself Dave, but I don't think its solid brass underneath the chrome. More likely nickel or a nickel alloy and I would probably end up ruining the bright. I think colouring as per Howards suggestion is the best way to go. At least it should be reversible if it doesn't look right. |
25th Aug 2007, 5:31 pm | #8 |
Hi I did this once on a chrome plated light fitting but just used "standard" light oak varnish it worked extremely well HTH
Mike |
25th Aug 2007, 5:36 pm | #9 | |
0358 012515 Lacquer, dark gold 125ml With P&P and VAT it came to a staggering £8.64 but one needs so little of it it will last for years. If you send me the trim, I will varnish it for you. Howard |
25th Aug 2007, 7:36 pm | #10 |
Robert
There may be other things in the M & P catalogue that may interest you to lessen the P & P a bit.
Mike. |
26th Aug 2007, 2:17 am | #11 |
Thanks for that kind offer Howard, I appreciate it very much. But rather than use up some of your lacquer and take up your valuable time I'll place an order with M&P. A bottle of the lacquer on-hand will most likely come in quite useful from time to time!
Yes I've already downloaded a pdf copy of the catalogue Mike and there is some interesting stuff in it. I probably will end up ordering one or two other things from it as well as the lacquer. |
