Old 27th Jul 2007, 11:14 am   #1
Radio_Dave
Radio_Dave's Avatar
Default Yellow carpenter's wood glue
What's the difference between yellow and white wood glue .
Apparently, after some web trawling, I need yellow (not white) wood glue to stick down loose veneer. I've only ever seen white and wouldn't even know where to get the yellow variety.
Radio_Dave is offline
Old 27th Jul 2007, 12:59 pm   #2
peter_scott
peter_scott's Avatar
Default Re: Yellow carpenter's wood glue
Is, perhaps, the yellow, the stuff made from boiled up cows hooves that needs to be heated in a cast iron glue pot ...and the white just the usual modern PVA?
Peter
http://www.secondhandtools.co.uk/ww14en.htm
http://www.thebestthings.com/newtools/hide_glue.htm
peter_scott is offline
Old 27th Jul 2007, 1:07 pm   #3
mickjjo
mickjjo's Avatar
I think the yellow and white varieties are both PVA type glues with different properties, This site describes the various types:-
http://www.diyinfo.org/wiki/Types_Of_Glue
Regards, Mick.
mickjjo is offline
Old 27th Jul 2007, 1:53 pm   #4
Gavtech
Regards, Mick.
Slightly off-topic...
There is a part in that article, where he is talking about Epoxies, that seems counter-intuitive to me:
''Another aspect I like is that you can deliberately adjust the mixing ratio to achieve different cured resin properties. More resin will increase the hardness and tensile strength, while more hardener will increase the elasticity or the cured glue''
I think I would have expected that to be the other way around... or is it a simple error?
Regards
Gavin
Gavtech is offline
Old 27th Jul 2007, 1:58 pm   #5
ppppenguin
ppppenguin's Avatar
I'm pretty usre that the terms "white glue" and yellow glue" are from the USA. I've never been quite sure about the UK equivalents. I think that white glue is PVA glue such Evostick Resin W.
ppppenguin is offline
Old 27th Jul 2007, 2:02 pm   #6
Radio_Dave
Radio_Dave's Avatar
Thanks for the replies
I've done some more web searching and I think I've answered my own question. It seems like white glue is PVA based and yellow glue is aliphatic resin (whatever that is ) based.
Thanks
Old 27th Jul 2007, 2:36 pm   #7
GMB
GMB's Avatar
The confusion is caused by the mislabelling of one of the components as "hardener" which implies it's a catalyst like that used for GRP. With epoxy the two components react which each other and so are mixed in equal quantities (although what they do to them to make them look equal I don't know). Some manufacturers just call them A and B, so it all depends on which is which, but adjusting the ratio slightly is a legitimate way to adjust the property of the result.
GMB is offline
